Author Topic: HDMI monitor claims it has speakers when it doesnt?  (Read 3765 times)
Offline cdevTopic starter
« on: February 22, 2021, 05:34:57 pm »
I have a small pair of speakers that would be ideal to give sound to the HDMI monitor I bought recently which falsely enumerates as having speakers. Why would it be doing this, is it common, and how to fix it. AS FAR AS I CAN TELL, it does not have any speakers, but internally would it have an audio output somewhere? I am on linux, is there any way to get the data that the computer must be seeing and solve this mystery. The monitor is an acer and it was a good value, it looks great. But its creepy that it claims to be an audio sink when it isn't - its also impossible to turn it off.
« Last Edit: February 22, 2021, 05:37:06 pm by cdev »
Offline bdunham7
Re: HDMI monitor claims it has speakers when it doesnt?
« Reply #1 on: February 22, 2021, 05:37:44 pm »
What model number is the monitor?  Is there a small jack somewhere you've overlooked?
Offline wraper
  • Country: lv
« Reply #2 on: February 22, 2021, 05:43:18 pm »
What impossible about that? Nobody forces you to use it as audio device. Probably there is audio out jack or optional soundbar.
and how to fix it
There is nothing to fix. Disable it on PC, if you want. Audio capability is described in E-EDID EEPROM. Computer just reads that information.
Online themadhippy
« Reply #3 on: February 22, 2021, 05:45:05 pm »
Have you confirmed the computer is using HDMI for the audio?is the monitor HDMI audio compatible or does it also need usb for the audio?
« Reply #4 on: February 22, 2021, 06:01:02 pm »
It was sold as an Acer Nitro 22 inch monitor with full HD and it has several inputs including a VGA plain vanilla input.
My video control panel tells me its a Acer Nitro QG221Q  and no, Ive examined it's exterior very closely. No hidden audio outputs or jacks, or vents that indicate internal speakers. But as I said I do have two very small amplified speakers that I feel would be ideal in that application, if it turns out that an audio signal is available somewhere. (And why wouldn't there be one?)
« Last Edit: February 22, 2021, 06:06:08 pm by cdev »
« Reply #5 on: February 22, 2021, 06:07:55 pm »
and how to fix it
It cannot be disabled.
Online coppice
« Reply #6 on: February 22, 2021, 06:11:43 pm »
Is there a headphone socket somewhere on the monitor? I've seen a couple of monitors which don't seem to say anything about headphones in the manual, yet have a poorly labelled 3.5mm socket in some odd location.
Online tunk
  • Country: no
« Reply #7 on: February 22, 2021, 06:23:10 pm »
According to the manual there's "Speakers 2Wx2 (Only Audio-Input Model)(Optional)".
Maybe they didn't bother to remove it from the firmware for the non-speaker model?
Online themadhippy
« Reply #8 on: February 22, 2021, 06:28:15 pm »
looking at the quick start guide  it would appear the audio input is optional,however the actual manual has this
.Adjusting the Audio1.Press the MENU key to open the OSD.2.Using the Navi/OK button, select Audio from the OSD. Then navigate to the setting you wish to adjust.3.Use the Navi/OK button to adjust any sliding scales.4.Volume: Adjusts the volume.5.Mute: Select On or Off
you could always use an HDMI audio extractor
Offline ejeffrey
« Reply #9 on: February 22, 2021, 07:34:23 pm »
and how to fix it
Either you are misunderstanding or your computer is broken.  Just select a different audio output, there is nothing to "disable"  If you can't select a different audio sink on your computer, that isn't the monitor's fault.
« Reply #10 on: February 22, 2021, 08:11:40 pm »
I mean that I cannot use the monitor in HDMI mode without it insisting it's an audio output.
Offline ejeffrey
« Reply #11 on: February 22, 2021, 08:14:27 pm »
The question is: why do you care?
The following users thanked this post: Bassman59, wraper, newbrain
Online themadhippy
« Reply #12 on: February 22, 2021, 08:16:45 pm »
surely then its just a matter  of changing  the settings on the computer for the audio output device
« Reply #13 on: February 22, 2021, 08:17:29 pm »
This is inaccurate as there is nothing about audio in the OSD menu anywhere.
I actually am trying to simply disable it.
Offline Bassman59
  • Yes, I do this for a living
« Reply #14 on: February 22, 2021, 10:18:35 pm »
You can't.
Your computer enumerates what is connected to it at startup or when a detachable device is attached. If your monitor has an audio interface over the HDMI, then it will tell that to the computer and the computer will add that interface to its list of available audio devices.
There is no way to defeat this feature.
I mean, I have a Dell 24" monitor with HDMI and DisplayPort and it has an audio output device built in. (With a ⅛" jack to connect to speakers or an amplifier.) I never use it and I use either my iMac's built-in speakers or a USB audio device that connects to my studio monitors.
Just ignore it. Surely there's a way for you to specify your preferred default audio output device.
Offline JohnnyMalaria
    • Enlighten Scientific LLC
« Reply #15 on: February 22, 2021, 11:17:31 pm »
I have a two identical Viewsonic monitors connected to a laptop. Windows thinks one of them has audio over HDMI even though neither do. I only discovered this on a WebEx call that automatically chose it as audio output.
I just ignore it.
« Reply #16 on: February 23, 2021, 03:27:59 am »
and how to fix it
Today it has got a problem, its injecting events (volume changes) randomly into my system every few seconds and its driving me nuts. Every time this happens a little volume level icon appears and pops emerges from my headphones. Or when there is sound the level intermittently changes now.
Thats  why I want so badly to turn it off.
« Last Edit: February 23, 2021, 03:56:02 am by cdev »
Offline wraper
  • Country: lv
« Reply #17 on: February 23, 2021, 03:34:47 am »
Today it has got a problem, its injecting events (volume changes) randomly into my system every few seconds and its driving me nuts. Every time this happens a little volume level icon apears and a burst of loud sttic merges from my headphones. Thats  why I want so badly to turn it off.
Audio device over HDMI has no way to change volume. It's a one way thing to begin with, it does not communicate back, just receives audio interleaved together with video signal.
« Reply #18 on: February 23, 2021, 03:59:27 am »
What would cause what I describe? USB audio events? See the screenshot I uploaded..
Offline ejeffrey
« Reply #19 on: February 23, 2021, 05:30:58 am »
Most likely a USB-HID device?  Could be a keyboard or mouse that is malfunctioning or has been reprogrammed to generate volume change key events.  Computer gadget manufacturers are obsessed with putting volume control buttons on almost any peripheral imaginable and rarely consider whether that is a good idea.  It could even be your monitor if it is connected via USB as well as HDMI.  Do those static burst / volume change events happen even if you turn your monitor off?  If so, you can rule out your monitor completely.  You can probably troubleshoot this by using some USB/HID sniffers to see what events are happening, and narrow it down from there.
While wrapper is correct that HDMI audio devices have no way to send events back to the host, technically eARC in HDMI 2.1 has the capability to send key press events upstream, but this is extremely unlikely to be your issue and in any cases is not the same as HDMI audio devices even though it happens over HDMI.
Offline andersm
« Reply #20 on: February 23, 2021, 06:49:47 am »
The HDMI CEC spec includes audio controls, and is bidirectional by design. You could try removing the CEC pin 13 from an HDMI cable and see if that helps.
Online newbrain
« Reply #21 on: February 23, 2021, 08:15:00 am »
But:
  • Practically no computer/video card reacts to CEC signals, a notable exception  being the Rapberry Pi.
  • It would be a strange function for a monitor, IME they also do not support CEC
« Reply #22 on: February 23, 2021, 03:52:13 pm »
They make HDMI cable breakout boxes, maybe that would be a good thing to have to troubleshoot HDMI stuff... Generally such cables get used around my house and they help resolve problems quite a bit without exposing sensitive inputs to ESD as much as they would be with a half-assed attempt to splice in.
I have an MSO-compatible device..
Offline ejeffrey
« Reply #23 on: February 23, 2021, 07:14:07 pm »
Linux (and probably Windows as well - I just am not as familiar) has all the software tools you need to troubleshoot this without HDMI breakout boxes or custom cables.  As a plus, those tools will also work in the almost certain reality that the HDMI cable is not the source of your volume change events.
Offline wraper
  • Country: lv
« Reply #24 on: February 23, 2021, 08:07:14 pm »
If you have DVI output, just connect monitor to it via passive adaptor. Audio functionality will be gone. Not that it's the cause of problem. I'm no linux user but in windows you can simply disable it in device manager.
