Author Topic: Small case for micro-ATX build without video card nor HDD  (Read 3363 times)
Offline Wilson__Topic starter
« on: January 12, 2025, 04:45:55 pm »
I tried and failed to find a small case.  Most designed for massive video card emitting 150 watts heat
Any idea of small and light-weight case for all-in-one motherboard.  M.2 NVMe SSD and on-board video, wifi and ethernet.  No video card. No HDD.
May be a case with motherboard in horizontal position.  May be 5 to 8 litres size.  Just need a bit of height (says, 3 inch 90mm) for the CPU heat sink and fan.
Core i5 mid-range CPU, 45 watts TDP, peak 150w.  Total 260 watts.  May be a power supply rated at 500 watts for some safety margin.
This video is ITX-sized motherboard.  I need a slightly bigger micro-ATX sized case in similar layout as this video.
Many thanks
« Last Edit: January 12, 2025, 04:56:23 pm by Wilson__ »
Offline abeyer
Re: Small case for micro-ATX build without video card nor HDD
« Reply #1 on: January 12, 2025, 08:28:18 pm »
Not terribly helpful, but I did look around for similar with not a lot of luck finding many choices that I liked... the style of case you're looking for is far more common in the itx form factor. (or the various NUC style designs, but those tend to be proprietary and not a standard motherboard form factor.)
Fractal Design has some smallish and well made cases that take matx, though all of their smallest ones are itx. https://www.fractal-design.com/products/cases/?size=small-compact
The following users thanked this post: Wilson__
« Reply #2 on: January 13, 2025, 07:37:07 am »
update: Mini-ITX instead of ITX
Yes, thanks for head up
Mini-ITX is industry standard size motherboard
FLEX is standard sized power supply that goes into Min-ITX case
Mini-ITX cases can have one or two slots for video card.  I found case with one video slot and can leave it un-used.   Cannot find a case with zero video slot
« Last Edit: January 13, 2025, 07:49:55 am by Wilson__ »
Online squadchannel
  • Country: jp
  • deepl translate user
« Reply #3 on: January 13, 2025, 09:56:43 am »
If expandability is not necessary, MiniPC is a good option. :box:
18:37
btw, do you already have the motherboard on hand?
« Last Edit: January 13, 2025, 11:14:45 am by squadchannel »
« Reply #4 on: January 18, 2025, 12:58:38 pm »
Yes, mini PC is very nice for business office use case.  Cost is fair for fast CPU and lot of memory.
They are for office desk where load is short peak (open a document is 1 second peak load) or medium load for video conference or video playing.
Larger case with bigger fans are need for business server handling constant high load.   May use same chip as the mini pc, just bigger heatsink, more fins and bigger fan, bigger case.
I am trying to assemble using case at 7 litres size using STX sized power supply.  Intel CPU 65 watts (154W peak) TDP.  Total 220 watts and ASUS advise using 550 watts power supply.
4 litres, holding as hardare, seem a bit tight and need FLEX s-ze power supply.
« Last Edit: January 18, 2025, 01:04:00 pm by Wilson__ »
Offline NiHaoMike
    • Facebook Page
« Reply #5 on: January 21, 2025, 04:23:48 am »
Take a look at 1U rack server PSUs and cooling hardware. I built a gaming PC in a DVD player case once.
Online mikerj
« Reply #6 on: January 23, 2025, 02:38:15 pm »
Something like this CiT S8-13?
« Reply #7 on: January 25, 2025, 09:33:54 pm »
Thanks for forum input, may be I can plan for mini-ITX size with SFX size power supply.  It is a bit bigger and should be easier for fanned air flow.  Can mount two 80mm fans at side.  Optionally 120mm fan at top but that reduces CPU cooler height allowance.
https://www.silverstonetek.com/en/product/info/computer-chassis/ML05/
Offline Halcyon
  • Global Moderator
« Reply #8 on: January 27, 2025, 05:29:36 am »
Would a thin client work? They are generally regular PC's shrunken down. You can have them with or without hard drives, although they will typically include onboard video (VGA/HDMI/DP) as standard. You can pick up second hand ones readily on ebay etc...
