Author Topic: Install Google Play Store on Windows 11 with Android Subsystem WSA  (Read 4248 times)
Offline Kedar264Topic starter
  • Country: in
  • Listen to Your Voice
https://youtu.be/t6nyXxaYPLw
 In this video, I am going to show you a great awaited alternative to amazon appstore windows 11. Google Play Store on Windows 11 First Time. Make sure you hit the like button. Instead of windows 11 sideload android apps you can now directly install apps from google play store. And the great thing is you don’t need to windows 11 sideload apk. This is the first thing you should do before installing windows 11 android subsystem. windows subsystem for android™ with amazon appstore or you can say windows subsystem for android™ with Google Play Store. You can install windows 11 android games directly. Install windows 11 android apps from Play Store. Great alternative to aurora store and amazon appstore.
WSA: https://easyupload.io/qjs1kf
WSA(mirror): https://drive.google.com/file/d/1Sq57...
Kernel: https://easyupload.io/r42y13
1st Command: Add-AppxPackage -Register .\AppxManifest.xml
2nd Command: setenforce 0
