Typically, this is a component in plentiful supply and therefore the price should be relatively low for repurposing.
First, some pointers:
- Many are of high efficiency and have active power factor correction (APFC) which the APFC board may be separate in larger units.
- Output is typically derated for lower AC input voltages.
- Certain units (which may be designed for automated exchange without requiring the callout of a technician) do not have an IEC (computer type) input connector.
- Starting of the main output (where the standby output is constantly enabled) typically requires a signal on a certain pin (typically last mate (which connects last on insertion) for hot swap units) which typically has a pullup or pulldown resistor or for certain units, a command
- on the data pins (usually I2C as used by SMBus/PMBus/IPMB/AdvancedTCA/MicroTCA) for starting which also has pullup resistors to a +5V or +3.3V standby supply.
- Outputs may be segmented and may have different current limits for each segment.
- Electronic components are typically of high quality.
I started a Delta DPS-1200FB (density 1.91W/CC excluding protrusions) and a Lite-On generic part number 684529-001 (density 2.11W/CC excluding protrusions) (both made for HP) by bridging pins 36 (last mate) and 33 which are labelled with numbers on these units.
Attached is a picture with connections to start a Delta DPS-1200CB (made for Cisco) - this one was a bit of a challenge since the 16 pin connector portion for standby +12V and control did not have a "last mate" pin (the pin for starting in its floating state measured around +16V which is connected to a standby supply via a pullup resistor).
If you have successfully started a server PSU outside a server, please share clear picture(s) of the connector with connections for starting thereof (note the use of any "last mate" pins) along with the manufacturer, server brand and model.
