fzabkar said:
I found the problem. There is a stuck bit at this location:
Code:
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00025C10 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00
When I change the 8 to a 0, the CRC becomes 0x0000.
F3RomExplorer is happy with the edit. If you can reprogram your ROM after making the change, then hopefully you will recover your data.
I use HxD (freeware hex editor).
https://forums.tomshardware.com/threads/seagate-archive-hdd-failure-no-crash-no-spin-silent-troubleshooting-advise%E2%80%A6.3699522/FZABKAR
OH MY GOODNESS! YOU ARE AMAZING! YOU DID IT! PRAISE GOD! YOU ARE A SAINT!
2.82 TB - 3,106,287,262,945 BYTES - 748,329 FILES, 57,259 FOLDERS
TAKING (1) DAY TO COPY! IT'S COPYING RIGHT NOW!
YOU HAVE NO IDEA WHAT THIS MEANS TO ME! THIS WAS MY MAIN BACKUP DRIVE THAT I BACKED EVERYTHING UP TO RIGHT BEFORE IT DIED. I WAS MOVING STUFF AROUND AND PICKED THIS DRIVE TO BACKUP STUFF TOO. I WAS GOING TO ORGANIZE EVERYTHING WHEN I PLUGGED IT IN AND ALL OF A SUDDEN IT WAS GONE.
THIS IS INCREDIBLE!
