Author Topic: Is my USB drive still revive-able?  (Read 1186 times)
Offline LoganTopic starter
« on: July 11, 2022, 03:14:50 pm »
Hi, a sad story today.
I ejected and unplugged my 32GB HP USB flash drive, then remember something not yet finished, so I plugged it in again, and it not show properly.
I found out the port is having bad connection, so I changed it to a good port, and it remain problematic.
In gnome-disk-utility, device shows correctly as /dev/sda, but no partition.
When try to format it in gnome-disk-utility, an error message says: "Error wiping device: Failed to probe the device 'dev/sda' (udisks-error-quark, 0)"
Tried to format it on an Android device with OTG, but the "formatting" screen just shows forever.
When trying "dd if=/dev/zero of=/dev/sda", it always stuck after some time, I guess that's the buffer running out and nothing ever written to it.
When trying "sudo dmesg | grep sda", here's the related output:
[ 975.393443] sd 0:0:0:0: [sda] 61440000 512-byte logical blocks: (31.5 GB/29.3 GiB)
[ 975.393561] sd 0:0:0:0: [sda] Write Protect is off
[ 975.393564] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 975.393682] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 975.395149] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[ 975.395154] sd 0:0:0:0: [sda] tag#0 Sense Key : Not Ready [current]
[ 975.395157] sd 0:0:0:0: [sda] tag#0 Add. Sense: Medium not present
[ 975.395160] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
[ 975.395163] blk_update_request: I/O error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 975.395172] Buffer I/O error on dev sda, logical block 0, async page read
The above 6 lines repeat 8 more times (total 9x)
[ 975.398753] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[ 975.398757] sd 0:0:0:0: [sda] tag#0 Sense Key : Not Ready [current]
[ 975.398760] sd 0:0:0:0: [sda] tag#0 Add. Sense: Medium not present
[ 975.398762] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 18 00 00 08 00
[ 975.398763] blk_update_request: I/O error, dev sda, sector 24 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 975.398767] Buffer I/O error on dev sda, logical block 3, async page read
[ 975.399256]  sda: unable to read partition table
[ 975.399934] sd 0:0:0:0: [sda] Attached SCSI removable disk
So, do you think I should try anything more to revive it, or is it completely died?
Thank you!
« Last Edit: July 11, 2022, 03:18:57 pm by Logan »
Offline Zenith
Re: Is my USB drive still revive-able?
« Reply #1 on: July 20, 2022, 09:43:27 am »
Is there valuable data on it?
If so, you could try this. Mac and Windows only, there may be Linux equivalents, I haven't looked.
https://recoverit.wondershare.com/flashdrive-recovery/repair-usb-drive-and-recover-data.html
or there are data recovery companies, but they charge a lot.
If it's just a 32GB USB stick that's acting up, they are so cheap it's not worth wasting time on. If you did get it to start to behave, it shouldn't be trusted.
Offline Haenk
« Reply #2 on: September 01, 2022, 02:39:32 pm »
I'm a bit late to this, but you might want to try the free "testdisk" tool.
