INTERESTING READING !! (OP here...). Though quite a bit is over my head
at this early stage...
Interestingly, their is a fair amount of discussion here about new/updated '
Drivers' lacking, from hardware/etc developers, and their reasons or
interest in producing them for smaller markets?? I would have 'thought' that they would/could supply some parameters/coding/information to the
Unix/Linux COMMUNITY, (who collectively supply such general Open-Source software, gratis!), so that maybe THEY can work on creating such drivers??
And in regards to my VirtualBox Guest 'Ubuntu-Mate 20.04', I found out about a few additional things!! The VM Guest was not recognizing my BlueTooth
hardware, but that's due to the VirtualBox emulation environment! However, 'V.B.' still allows it to work, via the Host, so that's OK. The same sort of thing
is going on with Wireless Broadband. I didn't have to set up communications via the Ubuntu Guest at all, as 'V.B.' just passes the comms via the Host,
straight through my existing (and already logged on) wireless connection, via this Win-10 Laptop Host! So that all works from the get-go with no setting up!
I ALSO found out after research, that you can improve a lot on the VirtualBox emulation, that's NOT done within VirtualBox. In the folder where you installed
VirtualBox, there is a dormant file, called '
VBoxGuestAdditions.iso'. This is to be used within the GUEST only! When the Guest Ubuntu etc is running, and you
are working in it, go to the VirtualBox menu area, select Devices, and CD, and mount the above .iso into the guests virtual drive. It will auto-boot, for various
operating systems, and install into your virtual environment a whole lot of extra settings & refinements, to make it work even better & more smoothly!!
(NOTE:
This is NOT the same as installing the Oracle_VM_VirtualBox_Extension_Pack' from within VirtualBox itself).
The only program so far that will install, but
not run for me, is '
Blender'. Does nothing when selecting it within the GUI. So I learnt to TRY running it in 'Terminal',
which would/(did!) show what the error is! Turns out it needs at least OpenGL 3.3, which the virtual VMWARE screen/graphics controller only has ver 2.1...
(Although the NVIDIA Graphics GeForce GTX-670M card in the host laptop is using OpenGL 4.6, but this can't be seen in the guest!!).
I suspect that if/when I set up UBUNTU-MATE on a stand-alone system, then that won't be the case, and the latest Linux drivers ARE available from...
https://www.nvidia.com/en-us/drivers/results/134859/GIMP works fine though!!
