Author Topic: A warning to engineers about calculators  (Read 17543 times)
Offline tggzzz
Re: A warning to engineers about calculators
« Reply #125 on: December 20, 2024, 07:48:17 pm »
What does the colon in "8:2(2+2)" mean?
In context, I think it's just a placeholder for the classical divide operator symbol (instead of slash), whose unicode I do not recall.
Ah. Bizarre and unnecessary substitution.
Makes me think of the way Humpty Dumpty used the symbol "glory" (which was, of course, written by the mathematician Lewis Carroll).
ISO 80000-2 allows the use of the colon( : ) as ratio(a:b=0.375); the symbol ÷ should not be used. IIRC, the Greek, Latin and Arab arithmetic used colon( : ) as division sign, since fractional arithmetic was treated differently. Maybe the extended use of the fractional sign( /) should be considered bizarre and unnecessary substitution?
I wasn't aware of ISO80000-2, any more than most people are aware of ISO8601 for date formats (emphatically plural!) nor RFC5322 for email address specifications (not so many plurals) :)
I was taught ":" for ratio, and wouldn't use "/" for that.
Using "/" for a fraction is common, mainly due to limitations in earlier typing/printing technology.
Was ":" used to mean division before and/or after Robert Recorde invented the "=" equals sign in 1557 ? :)
Offline TimFox
« Reply #126 on: December 20, 2024, 09:48:59 pm »
There is also the double ratio, or proportion as in  x:y :: s:t
The equals sign "=" was promoted since "no two things can be more equal", or
"And to auoide the tediouſe repetition of theſe woordes : is equalle to : I will ſette as I doe often in woorke vſe, a paire of paralleles, or Gemowe lines of one lengthe, thus: =, bicauſe noe .2. thynges, can be moare equalle."
Offline Zoli
  • Grumpy old men
« Reply #127 on: December 21, 2024, 02:24:21 am »
I've seen in physics textbooks(French, German and other languages) dated from the first half of the 20th century, about 45 to 50 years ago.
Offline SiliconWizard
« Reply #128 on: December 21, 2024, 02:45:03 am »
Yes. The division symbol ÷ was more commonly used though. But I'm guessing the simple colon : was used instead when the division symbol was not available as a character. So, basically a simplification of it.
Offline IanB
« Reply #129 on: December 21, 2024, 04:36:11 am »
Ratio and division are not the same. For example, 2:3 as a fraction is 2/5 or 2÷5.
Offline eugenenine
« Reply #130 on: December 31, 2024, 02:05:57 am »
Only one I ever use is droid48 and x48 on my laptop and pc. I use a rom dump from my own 48sx.
The following users thanked this post: RAPo
Offline tooki
« Reply #131 on: December 31, 2024, 10:24:10 am »
Well… one should use parentheses (not "brackets"--brackets are [ ] { }) …
US English:
() = parentheses
[] = brackets
{} = braces or curly brackets
UK English:
() = brackets
[] = square brackets
{} = curly brackets or braces
I don’t know which usage is common in other English speaking countries.
