Hello users,
This question may be offtopic here, but i need your kind suggestions. I am now going to reinstall an operating system in my computer.
I had Windows 10 earlier. Now I am thinking to use Linux. I have not used it before so I have a few doubts.
Will it be difficult to use and understand Linux?
Will Linux be faster than Winodows 10?
I'm coming in late on the discussion so I'm sure some of my answer will have already been posted, as I didn't bother to read the entire thread. First of all, welcome to trying out Linux! It will be a bit of a learning curve but at the end of the day, you will come out better for having the knowledge even if it doesn't become your "daily driver". Although depending on your use case, like many of us on this forum here, we use Linux for often all our personal, and some even our work computing needs.
Yes and no.
Initially it will be tougher but fortunately there are plenty of places to check. Get used to Googling questions, pick up a Linux book, and learn. Installation can be fairly EASY these days with many distributions, if you can manage to make yourself a bootable USB key. That may be harder for you to do than the actual install... just getting to download the proper ISO and using a number of different tools to write to make a bootable USB key, and making sure you get past your BIOS settings to let you boot it!
You will need another computer to be able to do this, so you need to buy a few USB keys, at least 4 GB each, download a few distros and make yourself a few LIVE USB bootables... then you can try a few different Linux distros out and see which you like more.
Yes and no.
Generally I find Linux to be faster but that is because I am using it on slower machines and I am customizing the Linux distro to one that has very little overhead. For example, I may use a desktop environment that is very "light" and there are Linux distros that are efficient, slim, take up little HD space, and will run much faster than say Windows 10.
However, that is not ALWAYS true, and it also depends on what you mean by "faster"? Does that mean gaming on Linux will be faster? Not really... You still have to push the same amount of calculations through your processor for graphics, etc... Sometimes you will not have optimized drivers for Linux, but you will for Windows. Will it calculate Fractals any faster? Again, this may have nothing to do with the overhead of the system. Windows 10 I have found to be fairly efficient and I have it running on older computers.
You may find Linux "faster" and more responsive if you are using a light desktop environment on an old machine. The advantage of Linux is that you can run it on fairly old hardware but be current as far as your software technology/patches and functionality, whereas Win10 may choke on the older computers simply because of lack of resources. Your old computer may run WinXP perfectly fast but it is not updated and will have vulnerabilities and problems running certain new software. Your Linux machine will still help you take advantage of your old hardware but on the latest bleeding edge of the software development, although you will still need to have minimal levels of RAM to do certain things.
ANYWAYS....
Welcome to your initial embarkation on Linux. I would recommend you start off as I mentioned with simply creating a number of LIVE USB's of say the most common/easy 4 or 5 distros, get your computer and BIOS to cooperate, and then spend some time booting those and trying them out. I did this and I even have a few "persistent" USB's which let me write files, so I never touched the hard-drive in my computer. When you are ready to commit to one distro, you can always dual-boot it on your Win10 machine and you have flexibility for a while, until you are ready to completely drop Windows completely.
I would AVOID... setting up a bunch of VM's. You won't necessarily feel the speed of the system this way. You also wouldn't feel the speed with Live USB keys as the read/write rate on those might be fairly slow also, but the VM's would add a lot more overhead. I would make persistent Live USB's if you really must save files (or just plug another USB key to save to and keep your Live USB untampered). You won't be able to really config and install apps to your Live USB, nor would you want to. This is just to play around and see if it will run and you can function in there. Then I would set up a dual-boot machine, and finally one day abandon Windows.
PERSONALLY:
I use Ubuntu Studio as it comes with a whole bunch of productivity stuff built right in. Then you can install other packages as needed. I have WINE in there configured so I can run tons of Windows games no problem. It has been my main daily driver for years now. Although I've but Lubuntu my kids older computers, and I have bootable USB's of Mint, Tails, and a bunch of others.
https://ubuntustudio.org/
