Author Topic: Looking for a 1U 19" computer... does this even exist?  (Read 3239 times)
Offline YansiTopic starter
  • STM32, STM8, AVR, 8051
« on: May 07, 2020, 10:06:23 pm »
Hello,
I am not sure if I am not looking for a non-existent product, but I seem to have trouble finding the following:
I have a setup of various rack-mount equipment, that is in need of a computer for control and data processing.
What I thought of is a 1U height 19" rack mountable computer, with the following spec:
 - low noise (no server stuff!)
 - shallow installation depth (350mm maximum rack depth)
 - at least one USB3 port
 - ideally a PCIex slot for an IO card
 - ideally more USB ports, than ETH ports (I won't have any use for more than one GbE port, but I can certainly utilize a couple of USBs).
 - ideally two monitor outputs (for two separate monitors).  HDMI/DVI/DP capable of up to 1080p60 is a requirement, second port may be VGA with lower res., no problem.
Regarding system configuration: Able to run Win7 (or Win10), the most intense task for it would probably be feeding HD video stream from a video source to the net or to save it locally.
I would like to buy a second hand piece, but I do not really know what to look for, as I am not really finding much like this.
The only thing apart from a few proprietary HP/Dell stuff I found were some new MiniITX chassis from Supermicro*, without any guts. And the miniITX boards seems to cost an arm an leg for the HW configuration they offer. Like a 250+ USD for an Intel Atom motherboard? Yuck...
Are my requirements completely off? Does stuff like this even exist?
Could you please give any suggestion what could probably fit the above criteria? Unfortunately, I have no clue about today's computing, lost track years ago.
Thanks Y.
//*EDIT: This from supermicro chassis looks just as I want: Supermicro 504-203b, but what board to fit into it? Is the connector back panel even replacable to fit a different board?
« Last Edit: May 07, 2020, 10:08:41 pm by Yansi »
Offline rdl
Re: Looking for a 1U 19" computer... does this even exist?
« Reply #1 on: May 07, 2020, 11:56:02 pm »
You might search Newegg for "1U barebone" just to get an idea of what's available. It's going to be mostly server class stuff. Also try ebay.
A diy alternative would be to rip the insides from some kind of "NUC" type machine and put it in a 1U case. "NUC" style machines are fairly common, consumer grade computers in 1U form factor are not.
Online themadhippy
« Reply #2 on: May 08, 2020, 12:24:38 am »
if you can strech to 4U (and have deep pockets) there 101 pc's aimed at the recording/events market.
Online edpalmer42
« Reply #3 on: May 08, 2020, 12:52:01 am »
Check out the various Ultra Small Form Factor desktop units.  Yes, they're proprietary, but for a niche application like this your options will be limited.  You'd have to figure out a rack mount arrangement, but they are ridiculously tiny.  I use a Dell 9020M as my multimedia PC.  It's actually smaller than their USFF model.  It's the size of a hardcover book, but has enough horsepower to render youtube 4K videos.  It's only 1.4 inches thick.
The following users thanked this post: Yansi
Offline james_s
« Reply #4 on: May 08, 2020, 01:24:31 am »
Low noise is probably going to be an issue. 1U computers use small fans which tend to be noisy. The form factor is primarily used for servers for which noise is not really a consideration. There's no reason you couldn't rack mount one of the various small form factor desktop PCs though.
« Reply #5 on: May 08, 2020, 10:01:40 am »
No way in hell I would go for 4U.  If they can put Quad core i7 into a notebook, I don't  see any reason why couldn't they put it into a 1U 19", where it would be way more relaxed in terms of efficient cooling.  Rack space is scarce and I don't want to transport air. :)
That is a very good suggestion, as the Dell PC would fit in a 1U shelf nicely and could be securely mounted there with a bracket.  It has all the specs I want (except possibility to add an PCIex card) and acceptable price.  :-+
Will consider that. It also seems I can find and buy a metric shit ton of these new/used Optiplex Micro PCs even in local shops.
But still I'd like to look for a more professional solution in a 1U, with possibility to add the expansion card.
Offline Lord of nothing
  • Country: at
Made in Japan, destroyed in Sulz im Wienerwald.
« Reply #7 on: May 08, 2020, 01:25:14 pm »
So it seems there are only two viable options:
1) get a proprietary small form computer brick - it seems there is plenty to choose from with very decent horsepower,
or 2) get a rack chassis and swap the internals. It seems the only computer chassis available are either with horrible crap HW inside (Intel Atom mostly) or they are servers, which are not suitable for what I want by any means.
I will probably get both in the end. The small computer brick would make for a lovely HTPC after all.
Thanks for all suggestions.
« Last Edit: May 08, 2020, 02:03:20 pm by Yansi »
Offline Syntax Error
« Reply #8 on: May 08, 2020, 02:04:47 pm »
Industrial 1U rackmount computers do exist, but they may not match your spec. You might also need another slot for a PSU/UPS.
There's some 1U devices here including ones with shallow depth frames:
https://www.industrial-computers.com/en/industrial-systems-1u-rackmount-computers.php
  • Country: at
« Reply #10 on: May 08, 2020, 02:46:49 pm »
These would be great, however I am not looking for a $1000+++ investment.
Why not?
http://www.shuttle.eu/de/produkte/slim/
https://www.zotac.com/at/product/mini_pcs/all
Same as the above. All companies that can't display price directly are out of the question.
The Dell Optiplex Micro computers so far fulfill almost all criteria I have, and unlike other suggestions, can be found both new and used for reasonable prices.
  • Country: at
« Reply #11 on: May 08, 2020, 03:02:15 pm »
 ::) You dont say where you are from so how should we know every price from every country?
If you are from Austria you know --> Geizhals.at here you can look up for the cheapest price from there Online Seller.  :palm:
« Reply #12 on: May 08, 2020, 03:13:01 pm »
It's not about where I am from or knowing all the prices everywhere. It is about my middle finger to all companies that think they need your personal data first to then very kindly offer price depending how they like yerr face.  No thanks.   ^-^
I'm from say somewhere in Europe, that is likely all that matters.  Your last link Geizhals.at seems to be very helpful though!  Currently sifting through what I can find there, it seems there may be a few promising pieces.
  • Country: at
« Reply #13 on: May 08, 2020, 03:26:56 pm »
If you pick it up from Austria I can sell you everything you like to have.
 :-DD Just send me a PM with stuff where you want a Price from and I send it to you.
« Reply #14 on: May 09, 2020, 09:13:49 am »
Mac is also a "no way in hell" as the software I need is Windows only, but Intel NUC?  I don't know much about them, rather I have skipped investigating them, as they look like toys and considered them not easily rack mountable. To much height.
If you know about a rack mountable options for that, could you give any examples please? All I can find are brackets to mount it so it sticks through the front panel a bit and thats all. Also requires 1.5 HU, which sucks.
Required IO cards are not an issue, separate budget for them. The budget for the PC was $400 tops, so it fits.
But I have finally found a viable 1 HU chassis I can stick any Mini ITX board I want - finally someone used their brain so the connector cutouts are replacable piece of metal and not built for a specific mobo type. Let's see if the seller will agree on price.
« Last Edit: May 09, 2020, 09:16:35 am by Yansi »
« Reply #15 on: May 09, 2020, 09:40:43 am »
Awww now I see.  Will look what the possibilities and prices are.
  • Country: at
« Reply #16 on: May 09, 2020, 10:39:04 am »
$400
Well a 1TB - 2TB SSD got very pricy this Days.
Online Someone
    • send complaints here
« Reply #17 on: May 09, 2020, 11:32:30 am »
Any recent Mac Mini can run windows or linux etc as they are intel based. What they do offer is a common platform that has reasonably good support and alongside the NUCs are some of the only small form factors that have thunderbolt for external PCIe.
Offline james_s
« Reply #18 on: May 09, 2020, 06:18:57 pm »
About a year ago I bought a little small form factor i7 PC to run my Plex server. I forget the brand but it's one of those direct from China things. It only cost me about $300 and the thing has been rock solid, the last time it was rebooted was over 3 months ago and that was only because of a power failure. It's running Ubuntu and has an internal 2.5" HDD bay.
The following users thanked this post: Lord of nothing
Online Someone
« Reply #19 on: May 09, 2020, 11:14:53 pm »
Not true. T2 chip will refuse exposing the internal SSD to OS if not using a certified driver to talk to it.
A recent Mac can only run macOS or Bootcamp Windows or hacked Linux.
The latter two lack proper drivers and overall polishness. Bootcamp runs hot, and running hacked Linux risk data loss at any moment if you log back into macos -- Apple could patch the hack at any moment.
You do have the options to boot from external SSD taking advantage of thunderbolt 3 ports, but that incurs additional cost and points of failure.
[virtualization rant]
"certified"? There are community/open source drives for linux that do work, but the OP was specifically concerned with windows. Apple remote patching an underlying firmware while possible is extremely unlikely, especially unlikely if you're not booting into OSX and running their updates (has there ever been an over the air update outside OSX?).
Offline radar_macgyver
« Reply #20 on: May 09, 2020, 11:59:38 pm »
These guys have short-depth 1RU cases:
http://www.plinkusa.net/1u.htm
And also offer I/O panels for popular mini-ITX boards.
« Reply #21 on: May 13, 2020, 05:39:37 pm »
Finally got something! Thanks all for valuable tips looking for interesting hardware.
Got a couple of chassis including their original guts, the Intel D510M0 boards. Both will be replaced, but I bought both pieces for the price less than a single new empty chassis, so I'm quite happy anyway.
« Last Edit: May 13, 2020, 05:41:38 pm by Yansi »
Offline fordem
  • Country: gy
« Reply #22 on: May 26, 2020, 04:26:19 pm »
Lenovo has a number of "one liter" form factor models commonly referred to as the "Tiny" - slightly larger than an old 5-1/4 half height disk drive (if you know what that looks like).  You could get two of these in a 1U rack space and have room left over.  They are virtually silent in operation, some models do have a PCIe slot, most have dual video, gigabit ethernet and USB ports galore.
Online SiliconWizard
« Reply #23 on: May 26, 2020, 04:39:11 pm »
You can find a few Mini-ITX motherboards these days supporting reasonably powerful CPUs.
The thing you'll have to work on though (possibly) is the CPU heatsink solution, so that it can fit the available height.
Offline artag
« Reply #24 on: May 26, 2020, 08:52:11 pm »
I bought a firewall on ebay. It was packaged as a 1U rack but is a pc internally. It's not very powerful so is much quieter than a typical server.
Aopen's Digital Engine media servers are really small. You can fit two side by side in a 1U rack.
