Keep in mind the standard SSDs have a rather low lifespan when used in a RAID (i.e. constantly reading/writing), there is a reason for a MTBF based on data amount written.
We have one RAID 50 setup running for a couple of years now, using Crucial MX500 SSDs - those are very slow now, in fact, incredible slow. So you should replace them once every couple of years, at least.
And yes, avoid QLC as the plague, TLC+DRAM Cache is the way to go, if you want it cheap. Don't fall for those very cheap Amazon/ebay/Aliexpress SSDs from dubious chinese sources. Those are made from B-grade NAND and therefor not very reliable.
