Author Topic: memory advice  (Read 7856 times)
Offline m3vuvTopic starter
Re: memory advice
« Reply #25 on: January 09, 2021, 07:17:14 am »
Well,i got this going ok with 2x2gb stripps,i was using it with an asus ati radeon hd5770 graphics card,it was running fine so ordered 2 more 8gb strips of ram,after fitting them i got no video out,i then memoved the video card and set the bios to use the onboard graphics,,any idea whats going on?,ive tried lots of settings changes in the bios,regarding the video but cant seem to fix it,any idea what the bios graphics/pcie settings should be on this?,finaly when i changed it to use the onboard graphics the boot drive sequence had altered even tho i never changed that while doing the memory change,any ideas what to do,the onboard graphics dont support dx-11,cheers in advance.
Offline Nominal Animal
Re: memory advice
« Reply #26 on: January 10, 2021, 08:16:37 am »
When you encounter problems, start from the simplest configuration, adding items one at a time to find the culprit, instead of trying random combinations in the hopes of hitting one that works.
If I understood you correctly, with 2×2GB RAM and ATi Radeon HD5770, the machine worked fine.
With 2×2GB+2×8GB RAM and ATi Radeon HD5770, you have no video.
I would try the following configurations next, resetting BIOS settings to defaults before each boot attempt, and booting to BIOS.
  • 2×2GB RAM and ATi Radeon HD5770, to verify the original configuration still works.  If not, something broke; abort.
  • 2×2GB RAM alone, to verify you can boot without the HD5770. Remember to put them in memory slots with exactly one unused slot in between.
  • 2×8GB RAM alone, to verify they work.  If not, they're not compatible with this motherboard; abort.  Remember to put them in memory slots with exactly one unused slot in between. (Can you read the chip markings?)
  • 2×2GB + 2×8GB RAM alone, to verify they work with each other.  Note that in this motherboard, the two must be interleaved, so the four slots must be filled as 2GB, 8GB, 2GB, 8GB; or 8GB, 2GB, 8GB, 2GB.  Try both ways.
  • 2×8GB RAM and ATi Radeon HD5770, to verify the two are compatible with each other.  If they're not, you need to drop one.
  • If everything worked thus far, then 2×2GB+2×8GB RAM plus ATi Radeon HD5770 should work; maybe it was a badly seated card, so retry.  If it still does not work even after reseating everything, this triplet is not compatible with each other, and you need to drop one.
After you find a configuration that works and suffices for you, boot into memtest (using an USB stick, for example), and run it for 48 hours, minimum, to verify the RAM is reliable.  If it finds any errors, you need to change the memory configuration.
« Last Edit: January 10, 2021, 08:18:36 am by Nominal Animal »
Re: memory advice
« Reply #27 on: January 10, 2021, 12:12:25 pm »
well ive tried all ways mentioned,still only the onboard video works,nothing fron the card,guess its stuffed,wierd tho as it was good b4 the memory upgrade!.
Re: memory advice
« Reply #28 on: January 10, 2021, 12:19:05 pm »
Right; I've had that happen, too.  I don't have an explanation, but I suspect it is a hardware issue, something like a cracked ceramic cap or broken trace in the card.  It could be related to the memory upgrade – not necessarily in the electric sense, but because you bumped the card slightly when installing, or something – or it could be a pure coincidence.  It might have nothing to do with the hardware change, and simply decided to go b0rk this same bootup.
Us humans, we're pattern detectors, and we often detect patterns even when there is none (because in our evolutionary history, that sort of reactions has kept us alive and procreating)
Re: memory advice
« Reply #29 on: January 10, 2021, 12:23:24 pm »
well said,how true,my conclusion also,im 53 now with poor eye sight,if i was younger i would have a go at fixing it,but think its not worth the hassle tbh!
