I hoping you good people can align me and calibrate me up, because I don't know the right questions to ask, or even if I am asking the question right.
Problem: Get legacy equipment IO data flow into SCADA.
I'm looking to gain some chops in getting DI, DO, AI, AO out of older PLC's, and discrete PCB's, then publish the information into a central data pool, then port it back to SCADA. Ideally I want to route this data to the data pool via an MQTT client / broker setup, using it's report by exception methodology.
What would you do if you had a PCB and wanted to harvest the I/O off of it? How would you go about it?
Help! Thanks for your advice.
