Does he think you don't know much about such cards, and he is 'trying it on', and trying to make as much money from you, by selling any
junk stuff he can get his hands on ?
I've seen cards like that, simply included with computer purchases, for little or no, extra cost. Making me suspect they are worth little (in real terms, even if they are sometimes for sale, for larger amounts), and have a number of possible problems. Such as potential lack of modern video output connectors, not supporting modern, higher resolutions, not supporting better games, possibly slightly patchy Linux support issues, relative slowness, compared to modern graphics cards.
I'd aim for 15W, and no more than 25W, if I was trying to get a passively cooled 2D usage, graphics card. Ideally, I prefer to get cpus, with built in integrated graphics, if there is no requirement to play fast/modern games on the machine and/or use the graphics chips for powerful computations.
EDIT: E.g. The following costs around £55 brand new, uses a maximum of 50 watts (probably a lot less, during normal 2D useage). Has HDMI/DVI and Display port connectors on it, and seems to support up to 4K output resolution. (
https://www.scan.co.uk/products/sapphire-amd-radeon-rx-550-pulse-oc-2gb-gddr5-graphics-card ).
https://www.techpowerup.com/gpu-specs/radeon-rx-550.c2947I.e. Probably better in most respects, is brand new, modern, and for almost half the money, of the 100 Euro deal you had on offer. Probably uses a fraction of the electricity, and can support modern resolutions/connectors/compatibility, and to a limited extent, games.
There are probably better examples, because I chose the example quickly.
