ECC counters are N/A, so I guess it doesn't have ECC
==============NVSMI LOG==============
Timestamp : Sun Jan 12 12:57:30 2025
Driver Version : 565.57.01
CUDA Version : 12.7
Attached GPUs : 1
GPU 00000000:1A:00.0
Product Name : NVIDIA GeForce RTX 3090
Product Brand : GeForce
Product Architecture : Ampere
Display Mode : Disabled
Display Active : Disabled
Persistence Mode : Enabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-0fd648b9-ede4-0d8f-df8e-d1830363fe2c
Minor Number : 1
VBIOS Version : 94.02.42.00.A9
MultiGPU Board : No
Board ID : 0x1a00
Board Part Number : N/A
GPU Part Number : 2204-300-A1
FRU Part Number : N/A
Platform Info
RACK Serial Number : N/A
Chassis Physical Slot Number : N/A
Compute Slot Index : N/A
Node Index : N/A
Peer Type : N/A
Module Id : 1
Inforom Version
Image Version : G001.0000.03.03
OEM Object : 2.0
ECC Object : N/A
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : No
Drain and Reset Recommended : No
GPU Recovery Action : None
GSP Firmware Version : 565.57.01
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x1A
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x220410DE
Bus Id : 00000000:1A:00.0
Sub System Id : 0x87AF1043
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Device Current : 1
Device Max : 4
Host Max : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 15316
Replay Number Rollovers : 0
Tx Throughput : 550 KB/s
Rx Throughput : 400 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 0 %
Performance State : P8
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Sparse Operation Mode : N/A
FB Memory Usage
Total : 24576 MiB
Reserved : 426 MiB
Used : 2 MiB
Free : 24150 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 2 MiB
Free : 254 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
ECC Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 41 C
GPU T.Limit Temp : N/A
GPU Shutdown Temp : 98 C
GPU Slowdown Temp : 95 C
GPU Max Operating Temp : 93 C
GPU Target Temperature : 83 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
GPU Power Readings
Power Draw : 44.24 W
Current Power Limit : 300.00 W
Requested Power Limit : 300.00 W
Default Power Limit : 390.00 W
Min Power Limit : 100.00 W
Max Power Limit : 480.00 W
GPU Memory Power Readings
Power Draw : N/A
Module Power Readings
Power Draw : N/A
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Clocks
Graphics : 210 MHz
SM : 210 MHz
Memory : 405 MHz
Video : 555 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 2130 MHz
SM : 2130 MHz
Memory : 9751 MHz
Video : 1950 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : 0.000 mV
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Processes : None
Capabilities
EGM : disabled
