PC bought several years back, and possibly with OS not reinstalled cleanly, may mean some garbage laying around. Some options for you:
1. reinstall OS cleanly, or have it done for you ... this should probably be done every few years anyway just to clean out the deadwood. Implies backup of your data, reinstalling the apps you care about, etc.
2. go through your startup locations (start menu, task mgr, registry), and see if anything was left over from years before.
You can find loads of web pages to help you through #2, and specialized applications that will scan/clean the registry of all the deadwood.
May still need option #1, at some point ...
