Author Topic: PC power supply ...weight  (Read 3138 times)
Offline DimitriPTopic starter
« on: June 18, 2019, 02:18:26 am »
Two power supplies , both 80 Plus Gold 850 Watts:
One is 3.3x5.9x7.1 inches and weighs 112.9 ounces  (  EVGA GQ    210-GQ-0850-V1)  (5 Y warranty)
The other is 3.4x5.9x6.3  inches and weighs 58.5 ounces  (Corsair RMx   CP-9020180-NA) (10y warranty)
Maybe someone can shed some light into the weight difference and if actually means something ?
Offline KaneTW
Re: PC power supply ...weight
« Reply #1 on: June 18, 2019, 02:31:59 am »
Impossible to say without tearing it apart.
Online Psi
« Reply #2 on: June 18, 2019, 02:33:02 am »
Could be anything.
Fan speed vs heatsink size vs heatsink metal
One might have power factor correction which adds weight.
I would go with the 10y warranty one, if the company is that confident in the design then its probably very well built.
Offline mariush
« Reply #3 on: June 18, 2019, 02:49:25 am »
Kinda irrelevant
For example, one design may have the mosfets (chips that produce heat) on the back side of the circuit board using the whole case of the psu as heatsink, while the other design may use heatsinks on the top side...
The result is the same, a functioning power supply... just has the components cooled differently.
One may include the weight of the cables in the total weight , the other may not...
