Hi there!! I have a 2 TeraByte Ext HDD, on my laptop, where the 4 Port HUB that is powered by a barrel connector (I have o check the voltage - but it's probally not 5V USB).
In case of Mains power failure, if it was pluged directly into the laptop, it would probally be the best senario, as the laptop battery would provide the nessesary delay, and "Shut Down Procedure" the HDD needs to shut down properly.
But using a Hub, brings in other questions.
I'd say that, without going through buying a Mains Powered UPS, just a simple DC-DC converter, would provide the nessesary power, to allow the Laptop to send the signal to the Hub to shut-down, if the laptop shuts down before the Hub power.
To cut a long story short, "How do you send a signal to the Hub that the power is about to go, and shut down properly??"
Thanks Simon.
