Author Topic: Recommendations for Open Source hard drive backup software to external NAS.  (Read 4557 times)
Offline djsbTopic starter
I'd like to back up my laptops hard drive to an external Synology NAS over Ethernet. I've tried AOMEI Backupper, but it failed at 98%, and It's VERY slow (maybe intentionally so I'll buy an upgraded licence from the freeware I'm using). Can Clonezilla do this? Are there any open source solutions that can also encrypt everything at the same time. I'm using Windows 10. Thanks.
Hertfordshire,UK
University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor. Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. Credited Kicad French to English translator.
Online kripton2035
why not use the synology dedicated backup agent for almost any existing operating system ?
The following users thanked this post: djsb
Yes, I've seen a few apps on the web interface. I'll do a bit of research over the next few days on what's available and how to use it. I'll post here if there is anything I don't understand. Thanks.
Hertfordshire,UK
Offline Halcyon
  • Global Moderator
Bacula comes to mind, but it's not easy to set up and configure. Depends on your Linux skills. There is a Windows version too, but I haven't played with it.
« Last Edit: December 27, 2023, 11:27:28 pm by Halcyon »
Offline coromonadalix
sometime the Anti virus causes problems,  or you have in use / locked files  who are not well managed  ??  close everything,  no background processes  etc ... onedrive  ....
Online mk_
  • Country: at
Freefilesync with history if runnig windows on your laptops, but this is not Opsen Source
Urbackup runnning on a Linux-System with a client on Windows, don`t know if this is OS, but it`s doing fine here on some of my systems
of course restore was/is tested
But - I do only backup Data-partitions, not System and not Programs (don`t care about them, can be reinstalled within a really short time)
Online tunk
  • Country: no
Could microsoft's robocopy be an alternative?
Online nctnico
I have been using rsync for this purpose for many years. It's a simple command line tool you can run at set times to do a backup. AFAIK every modern day NAS supports rsync.
The following users thanked this post: djsb, jfb
Offline Traceless
I think kripton2035'S proposal is probably the best course of action. If you have trouble with/don't like the Synology solution, you could take a look at Duplicati as an alternative. If you were not using windows I'd suggest Borg Backup, which is my preferred solution.
Thanks for all the suggestions. I have to figure out a strategy for working out what I'm going to back up as a priority. Then I'll take it from there.
Hertfordshire,UK
Offline free_electron
    • SiliconValleyGarage
Re: Recommendations for Open Source hard drive backup software to external NAS.
« Reply #10 on: December 31, 2023, 09:23:00 pm »
ViceVersa by TGRMN software. i've been using that for 20+ years. has never failed me. https://www.tgrmn.com/
Offline 5U4GB
Does it have to be open source?  There's a freeware/shareware program for Windows called SyncBack that does a great job and is easy to use, it just runs in the background and takes care of things automatically.  The more fancy stuff is paid, but the basic version that'll probably do all you need is free.
Offline cncjerry
Owncloud, though not specifically a backup program, works fine.  You can keep.as many live copies on other synced computers and keep virtual files on others.  I have 5 or 6 laptops and desksides all synced.  Then on the server I use ZFS raid.  The advantage over backup software is the syncing is almost immediate. I've tried Bacula and it works, but it's tough to get the incremental working.  Bacula supports virtual tape and real tape if you p Lan to take a copy offside. Rysnc as others mentioned works well if you setup a chron job but adding the folder to owncloud is as easy as putting it in the owncloud directory and then adding it to the sync on other computers. Filehistory on windows and timemachine can both point to an external drive using afp or smb.  I don't know if there is an equivalentent for linux, other thN rsync with a chron job for automation.
The following users thanked this post: djsb, 5U4GB
