Products => Computers => Topic started by: geggi1 on March 13, 2023, 05:31:28 pm
Hi!
I'm looking for a reccomandation for a portable router with LTE / 4G /5G for the european frequency allocations.
The router must have the posibility for external antenna for wifi and also LTE / 4G /5G.
Can anybody give me a reccomandation for something that is in a portable size, internal battery is not required.?
The Netgear Nighthawk M5 are pretty decent. They also come in 4G/LTE flavours if you don't particularly need 5G.
Has a removable battery pack, ports for external antennas, Gigabit ethernet port + 802.11ax Wi-Fi.
https://www.netgear.com/home/mobile-wifi/hotspots/mr5200/ (https://www.netgear.com/home/mobile-wifi/hotspots/mr5200/)
Its missing external antennas on the 4G
I'm not entirely sure what you mean by this? Both external antenna ports are used for all supported bands. The optional Netgear antenna is tuned for bands between 600-960 and 1710-5925 MHz. Or, you could supply your own.
This is the datasheet for it: https://www.downloads.netgear.com/files/GDC/mobile-wifi/MIMO_Antenna_DS.pdf (https://www.downloads.netgear.com/files/GDC/mobile-wifi/MIMO_Antenna_DS.pdf)
I have a router that is kind of portable and seems reliable but not pocket size and might be a bit too big for your requirements and one problem with it is that it is a Huawei and it's 4G only ar 150mbps.
Hauwei E-5172
https://www.amazon.co.uk/Huawei-E5172As-22-150Mbps-Unlocked-Wireless/dp/B00GHK3XOC (https://www.amazon.co.uk/Huawei-E5172As-22-150Mbps-Unlocked-Wireless/dp/B00GHK3XOC)
It has room for a built in battery backup battery but I have one firmware that disables most of the functions but the mobile and phone adapter and the other leaves everything on. I carry one around with a 12v powerbank on the back.
It has:
12v 1a input
Battery compartment for 3x aa NiMH battery pack.
100mb ethernet port.
Wifi N
Internal aerial and 1 x external sma plug, set to auto and can be selectable in built in webserver.)
Analogue phone converter (auto switches to 3g on my mobile service.)
I got a couple from Portugal much less than that on Amazon for about £40 each in 2018 and I am using one as a backup for my broadband and VOIP converter.
I used it in a chicken barn in 2018 in a farm in the middle of nowhere and the signal was a lot better than this EE pocket WIFI thing I had and even outside.
