The company "Geekworm" has an interesting toy for RPI: the C779!
It's a "camera serial interface(1)" version2, aka "CSI-2" Module with Toshiba TC358743XBG chip that accepts
HDMI input up to 1080p@25fps and allows RPI(2) to capture and record videos though the v4l2-ctl console tool.
Any experience?
(1) The Camera Serial Interface (CSI) is a specification of the Mobile Industry Processor Interface (MIPI) Alliance. It defines an interface between a camera and a host processor. The latest active interface specification is CSI-3 which was released in 2012.
Different Standards of MIPI CSI Interface:
- MIPI CSI-1 was the original standard MIPI interface for cameras. It emerged as an architecture to define the interface between a camera and a host processor.
- MIPI CSI-2 released in 2005. It uses either D-PHY or C-PHY (Both standards are set by the MIPI Alliance) as a physical layer option. The protocol is divided into the following layers:
1. Physical Layer (C-PHY/D-PHY)
2. Lane Merger Layer.
3. Low Level Protocol Layer.
4. Pixel to Byte Conversion Layer
5. Application Layer
Features:
PHY variants supported: D-PHY 1.2, C-PHY 1.0 or "Combo PHY"
Number of Virtual Channels: Four (4)
Control Interface: I2C
Line based transmission (Easy implementation, low gate count, matched data rates for sensor and link)
Interrupt type: In-Band
Supports { RGB, RAW, YUV, JPEG }
Embedded Data
CRC/ECC for payload & Header Protection
- MIPI CSI-3 is a high-speed, bidirectional protocol primarily intended for image and video transmission between cameras and hosts within a multi-layered, peer-to-peer, UniPro-based M-PHY device network. Originally released in 2012, got re-released in version 1.1 in 2014.
(2) compatible with: Raspberry Pi { 4B, 3B+, 3B, 3A+, 2B, 2B+, Pi Zero , Zero W }
