Products => Computers => Topic started by: BeBuLamar on May 14, 2022, 01:50:34 pm
Title: selfextracting Zip file
Post by: BeBuLamar on May 14, 2022, 01:50:34 pm
I have a problem last night that I downloaded the Flukeview Forms update from Fluke. It's an *.exe file that is self extracting. Running the file it shows that it extracting and then run a setup problem for a different software altogether. It took me a few hours to figure out what it was. I run the file in the downloads folder which has many setup.exe files so it would run whatever setup file it found. I moved the file to an emply folder and it works fine.
