Author Topic: Which Intel CPU not affect by recent issue  (Read 2799 times)
Offline Wilson__Topic starter
« on: January 25, 2025, 09:16:19 pm »
With BIOS updated to microcode version 0x12B, is it now safe to buy Intel Core i5-14500 because it is not on the issue list.
https://www.intel.com/content/www/us/en/support/articles/000024255/processors.html
Offline brucehoult
Re: Which Intel CPU not affect by recent issue
« Reply #1 on: January 26, 2025, 04:31:56 am »
With a maximum turbo of only 5.0 GHz I doubt there was ever any problem with i5-14500 in the first place.
I think the problems only started somewhere north of 5.5 GHz -- and limiting the maximum boost to around that prevented damage if you hadn't already damaged your chip.
The following users thanked this post: Wilson__
« Reply #2 on: January 26, 2025, 01:58:54 pm »
Is the issue triggered by high CPU heating?
I shall be buying new CPU from well-known seller.  For 'preventive view', may be I can set fan speed curve to ramp up fan speed at lower temperature to keep CPU cooler than 60 to 70 Celsius?
Offline exe
  • self-educated hobbyist
« Reply #3 on: January 26, 2025, 02:33:39 pm »
I think the original issue was with overvoltage and overstress of internal circuitry. So, temperature won't help with that. May be the opposite, the cooler the CPU, the faster it may decide to work)
Offline brucehoult
« Reply #4 on: January 26, 2025, 03:38:36 pm »
No, it's not the temperature. Running them at up to 100 C is no problem at all.
The problem is that the voltage settings for the highest turbo speeds were set incorrectly from the factory, and were causing something like sparks or burnout at the microscopic level.
There are lower voltages that are safe but are still sufficient for those highest clock speeds, and updated chips use those voltages.
Offline KE5FX
    • KE5FX.COM
« Reply #5 on: January 26, 2025, 05:20:02 pm »
All Raptor Lake systems have BIOS patches available at this point, AFAIK, so they are OK if they've been updated.
The real problem is that any degradation that occurred prior to the BIOS update is permanent.  So while there is no reason to avoid new CPUs, existing ones may end up with curtailed operating lifetimes.  I have a 13900k that couldn't run y-cruncher for more than an hour or so, and that's still the case after upgrading. :(
« Reply #6 on: January 26, 2025, 08:20:52 pm »
Sorry to hear that.  Intel press releases were toned toward making replacement easy.  Hope it works out for your damaged CPU.
Does the CPU work fine until temperature gradually rising up after one hour?
Offline KE5FX
    • KE5FX.COM
« Reply #7 on: January 27, 2025, 12:55:39 am »
I haven't noticed any correlation with temperature, really.  I'll replace it at some point, but it's not my main system so not urgent.
