Author Topic: Strange sound problem  (Read 1178 times)
Offline rdlTopic starter
« on: April 18, 2023, 04:38:11 pm »
I put MX Linux on a used computer I bought recently and just noticed an odd problem. Using a DisplayPort to HDMI cable, all the sound is going to the left channel. The headphone jack is working normally. I'm thinking it's some kind of software issue. Any other ideas on what could be causing this?
Re: Strange sound problem
« Reply #1 on: April 23, 2023, 04:45:24 am »
Okay, I figured this out and it was kind of stupid. I checked on my Lenovo running Debian 10 and the sound was set to "HDMI/DisplayPort Built-in Audio" and I noticed on the HP it was set to "Analog Stereo Out".
Hiding out to the right in the Pulseaudio window, past the border where it wasn't visible, was one more tab for "Configuration". There was a small arrow thingy that I just hadn't noticed, but geez. Seriously the window isn't that big, why not make it so all 5 tabs are in view by default?
Anyway, on that tab was a listing for many output devices (most of which were unavailable), setting it to "Digital Stereo (HDMI) Out" fixed the problem. Not sure why "Analog Stereo Out" wasn't giving stereo out, or rather both channels to the left side, but I'm not gonna worry about that now.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #2 on: April 23, 2023, 05:40:50 am »
Glad you got it sorted.
Who knows.
There should be an arrow at either end of the tabs that appears when the window isn't wide enough to shall all the tabs. The arrows allow you to shift the tabs left and right.
iratus parum formica
