Author Topic: Perils of USB-C  (Read 1227 times)
Offline ZbigTopic starter
Perils of USB-C
« on: September 19, 2019, 01:14:01 pm »
I apologize for the click-baity title but, as you'll find out, it's for the greater good :) Turns out, while trying to blindly mate (I's sounds kinda weird when you say it out loud) a USB-C plug with its socket and there's a USB-A port nearby, it's very much possible to insert the USB-C plug into the USB-A socket. Just enough for it to short the USB-A power to ground with its outer shielding... All that without using unreasonable force (© bigclivedotcom). Ask me how I found out... ::)
Online SiliconWizard
Re: Perils of USB-C
« Reply #1 on: September 19, 2019, 03:16:46 pm »
You could also insert a screwdriver inside a mains plug and get shocked... :P
Some mating configurations are best avoided in general. :-DD
Offline FreddieChopin
  • Country: ua
Re: Perils of USB-C
« Reply #2 on: September 21, 2019, 04:11:04 pm »
If youre using only USB-C devices then maybe you could 3D print USB 2.0 disabler plug? This way you won't fry your USB ports anymore.
https://www.thingiverse.com/thing:1037467
Offline soldar
Re: Perils of USB-C
« Reply #3 on: September 22, 2019, 04:48:40 pm »
Doing things "blindly" is a stupid way to go through life and results in occasional disasters.
In this case one possible solution would be to install an A to C adapter permanently; just leave it plugged in.
