Author Topic: TEG generator at CPU heatsink  (Read 515 times)
Offline msuffidyTopic starter
« on: August 19, 2022, 12:33:07 pm »
Would it help if you could somehow extract TEG power from a cpu at the cooling solution?
Offline golden_labels
Re: TEG generator at CPU heatsink
« Reply #1 on: August 19, 2022, 07:15:04 pm »
The goal of cooling is to minimize temperature difference between the hot and the cold side.
TEG requires maximizing temperature difference between the hot and the cold side.
Do you see the problem?
People imagine AI as T1000. What we got so far is glorified T9.
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: August 20, 2022, 01:24:03 pm »
There was the idea to build datacenters in really cold places to not only save on cooling costs but also to run a heat engine to supply some of the power.
