I like the concept of E-Readers but they seem pretty useless for PDF's like datasheets and things like technical documents with detailed illustrations mostly because of the limited resolution, lack of colour and the obvious super slow nature of e-paper.
QUESTION: I'm thinking of buying an inexpensive 8" or bigger tablet. It doesn't need to be anything fancy and I see that the Amazon Kindle Fire HD tablets are very affordable BUT they don't use the Google Play store, just the Amazon store. People have been hacking them to work with Google Play so that would be an option I wouldn't mind trying considering these things are only around $90.
Would people consider this a good option for a datasheet, technical document, PDF tutorial/instruction and course material reader to replace printing out stuff on paper?
I almost never use paper anymore and I would like to sometimes be able to have documents on a separate portable device.
I use both Kindle Paperwhite and Amazon FireHD 10" Tablet (latest version). For color, PDF or where exact formatting is required I use the Amazon FireHD 10" Tablet as my go to reader using MoonReader Pro (paid version -- I bought most of the ereaders on Android but I tend to use that one out of all I bought the most often). For Novel format (e-ink readers are just really simple web browsers at heart and just write text to the screen with image support and some rudimentary formatting options.
There is no real hacking on Amazon tablets, the latest ones you just use the Android Debug Bridge, ADB like you do with all android devices and you just write/update a setting on the tablet and boom now you have modified its behavior such as toggle on or off ads or other features like turn off automatic software updates. There is a full text gui menu system front end called FireControl that will automate all this stuff for you, it couldn't be easier. It can even install Google Play and Support files for you so you can have both access to the Amazon app store and access to the Google Play store at the same time.
When reading PDFs the display on the tablet of course is much brighter than the low brightness I can set the Kindle e-ink display to. So if you want to read in bed its so much more comfortable on your eyes to do it on an e-ink display. But if you are reading in the daytime the Tablet screen is less annoyingly bright.
I've got both my devices fully modded and tuned up. And for the desktop PC I recommend Calibre as the super store of all you books and swiss army knife to convert between formats on the fly, deal with encryption, etc. etc.
