Author Topic: Turning on a server PSU Delta DPS-1200AB-4  (Read 1306 times)
Offline AmmoJammoTopic starter
« on: September 11, 2022, 11:44:19 pm »
I purchased two of these, have attempted to test one, but failed to get it to turn on.
(see attached datasheets) 550w is the same pinout as the 1200w.
I have pulled A21 (PSON) low (connected to the negative output?), I have tried connecting A24 (+12VRS) to the positive output and A23 (RETURN_S) to the negative output.
I've also tried pulling B29 (A0) low, as I thought that may have been needed to address it as PSU1... but nothing!
Ideas?
Thanks!
Online coromonadalix
Re: Turning on a server PSU Delta DPS-1200AB-4
« Reply #1 on: September 12, 2022, 11:41:47 pm »
try at rcgroups ?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: September 13, 2022, 06:53:52 am »
https://www.rcgroups.com/forums/showthread.php?1621433-Delta-DPS-1001AB-1-48V-700w-1000w-Delta-DPS-1500AB-A-Full-Pinout it seems so simple, just ps_kill and ps_on to gnd.. my $15 each Dell 750W PS-2751-5Q requires soldering resistors.
« Reply #3 on: September 22, 2022, 10:27:55 pm »
