Someone didn't bother to do anything before knee-jerking to sound superior. And, well, pot and kettle considering our last discussion..
I have to disagree, but rather than ping-ponging needlessly, I'll let you do your own reading.
Do you realise AMD processors aren't immune to many of these publicised vulnerabilities either?
I actually work in cyber security and I have not come across a single instance (outside a lab environment) where things like Spectre or Meltdown have been exploited, largely due to the complexity involved and level of access needed.
At least Intel have been responsive to provide patches and mitigations, AMD, not so much.
Since you're working in cyber security I wonder why so many "experts" don't consider the severity and real-life threat possibility of vulnerabilities. It's not simply black or white. In the AMD vs. Intel debate I'd say that the CPU vulnerabilities found in the last few years suggest a much greater threat level for Intel CPUs. And the microcode updates and OS workarounds aren't for free, they come with performance penalties (not so much for typical desktops).
Because the threat in real-world cases is negligible. The biggest challenge is getting physical access to the machine and even then, you need certain privileges.
Consider a data centre or some other protected environment. A threat actor, even if they are internal, aren't going to get anywhere near those machines without being noticed. If someone can just waltz in, you have much bigger issues such as physical security.
As I said, it just hasn't been exploited out there "in the wild". I'm not saying it won't ever happen, it just hasn't yet.
