Looking for a reliable brand, robust, torn down, tested, reviewed for safety/compliant etc.
It's for a mix of devices but some of them are fast charging so at least 2 ports fast charging USB C. 4 ports total or a couple of 2 ports will be enough. Need also a cable brand that have been tested (data/power etc) to the latest USB C standard with good plastics/connectors.
Any good place to start, brand names, channel/videos? I figure some of you have been all over this a few times before, please share experiences/research.
I have a Ugreen Nexode 65W charger. It has 2 USB C PD outlets aND 2 usb 2 outlets (purple, whatever that means).
I can't point to a teardown but Ugreen seem generally of good quality - I have a few of their other products too.
I looked for it on Amazon and it appears to have been replaced by 100W, 165W and 200W models with up to 6 ports.
I've been going with Anker or Monoprice lately.
Thanks for the suggestions, I'm going with a couple of Ikea chargers. I don't tend to buy from Ikea but their Ladda 2450mAh NiMH batteries (Japanese) were a bargain on sale. So there are a few gems amongst the cardboard/plastic.
The single port Smahagel has no rating on their website but seems 5W. The 3 port model is 12W max per port (17W total). Probably give the Sjoss USB C models a try as well, they look well constructed.
