Author Topic: NLX (motherboard) Specification  (Read 3004 times)
Online squadchannelTopic starter
  • Country: jp
  • deepl translate user
« on: September 05, 2024, 01:51:10 pm »
I got this specification data when I used to tinker with the Tek TDS7000.
I thought I wayback machine the official Intel site, but I forgot.
If it helps, here you go. :-+
mod:
I checked and it was crawling on xdevs. Oh well.  :popcorn:
« Last Edit: September 05, 2024, 01:54:55 pm by squadchannel »
The following users thanked this post: coromonadalix
Online coromonadalix
Re: NLX (motherboard) Specification
« Reply #1 on: September 05, 2024, 04:59:12 pm »
340 pins of fun,  i myself checked theses too,  unless someone design and an adapter board to fit more modern pci boards ... ??
I think the scope power pc interface do use the pci section of the nlx interface ...
I have an Intel Getway 3400   Nlx 815 motherboard that i tested on a 7404  loll   no luck, must miss a voltage or something else, the scope power led become red
but will take all the space up to the front scope plate ... it is way bigger in size, i saw no other 815 Nlx boards ...
would need to poke ...  but this scope is not mine :(
« Last Edit: September 05, 2024, 05:03:23 pm by coromonadalix »
