Hi everyone,
this may be more of a tech support question, but i am currently more interested in possible causes for the issue i am outlining below.
Shortly before Christmas, i wanted to "re-home" my current PC into another case.
Relevant hardware details:
Mainboard: AsRock x99 Extreme 4
GPU: Palit GTX 1080
PSU: BeQuiet Straight Power 10
Various SATA Devices: two optical drives, 2 spinning rust drives and 2 SSDs
Old Case: Aerocool DS 200
New Case: Fractal Design Define 7
Ordinarily, doing something like this is, while time consuming, should be a routine task. So i went ahead and fully disassembled the PC (I did not remove the CPU, RAM and NVMe boot drive)
and then started with Board and GPU in the new case. First boot attempt to see if it still turns on was successful, i got an image, but i could not boot. Knowing that the board has had issues with loosing the bootorder before, i went ahead and popped the BIOS battery out to fully reset the BIOS.
That was the point the issue started.
With removed battery, i reconnected the power, and tried turning it on again. No dice. Dead as a dodo, no LED, not even a twitch on any fan.
Anything i did afterwards hat no effect at all:
- putting the battery back
- removing everything except the CPU
- shorting the powerswitch contacts on the board to exclude a dead switch
- jumpered to the secondary BIOS
- "proper" BIOS reset with jumper to "Clear CMOS"
Nothing helped, the system was in all effects dead. I have to admit, i did not check voltages, except of the battery, which is still good.
Next, i removed the board from the case and repeated all tests. Still dead.
I then tried an old PSU that should still be good. Dead, even without the GPU inserted.
I essentially did everything i could think of, short of removing the CPU (i have currently no thermal compound on hand) and jumpstarting the PSU.
The kicker though: As a last act of desperation, i put everything back into the original case. And on the first effin try, the thing booted back up as if nothing has happened. That was now more than two weeks ago, and the PC still runs rock solid back in it's old case.
While the system is running now, i still have absolutly not idea *why* the rehoming failed so spectacularly.
I double and tripple checked the mainboard standoffs in the new case, to make absolutely sure that i had them at the correct locations, before the first power up. I checked them again after the power issue started. There is only one difference: one of the standoffs in the new case is not for a screw, but is a small stud fitting into the hole on the mainboard. A neat idea, since if you have a large CPU cooler mounted, that mounting hole can become inaccessible. The stud fits exactly into the mainboard mounting hole. I would think that a short caused by a incorrectly mounted standoff would cause permanent damage anyway.
But could the lack of a screw at that point have caused the issue? Something caused by the lack of a solid ground/common connection at that location?
I also know of the reports of AsRock boards dieing when the power is removed. But that are other series, and when not in use, my PC is fully turned off every day via a switchable power strip, and never showed any power issues in the four years i now have it. And the system is now running again.
Currently i am reluctant to do more tests and repeat the whole procedure. Spareparts are expensive for that socket, and adequate new parts are still very expensive due to various shortages. But i still can't stop thinking about this. The PC will go as a gift to my nephew as soon as i have new parts, but i'm afraid of lingering issues.
TL;DR: What could be the reason why a PC runs in one case, but not in an other?
