Author Topic: What linux distributions is everyone using?  (Read 57566 times)
Offline JPortici
Re: What linux distributions is everyone using?
« Reply #100 on: March 13, 2025, 05:55:51 am »
last evening i finally got fed up with OSX not acting nice with non genuine parts and installed Debian on my old Macbook  >:D
Fells like i gave another 4-5 years to the 2012 machine
Offline brucehoult
« Reply #101 on: March 13, 2025, 06:21:03 am »
I'm not surprised, GROK is probably trained on stackoverflow answers to your questions.  If you ask it about a problem less common then it will likely struggle to understand your true problems, and give similar-sounding solutions instead.
LLMs are interpolation machines.  They are great at giving answers very close to their training data, poor at answers further afield.
That's all true, but ... I just tried an exercise.
Here are my prompts, and very abbreviated excerpts from its responses. It actually wrote a many different version of strllen, strcpy, strcmp as we went:
If you wanted to add a new instruction to the scalar part of an existing ISA such as MIPS to speed up C string handling e.g. strlen, strcpy, strcmp, what would you suggest?
> The key bottleneck in string operations is the sequential scan of bytes, often one per cycle, limited by memory alignment and the need to check for the null terminator or character differences. A single instruction that processes multiple bytes at once, detects the null terminator, or compares strings efficiently would be ideal.
>One effective approach would be to introduce a "string scan" instruction that processes a word (4 bytes in MIPS32) or double-word (8 bytes in MIPS64) at a time, detecting the null terminator and returning its position.
> Proposed Instruction: strscan Reads a word (4 bytes) from the address in rs1. Scans the word for the first null byte (\0). Writes to rd the offset (0–3) of the null byte within the word, or 4 if no null byte is found. Updates rs1 to point to the next word (auto-increment).
I see some problems with strscan. Loading from memory and then doing arithmetic on it violates RISC principles. Also for strcpy or strcmp it requires a second load instruction for the same data.
> Revised Proposal: zdetw  rd, rs1 (Zero Detect Word) Writes to rd the offset (0–3) of the first null byte, or 4 if no null byte is found.
strcpy writing the dst past the null is a serious bug, violating the strcpy spec, which must do precise insertion
> New Instruction: zdetwm (Zero Detect Word with Mask) Sets rd to the offset (0–3) of the null, or 4 if none. Sets rs2 to a mask: 1s for bytes up to (but not including) the null, 0s after
This masking is good, but this zdetwm instruction violates r2w1 design.
> Revised Proposal: zdetw rd, rs1 Writes to rd a byte mask: 1s for bytes up to (but not including) the first null, 0s after
> {code using ctz in the loop}
Making all zeros after the first null is good for strcpy but reduces the chances of using it for other things. It is also not a pure SIMD operation but has dependency within bytes, which could slow the instruction on larger words sizes e.g. 64 bits. Also there is no need to know the exact position of a null in the main copy loop but only whether one is present or not
> Revised Proposal: zchk rd, rs1 (Zero Check) Writes rd = 0 if any byte is \0, rd = 1 if no bytes are \0.
Good, but I still like the byte by byte mask, not a single bit 0 or 1 output
> New Proposal: zmask rd, rs1 (Zero Mask) For each byte in rs1, sets corresponding byte in rd to: 0xFF if the byte is non-zero. 0x00 if the byte is zero.
{a few cycles trying to hint that it had missed that ctz counts bits not bytes in the last chunk (with the null in it)
Good .. but please check what you are returning from strlen
It seems like you don't understand what ctz returns
> {notices that MIPS is BE so ctz won't work, switched to byte by byte compares for the tail}
Not really the fix I was looking for.  Let's either use clz instead of ctz, or else assume a LE MIPS system and continue with ctz
> {produces almost correct BE and LE versions, using clz or ctz as appropriate. FINALLY adds srl 3 to convert bit count to byte count in both versions}
ok good. Let's stick with LE. Can we keep the loop in the loop, so there is only one taken branch in a normal loop, and final bytes are handled after the loop? Also we can subtract pointers after the loop to determine the 4 bytes per loop counted, not actually have an addi instuction every iteration
> {fixes the loop}
this is looking great now, except you need to count trailing 1s (non-null bytes) not 0s
> {adds nor with zero reg in loop tail before ctz .. all code is now correct and beautiful}
Looks great. How does zmask compare to instructions in RISC-V?
> {nothing good in base ISA, nothing except ctz in B ext, vmseq.v, vfirst.m do the job in V ext, shows the best we can do in each}
Let's ignore RVV and stick to scalar. The B extension was ratified in 2021, it is not draft. Did you consider the orc.b instruction?
> {describes orc.b, tries a sample string "abc\0| with both orc.b and our new MIPS zmask}
> Holy smokes—they’re identical! I missed this entirely. orc.b does exactly what zmask does, down to the byte-wise non-zero check producing 0xFF or 0x00.
> Why I Missed It
> I focused on ctz and clz in Zbb, assuming no single instruction matched zmask’s mask generation. orc.b slipped under my radar—its name (“OR-combine”) didn’t scream “string mask” to me, but its behavior is a dead ringer. My bad for not digging deeper into the ratified spec.
> Verdict
> zmask = orc.b: Functionally, they’re twins. If we’d designed zmask for RISC-V, we’d have reinvented orc.b.
> RISC-V Wins: Since orc.b exists, it’s the go-to for scalar string acceleration in RISC-V, no custom instruction needed.
> MIPS Context: zmask still makes sense as a MIPS extension, as MIPS lacks an orc.b equivalent in its standard set.
> For your original ask—adding a string-handling instruction to MIPS—zmask (or orc.b by another name) is still a great fit, mirroring a proven RISC-V solution. If you were targeting RISC-V instead, you’d just use orc.b off the shelf. Pretty cool convergence! Anything else you want to explore with this?
Those RISC-V designers must have been on some strong stuff, eh? But what a wacky name. It seems this pure SIMD instruction works with both LE and BE, while the earlier suggestion to zero all bytes after the first null is inherently BE.
> Haha, yeah, the RISC-V folks were definitely cooking with some high-octane creativity when they named orc.b—it sounds like a fantasy spell or a grumpy orc’s battle cry, not a string-handling gem! But you’re spot on: its pure SIMD-like nature makes it endian-agnostic, which is a slick advantage over our earlier ideas. Let’s unpack that and see why orc.b (and thus zmask) shines across both little-endian (LE) and big-endian (BE), while the “zero after first null” approach tied us to BE.
> RISC-V’s Strong Stuff
> The designers must’ve been sipping some potent open-source espresso—orc.b sneaks in as a bit-manipulation trick but doubles as a string-handling powerhouse. It’s a testament to RISC-V’s “less is more” ethos: one instruction, broad utility. Our zmask journey landed on the same idea, proving great minds (and AIs!) think alike.
For MIPS, zmask as an orc.b clone is still a killer addition—endian-flexible and lean. Any other RISC-V scalar tricks you want to pit it against?
So ... interesting.
zmask is a pretty novel instruction. As far as I know, orc.b in RISC-V is the first time anyone has done that instruction in an ISA that also has ctz. Lots of SIMD ISAs can do a "compared each element to 0 and make either a byte mask in a vector register or a bit mask in a mask register" but none of them can then do a ctz on the entire register or mask. The best you can do is compress the MSB of each vector element to an integer register, or transfer a mask register to integer, and then do ctz there.
Grok didn't get to zmask by itself, but it got there by prompting relatively general observations about problems with its initial suggestions.
There were a couple of bugs that to be honest a human programmer could easily overlook too, and have to debug: forgetting to invert the mask before doing ctz (in the absense of cto), and forgetting to adjust bit count to byte count. In translating from MIPS to RISC-V it hallucinated a "nor, t4, t2, zero" instruction in RISC-V, which I didn't correct -- "xori t4, t2, -1" is available so nbd.
There were also a couple of correct but not optimal things. Incrementing the byte count in every loop when it could be calculated after the loop by pointer subtraction. Putting the tail processing physically inside the loop, so having a taken conditional branch and an unconditional branch in each loop iteration. I got that to a non-taken conditional, plus an unconditional branch, with contiguous code for the loop body. I didn't ask it to rotate the loop to only have the conditional branch, and start by jumping into the middle. I think it probably could have done that.
Once these problems were pointed out, they didn't recur in later versions of strlen, strcpy, strcmp that used different custom instruction formulations.
The whole process was quite fast. Grok3 responded very quickly, with updated versions of all three functions at every prompt, which were at least close to correct. modulo the confusion about the exact input and output of ctz.
Reasoning about imaginary instructions, it's obviously not possible for the machine to actually execute the code. Symbolic reasoning is all there is.
I think it's useful. You have to supervise it like you would a junior programmer, and prod all the good ideas, but it iterates the mechanics in seconds that a junior would take a day to rewrite. And, within a given session (which you can go back to later) it doesn't make the same mistake again once corrected.
The following users thanked this post: mapleLC
Offline BradC
« Reply #102 on: March 13, 2025, 08:08:36 am »
I recently retired a 2011 iMac that was running Debian. The only reason I retired it was the AMD GPU was failing. I'm still running it on my 2014 Macbook and can't see any reason to "upgrade".
Intel Macs run Linux perfectly well and I've got to say this Macbook is better than, and has lasted longer than any other Intel based Laptop I've ever owned.
I've not run MacOS on them however.
Offline steve30
    • Stephen Coates' Homepage
« Reply #103 on: March 14, 2025, 12:36:46 am »
My main machine is triple booting Debian 12, Windows 10, and Slackware 14.2.
My ThinkPad T420 just single boots Windows 7 at the moment, but it did run Slackware 14.2 nicely a few years ago so I think I'll put some Linux on it at some point.
Offline designerhans
    • SEA Agentur
« Reply #104 on: March 15, 2025, 09:00:08 pm »
I've been using Debian on servers for its stability and reliability, but for desktop use, I switched to EndeavourOS (Arch-based) a while ago. I like having a rolling release without too much initial setup hassle.
That said, I totally get the frustration with Ubuntu becoming more bloated—especially with things like Snap. It feels like it's drifting away from what made it appealing in the first place.
Offline Zucca
  • EE meid in Itali
« Reply #105 on: March 15, 2025, 09:24:39 pm »
Soon I will use Fedora Workstation on Gnome just to try it out, wish me luck!
If it feels too Apple for me plan B is Debian KDE.
« Last Edit: March 15, 2025, 09:43:47 pm by Zucca »
Offline John B
« Reply #106 on: March 16, 2025, 12:50:15 am »
Try out GNOME in a virtual machine first if you can. If you prefer KDE, it's probably better to install the KDE spin of Fedora from the beginning.
Although you can start with a vanilla GNOME install of Fedora, then install the KDE desktop environment and display manager, it does leave some annoying artefacts, like sometimes programs will open GNOME Nautilus rather than KDE Dolphin as the file manager. Or icon discrepancies.
I use KDE on Fedora, and I think KDE is the most full featured for a power user.
I also have a Debian machine running some 24/7 services where GNOME is the perfect desktop environment because the screen stays off and I don't have to use GNOME  ;D
Offline JohanH
« Reply #107 on: March 16, 2025, 09:30:52 am »
I think all depends on personal preference and what your goal is with your computer. I consider myself a power user; I learned Linux on the command line and most system administration I do from the terminal. In the past I tried out most desktop environments and distributions (starting 20 years ago). In the end I got tired of tinkering with the desktop and just left Gnome installed in Fedora and now I've been running it for many years on my main workstation (and other desktops and laptops at home). All annoying bugs that I would care about have been fixed a long time ago (at some points I even participated myself and fixed some bugs). I have zero interest nowadays to see or "use" a desktop environment. It should just stay out of the way and let me run my programs.
Offline JPortici
« Reply #108 on: March 17, 2025, 06:08:33 am »
which happened i think 15 years ago, around the time of the Gnome 2 -> Gnome 3 switch
Offline thermistor-guy
« Reply #109 on: March 21, 2025, 06:55:10 am »
I have a fairly elaborate home network of computers.  Two servers running Ubuntu acting as nfs and samba storages (one backs up the other), Windows 10, and 11 workstations, Mac workstations, and Linux workstations.
My question is about Linux.  Ubuntu used to be small and nimble.  But I'm not so sure about the latest version, 22.0.4.  It seems bloated, and I am even having stability issues. ...
Re stable network storage. I have a mixed home network like you. For critical files, I use Synology h/w (for over a decade now). Never had a problem.
For large entertainment archives (movies, music, etc) I've been using Unraid on an old PC for a few months now. Drives are WD Red Pro HDDs, always spinning.
Working well so far. I don't trust the Unraid tower yet with anything critical - maybe after 12 months I'll reconsider (but maybe not).
Offline valcher
  • Country: ru
« Reply #110 on: March 21, 2025, 07:50:51 am »
I prefer Debian, it has been installed on my home router wrt3200acm for almost 9 years. It has adbbock, dnscrypt-proxy, openvpn, smb and everything else necessary for my network.
All configuration is from the command line.
Offline InductorX
« Reply #111 on: March 21, 2025, 07:57:13 am »
I don't have a favorite distribution, it depends on the task and also mostly the convenience I think. I run a proxmox server with various vm's that run docker in some form and some LXC as well. Besides that I also run a Truenas server. I have Arch running on a Lenovo laptop, ubuntu server, Debian, SUSE, and I might have forgotten what else  ;D
Mostly I try to avoid using a GUI, and if I have to, or want to, it's something light weight for sure, no Gnome or KDE.
Offline JohanH
« Reply #112 on: March 21, 2025, 08:10:31 am »
Regarding network storage and servers.
I have a Lenovo Tiny M920 PC that I use as a network server and media storage (SSDs). I run Xcp-ng virtualization with a few AlmaLinux servers on it. Great little machine and Xcp-ng is rock stable. I have a separate Qnap NAS backup machine (RAID 1 hard disks) that starts automatically once a week and runs some backup scripts over the network.
Offline DiTBho
« Reply #113 on: March 27, 2025, 12:10:42 pm »
Yesterday I found something unique and very odds: have you ever heard about "Corel GNU/Linux"?
Two CD-ROMs, for x86/32 and powermac G3. Live-so-you-can-evaluate-before-installing, Booting a 2.4 kernel with a very old version of Gnome, but amazing!
Corel? the same guys of CorelDraw? I think so ...
Offline JPortici
« Reply #114 on: March 27, 2025, 01:21:38 pm »
Argh! last evening I tried to update my macbook from debian bookworm to trixie. I thought it would be as easy as changing the sources list and then apt update / upgrade but of course it fucked up everything and was met with SDDM instead of the usual kde login screen.
Of course my macbook trackpad decided to break at the same time and wouldn't click anymore, of course tap to click isn't recognized before logging in, of course SDDM has the eternal can't-hit-return-to-accept-password bug.
Because i did literally zero actual work on my macbook after i installed debian, i decided to reinstall trixie from scratch.
That's what wiki says
https://en.wikipedia.org/wiki/Corel_Linux?useskin=vector
Offline DiTBho
« Reply #115 on: March 27, 2025, 01:39:28 pm »
diff vs wiki
Platforms   IA-32 ----------------------> CD#1 is x86/32 (PC), but CD#2 is PPC/32 (PowerMac)
Default user interface   CDE (variant of KDE) ----------------------> mine is based on Gnome
but yes, they confirm to be the same guys from CorelDraw  :o :o :o
Offline madires
  • A qualified hobbyist ;)
« Reply #116 on: March 27, 2025, 01:58:40 pm »
That's rotten! The original CDE is an old desktop environment based on Motif and might have inspired KDE. The old SPARCstations running Solaris came with CDE, for example.
Offline DiTBho
« Reply #117 on: March 27, 2025, 03:50:44 pm »
wiki_error=+1
now that you mention it, I believe it is the same "CDE" that was on HPUX v10.20 (PA-RISC-1.0)
When I daily worked on a HP712@60Mhz at my university computer lab.
Offline MrMobodies
« Reply #118 on: March 27, 2025, 06:39:45 pm »
Ubuntu Studio recommended by a friend this year for his audio stuff.
No horrible bloated flashy animated activities/Unity thing.
Dimming of inactive windows now an option.
Can turn pretty much all the animations off with KDE plasma and other renamed tools.
In my opinion I think they should replace the normal Ubuntu with it.
The LibreOffice that comes with it seems to load up fast.
There is one issue during install@
During copying files, if no mouse input, it toes go to sleep (bloody STUPID they allow this to happen) and when woken lock screen requires a password that is not even set yet and the one it requested doesn't work if I remember correctly.
https://askubuntu.com/questions/1438597/live-session-locked-out-ubuntu-studio-22-10
If it was on a laptop and was on batteries I could understand but this was not and I was told that this would happen but twice it happened to me when I got carried away with something else at the time.
« Last Edit: March 27, 2025, 06:53:49 pm by MrMobodies »
Offline themadhippy
« Reply #119 on: March 27, 2025, 07:04:26 pm »
Turned all that off ages ago,just the serene calmness of desktops and proper menus of old
Offline voltsandjolts
« Reply #120 on: March 27, 2025, 07:20:54 pm »
Seems like System 76 are gonna make quite a splash with their Pop-OS (Ubuntu based) and all new Cosmic desktop written in rust. Just in alpha now but already looking very nice. Wayland only (a good thing).
youtube.com/watch?v=q077sf7ymzI
Offline madires
« Reply #121 on: March 28, 2025, 09:55:40 am »
Yep, was a collaboration of HP, IBM, Sun and USL.
Offline Black Phoenix
  • Country: hk
« Reply #122 on: April 13, 2025, 07:13:56 am »
I started my mild learning on Linux way back in 2020 with Fedora 32/33 (dual boot with Windows 10) but after the CentOS/RedHat drama I dropped it and started using Rocky Linux (no dual boot) - Now on their Workstation build.
Definitely a harder OS since it doesn't have the quality of life that Fedora had in terms de pre installed dependencies and packages. But at the same time it is way cleaner because of that since I only have what I need at the moment.
Unfortunately is the same problem as always: Although I'm not going to totally migrate to Linux - my knowledge about Linux is around 4 years against a lifetime (since I was 7/8 years old) of DOS/Windows - I will have to install a bigger drive in this new (to me) laptop to have again dual boot because of applications I don't have alternatives at the same level as in Windows.
So I will have to still put up with all the crap Microsoft is doing to his OS in a bet to turn it into a "service" while using ways to edit files and registry and others to remove superfluous crap, while I hope for companies to look at Linux as a viable alternative.
Or in a mad world where a version of Windows will be app compatible (including older apps) while using a Linux kernel (you can always dream).
Offline Nominal Animal
« Reply #123 on: April 13, 2025, 09:48:26 am »
That will not happen because of backwards compatibility in Windows, and the fundamental differences in concepts and their implementation between Windows and POSIXy systems.  The decades-long history and current performance limitations of Wine is the proof and record of that.
Even with their cloud infrastructure being fully based on Linux nowadays, Microsoft isn't capable of producing that level of interoperability either, as illustrated by Windows Subsystem for Linux and its compatibility issues.  (The reason for this is in MS's internal culture.  It just isn't suited for interoperability with others.  The internal tug-of-war between the OS and Office units is a good example of this, although MS's contracts try hard to keep those out from the public view.  What makes excellent business sense, can cause severe limitations on real technical capabilities, that's all.  I do not see MS as an enemy of FOSS anymore, for example; it was that a couple of decades ago, but not so today – just limited because of organizational history and structure.)
What works, however, is running different OSes in virtual machines, and enabling machine-local file sharing across those virtualized instances.  With a bit of help from the host virtualization environment, you can get even clipboard (copy-and-paste) working across OSes.
Thus, instead of hoping for unrealistic developments, you should focus on 'encouraging' Microsoft to enhance Windows performance in virtualized containers, including OpenGL/OpenGL ES acceleration (instead of their own proprietary DirectX).  This would bring Windows closer to other OSes in virtualized use cases.
Whatever opinion one might have about any one operating system, we all benefit from having multiple options.  Even though I myself don't use Windows, I am happy it exists.  I love that there is FreeBSD and OpenBSD and a couple of other smaller open source OS projects, and that Linux isn't the only option.  I much prefer mac OS over Windows, too, although I suspect Apple is overfocusing on iOS features (it being a derivative of their own mac OS), and am not impressed about the last few years' so-called improvements.
The same extends to Linux distributions.  Although they all use the same Linux kernel and most of the same OS and service layers, the key in open source has been user control (and ownership; licensing only limiting redistribution and creating derivatives, not use), so there are a lot of build-time choices to be made, and the entire system integration to do; and these affect the user interaction and "feel".  Multiple choices keeps up competition (for contributors, not so much for users), and through selection, software evolution.
  • Country: hk
« Reply #124 on: April 13, 2025, 01:58:08 pm »
As I said, in a mad world...
