Dunno. On windows 7 / Firefox I didn't notice anything much, it works fine here.
On Linux / Firefox, the Youtube player has been a disastrous experience for a few months now though (used to work absolutely fine before that). Usually the trigger is to use any control in the embedded player (so if you touch nothing, it plays fine), such as going forward or backward. It tends to suddenly take 100% CPU and make the player become unresponsive. You get out of it either by killing the associated process (fortunately - or unfortunately depending on your views on that - Firefox now spans a myriad of separate processes for everything), or letting Firefox figure out the script is unresponsive, and let it kill it.
So I often use VLC on Linux to watch Youtube videos - it plays them fine and with much less resource usage, and no problem with controlling the video.
I suppose it should on Windows as well. So if you keep having issues with the embedded player, I'd suggest using VLC instead, at least while the problem is still there.
One benefit is that since you need to cut and paste the videos URLs in VLC (it doesn't embed a Youtube browser), you waste a lot less time binge watching.
(There is a Firefox extension to directly play a Youtube video in VLC from Firefox, but then you don't get the above benefit.)
