Author Topic: Windows 7 vs Windows 10??  (Read 52804 times)
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Windows 7 vs Windows 10??
« Reply #125 on: November 30, 2019, 09:51:50 pm »
To be fair. I'm using windows 10 for a few months now. And they do learn, although slowly.
I've installed it by decrapifying in the audit mode, this gets you rid of all the recurring UWP apps.
The pro version allows you to delay feature updates for a year, so the "october update deletes your files" will probably go by me. And also patches can be delayed a month.
You still can only delay the inevitable rebooting for a maximum of 7 days though. So Windows 10, even LTSC which replaces embedded, is unsuitable for 24/7 operation!
Windows MUST HAVE a reboot once a month. There is only one other scenario I can think of that requires this, bugs.
Anyway, for a workstation this is fine.
Windows 10 still hides common settings in this ridiculous tablet mode. Getting to the network adapter overview is a pita, so much for many similar things.
The lack of decent shell inhibits effective productivity and is imho just a job creator.
However, they do try with powershell, but it's still not finished or the wrong time. As always with Microsoft products. Their product is wrong or they are doing it at the wrong time.
I wonder if the server product line is just as bad...
« Last Edit: November 30, 2019, 09:53:26 pm by Jeroen3 »
Offline james_s
« Reply #126 on: November 30, 2019, 10:16:55 pm »
In my very limited experience administering Windows servers, the server versions of the OS are much better. They still have the fugly UI but that doesn't really matter for a server and you can do most of the administration via powershell now. I can't think of many reasons to run a Windows server anymore though, and outside of Microsoft itself, *nix experience is far more valuable on the job market. Most tech companies are all Linux on the back end these days.
Offline SilverSolder
« Reply #127 on: November 30, 2019, 10:35:48 pm »
[...] I wonder if the [Microsoft] server product line is just as bad...
Server 2003 is actually quite good!  :)
Offline LeonR
  • Country: br
  • PC hardware enthusiast
« Reply #128 on: December 01, 2019, 10:33:11 pm »
I'm experiencing a weird thing on my Win 10 (that didn't happened back when I had 7): Sometimes my mouse cursor freezes for half a second or so, randomly and not linked to high RAM or CPU usage. I suspected it being a disk issue but even after changing my OS disk (upgraded my OS SSD, 256GB -> 500GB) it persists. It happens maybe twice a day. Haven't tried a fresh install though.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #129 on: December 02, 2019, 06:47:15 am »
Sounds like some driver spends too much time in an ISR.
The following users thanked this post: LeonR
Offline dzseki
  • Country: hu
« Reply #130 on: December 02, 2019, 06:48:25 am »
Windows 10 can do funny things. On my laptop the scrolling does not work in EDGE, but everywhere else yes. :clap: This was a problem last time in Windows 95...
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
« Reply #131 on: December 02, 2019, 03:48:48 pm »
I have seen similar things in Win7.  In my case, it was a tray application that was misbehaving and blocking the whole PC intermittently.
Perhaps try stripping the system down by switching applications and services off one by one, until the problem stops - to identify the culprit.
Offline NorthGuy
« Reply #132 on: December 02, 2019, 04:39:44 pm »
Cannot do it in Windows 10. Whatever you turn off, will automatically turn back on :)
Offline SiliconWizard
« Reply #133 on: December 02, 2019, 04:50:26 pm »
A bit like a bad virus.
 ;D
Offline LeonR
  • Country: br
« Reply #134 on: December 03, 2019, 12:02:07 am »
Seems like disabling C-States did the trick. I suspected it was a power management thing because it happened mostly when switching applications. I already had High Performance as my default power plan. Power consumption seem pretty OK with just SpeedStep turned on, at least by the wattage and temp readings that CoreTemp/PPM Panel show. Temps are just 6ÂșC above ambient on idle/low usage.
Had LatencyMon running and it didn't find anything weird, aisde from the occasional higher usage from DirectX/nVidia kernel drivers. The latter topped at ~1ms and the first at ~300us.
For a "cleaner" system I used ShutUp10, by O&O Software. Just went with the default optimizations it suggests (that are already many). I just have the nVidia control panel outside Windows default stuff. I like my main desktop to be as clean as possible of resident software.
« Reply #135 on: December 03, 2019, 12:11:15 am »
^Winner, winner, chicken dinner!   8)
Online langwadt
« Reply #136 on: December 03, 2019, 12:47:10 am »
Windows Subsystem for Linux works great
https://docs.microsoft.com/en-us/windows/wsl/install-win10
Offline james_s
« Reply #137 on: December 03, 2019, 01:46:19 am »
WSL is useless when you already have Linux machines and if you really want Windows bare metal you can run a proper Linux distro in a VM rather than use the WSL hack.
Online langwadt
« Reply #138 on: December 03, 2019, 08:45:49 am »
why is it useless if you already have linux machines? what major thing can a "proper Linux distro in a VM" do the WSL can't?
Offline BravoV
  • +++ ATH1
« Reply #139 on: December 03, 2019, 08:54:53 am »
 ;D
Also its now becoming ransomware, and own and take full control completely your PC, if its not constantly connected to the mother ship in Redmond.  >:D
 -> Windows 10 users fume: Microsoft, where's our 'local account' option gone?
The following users thanked this post: Electro Detective
Offline Black Phoenix
  • Country: hk
« Reply #140 on: December 03, 2019, 02:33:27 pm »
Keep putting nails in the coffin Microsoft. Go on, I dare you.  |O
Of course it was expected when they announced on the release of Windows 10 to be free to install for 1 year, including updates from cracked Windows 7/8/8.1 (specially the ones who used local VLK activation). When its free, then the product is the user.
« Last Edit: December 03, 2019, 02:37:44 pm by Black Phoenix »
Offline james_s
« Reply #141 on: December 03, 2019, 06:14:43 pm »
It's redundant, and it's a subset of Linux, a Linux distro in a VM is the real deal, you can have the entire graphical environment if you want, I've found no reason to want to run Linux software under Windows, Windows is the problem, the thing I've been working slowly to escape from for years.
Online langwadt
« Reply #142 on: December 03, 2019, 11:01:21 pm »
so it is more of a religious thing like being vegan?
a computer doesn't become redundant because you have another computer. As for being a subset, can you give some examples that makes a difference? everything including graphics seems to work the same as any other linux machine
Offline james_s
« Reply #143 on: December 03, 2019, 11:08:25 pm »
What are you even talking about? There's nothing religious about it, WSL is redundant because I can already run a full Linux distro under Windows if I really want to. If I'm going to use Linux anyway then why put up with the hassles of Windows? I don't mind that WSL is there, it just does not seem like a compelling feature, I cannot figure out what it offers over what I already have. I run Windows only because I have a significant amount of software that requires Windows, I cannot think of any other reason to run that OS. If I'm going to use Linux software I can just run it on Linux and not have Windows making my blood pressure rise.
Offline NorthGuy
« Reply #144 on: December 04, 2019, 12:00:01 am »
People don't switch to Linux because they miss Linux command line in Windows 10. They switch to Linux to get rid of the rest of Windows 10.
The following users thanked this post: SeanB, rdl, Red Squirrel, MyHeadHz, james_s, Jacon
Offline nigelwright7557
    • Electronic controls
« Reply #145 on: February 02, 2020, 12:22:21 am »
As a normal user Windows 10 does the job. You can block/delay updates if you like.
I had to connect two computers using a LAN.
There are bits and pieces all over the place in Win10 that need setting up to get it to work.
In this case Windows 10 is the worst software I have ever seen, very user unfriendly.
It seems like it was designed for techs to use, not normal users.
I got Win10 when it first came out and it was a bit unstable for a while but is much better now.
I have reinstalled Win10 about 10 times due to unrecoverable problems.
The following users thanked this post: Jacon
Offline james_s
« Reply #146 on: February 02, 2020, 04:53:11 am »
Meanwhile my Win7 laptop has been humming right along since I bought it in 2015. My Linux machines have also just worked, never had to reinstall any one of them, networking and file sharing works fine on all of them, I'm even able to access my Samba shared folders from Windows and my employer issued Macbook. I haven't experienced an unrecoverable problem requiring re-installing since Windows 2000. That was generally a solid OS but it did break on me a couple of time.
« Reply #147 on: February 02, 2020, 01:03:32 pm »
^I have Win 7 on all my PCs (about 7 of them), and it "just works"TM.
I also have several old but good printers, which most likely are not supported in Windows 10.
I have hundreds of applications collected over the years, some of which most likely won't work well in Windows 10.
I have a big problem with all the surveillance capitalism going on,  I don't like entrusting my digital life to the cloud, and I don't like paying monthly for things that rightfully should be bought outright.
If I felt more comfortable about the above issues, I would have upgraded to Windows 10 a long time ago.
« Reply #148 on: February 02, 2020, 10:50:41 pm »
The Win7 install on my main workstation actually dates back to... 2009. I've of course upgraded the hardware several times since then, cloned the OS on different hard drives (and then, SSD), but without ever re-installing it! The machine itself has little to do with what it was when I installed the OS, but never had any issue when upgrading hardware (several times, I think it has seen 3 generations of Core i7 processors, a different motherboard for each, several HDDs/SSDs, several different graphics cards...) But it works fine to this day.
Offline pcmad
    • module web design
« Reply #149 on: February 12, 2020, 02:34:18 am »
linux
