At the time OS/2 had, in my opinion, a great balance between the Windows 3.x desktop organization and the Applications bar located at the bottom of the screen
The object-oriented approach IBM used for the OS/2 WPS was certainly interesting but the concept was so far off that many users struggled with it.
The application bar (called LaunchPad) was only introduced later with Warp 3.0 and wasn't exactly a novel concept (CDE, the back then default UNIX desktop, has had it for longer, I believe AmigaOS had that, too, and then there was IndigoMagic from SGI which had that as well).
something that OSX borrowed many years later (but probably Apple claims to have invented it). Even at that time several third party applications re-configured the Windows UI to add these elements (I don't recall their names, though).
Mac OS X didn't borrow from OS/2. Most of the Mac OS X UI elements were derived from NextStep/OpenStep, a UNIX variant created by NeXT for its series of M68k based workstation. NeXT was founded by Steve Jobs after he was ousted from Apple in the '80s.
Well, to be fair most of the time the desktop shortcuts are there because so many software installers insist to place another icon for the software they are deploying on the desktop, often without asking the user.
I used to believe that as well but, in my experience working with people from various companies, the amount of word docs, excel spreadsheets and powerpoint presentations plastered in the desktop of countless hosts indicate that the practicality of having these at your fingertips beats any hierarchy by a mile. [/quote]
You are right, corporate users are the worst when it comes to littering the desktop and local and networked folders with copies of the same spreadsheet at various stages. Often even the authors don't know which of the copies is the current one.
Sharepoint helps a lot to avoid that, but it's a rather fragile software and difficult to setup properly.
Developers ignoring Microsoft Style Guides have been a bane of Windows since forever.
Yep. That was one of the huge contributors to the bad press that Vista got when MS tried to enforce proper user/superuser separation from third party applications. [/quote
Indeed. It's still a problem, i.e. some installers want to install into AppData which is just for settings
But don't underestimate the power of the search function.
No worries; I don't. However, the added clutter that Windows 10 adds to results confuses inexperienced people (the vast majority of users). I know this by my own experience.
I agree, I don't like many of the UI changes in Windows 10 either. The full screen mode of the start menu is actually worse than on Windows 8/8.1, and has the nasty habit of occasionally shifting icons so they partially cover others. I also miss transparency.
Luckily, most of our work systems run on Linux (Red Hat/SUSE) but considering that GNOME is horrible on a completely different scale than the Windows UIs I'm glad that we use Red Hat mostly on servers only (RH uses GNOME). Thankfully, SUSE supports KDE which is a lot better (even though it's also far from perfect).
We sure can have "nice things", but it doesn't mean we like them. Case in point: the software houses are pushing their UI newfangled trends at every new release - the latest being the ethereal visual appeal with light grey on white or the complete flattening of icons, images and buttons.
Yeah, I'm not a fan of the flat monochrome designs we get these days. But luckily sometimes it's just that it's butt ugly while the actual functionality behind is quite good.
I have no idea where the Win95 desktop idea came from, though.
I think it started as something called "System" which was supposed to resemble the same functionality as the Apple menu on classic Mac OS, and later morphed into a program launcher.
