Author Topic: Windows Home 10 1903 update Struck this morning  (Read 3589 times)
Offline SG-1Topic starter
« on: July 29, 2019, 02:08:02 am »
Explorer is about all that is left of the system.
Any suggestions on getting my files & Outlook back?   :scared:
Advice is a dangerous gift, even from the wise to the wise.
Offline wilfred
Re: Windows Home 10 1903 update Struck this morning
« Reply #1 on: July 29, 2019, 05:09:48 am »
Do you have restore points you can go back to before the update? Windows (if you've enabled it) can take restore points before doing updates.  You can read more about it here.
It is just one of the first links I found. There might be better ones. https://www.windowscentral.com/how-use-system-restore-windows-10
The following users thanked this post: SG-1
Offline ChunkyPastaSauce
« Reply #2 on: July 29, 2019, 06:06:54 am »
I use testdisk. Has saved me number of times now.
https://www.cgsecurity.org/wiki/TestDisk_Download
Do not boot from drive or write anything to the drive until you're done with recovery
« Reply #3 on: July 29, 2019, 03:59:28 pm »
Here is my plan so far:
I can see most or all of the missing files on the C-drive.  Not located Outlook yet, have not really tried.
Purchase a jump drive & copy the files on C.
Then go about restoring Windows 10.
Set up restore points!!
Offline JPortici
« Reply #4 on: July 30, 2019, 07:20:33 am »
usually you have a number of hours when you can restore the system at BEFORE the critical updates, you have to boot in recovering mode
Offline Black Phoenix
  • Country: hk
« Reply #5 on: July 30, 2019, 07:54:53 am »
The outlook file normally is hosted if it wasn't changed in:
drive:\Users\[user account name]\Documents\Outlook Files.
Inside there should be a .PST or .OST file with the account name. Just copy that file and all emails, calendars, contacts, etc should be safe.
In Microsoft Office Outlook 2007 or earlier, these files are saved in a different location in a hidden folder at drive:\Users\[user account name]\AppData\Local\Microsoft\Outlook.
That's the default config for the files. If not just search the HDD for all files including hidden ones with *.pst AND *ost
« Last Edit: July 30, 2019, 08:01:05 am by Black Phoenix »
Offline ruchika
  • Country: in
« Reply #6 on: July 30, 2019, 11:38:18 am »
Thanks for the information
Online SiliconWizard
« Reply #7 on: July 30, 2019, 09:08:01 pm »
With Win 10 2000 update, you'll be greeted with a "All your base are belong to us" at the login screen.
 :-DD
« Reply #8 on: July 31, 2019, 01:57:46 am »
 :-DD
Don't forget the first born child !!
« Reply #9 on: August 02, 2019, 04:30:41 am »
Thanks everyone, After copying the C-drive & skipping a few files because of the FAT32 file system that needs to be changed,  Windows 10 was manually downloaded & restored the system to normal . :phew:
Now to set up some restore points...
