Author Topic: Windows XP, NTFS, badclusters in partition3: how to know which file is affected?  (Read 3035 times)
Offline 0dbTopic starter
  • Country: zm
Yesterday a collegue gave me her Windows XP laptop and asked me to backup the whole harddrive because she wants to migrate to a new laptop with Windows 10
On her XP laptop I found three partitions, and I checked each of them for any badblock
#1 NTFS 60GB: all ok
#2 NTFS 50GB: all ok
#3 NTFS 50GB: found several badblocks
I wonder if there is a way to understand which file is affected by the badblock? Data is for sure corrupted there at the physical layer, but how to know about the filesystem layer?
Sorry for the silly question.
Offline StillTrying
  • Country: Broken Britain
  • Country: zm
I checked the three partitions with Linux, which reports a list of damaged sectors.
But what I'd like to know if there is a way to know which file is mapped on that sectors.
Offline ChunkyPastaSauce
The following users thanked this post: edavid, 0db
Online magic
mount /dev/sdz9 /mnt/wind0$ -o ro
find /mnt/wind0$ -type f -exec cat {} \; >/dev/null
cat: /mnt/wind0$/broken/file: IO error
cat: /mnt/wind0$/broken/another/one: IO error
:popcorn:
edit
Or, you know, simply
cp -a /mnt/wind0$ /mnt/new-disk/:D
« Last Edit: July 18, 2020, 06:44:54 am by magic »
The following users thanked this post: 0db
  • Country: zm
LOL, this is already "work in progress"  ;D
  • Country: zm
This didn't report anything. Can I assume there are no corrupted files?
20 minutes ago I completely copied all the files in the damaged partition into an external harddrive.
Again, no warning/error message.
It's a bit weird, becasue the physical analysis of the harddrive reports more than 5000 damaged blocks.
Online magic
Yes, try either the find or cp on some files you don't have permission to access or something like that, it will throw errors at you (the find invocation simply reads all files and prints them to /dev/null).
If there were no errors, it must have worked. It seems that you / your friend were lucky and the bad blocks fell within some unused area.
  • Country: zm
Dunno what she did with her laptop, but today I copied everything into a new SSD.
And I am going to put the old electromechanical harddrive into the bin.
Thank you for the support, this story has a good end :D
Offline tunk
  • Country: no
If you haven't already done it, wipe the disk before you bin it.
Online magic
Or keep it as a backup, just in case ;)
Offline Mechatrommer
  • Country: my
  • reassessing directives...
maybe once, the laptop got slight bump while write/read progress if its HDD. or psu problem if its SDD of just near the drive lifetime
https://www.crucial.com/support/articles-faq-ssd/my-ssd-has-bad-sectors
reading your OP the total volume is 150GB, i thought its SDD. but if its HDD it must be really really old HDD. but still, the plates is a nice decorative mirror. ;D
if you have free time to spend... wiping the whole area takes time, not really an issue for 100GB+ data, for TB data/volume? only worth for some sensitive data imho like business/IP/government secret or sex/scandal/affair or self naked pictures >:D. faster way is open it up, dismantle the disc plates and grind the surfaces (HDD). or simply smash with hammer or burn if its SDD.
if its HDD is new or less than 10 years, its probably still can function properly if bad sectors are marked. but if its SDD, its a sign of end of lifetime. if its new and power disruption occurs during operation resuting corrupted files or bad sectors, maybe reformat can fix it?
for hardcorer who want to get closer to their data from SW/OS level... http://www.cse.scu.edu/~tschwarz/coen252_07Fall/Lectures/NTFS.html but i think the structure only accessible from disk cloner file output, not directly from the drive/OS. fwiw.
« Last Edit: July 19, 2020, 03:47:07 am by Mechatrommer »
The Ultimatum of False Logic... http://www.soasystem.com/false_logic.jpg
  • Country: zm
It's HDD  :D
I am not sure if she upgraded it, but according to the receipt number written on the back of the laptop, she must have bought the laptop in the far 2008.
It says "November, 2008". It's something like 12 years ago!
That's probably the cause, in my opinion. I mean, in real life, sooner or later it happens  :D
  • Country: my
thats the age when PATA is still a common thing. recently i got one dated 2007 giving up. i have another one stripped from a DSO manufacturer's date 2003 thats still readable with lots of bad sectors, maybe it had see less working hours inside the DSO. that HDD is going to die soon anyway even without a bump, continue to use it is hoping for disaster. bin it, its useless except its disk plate is an unusually smooth and flat high quality steel alloy mirror (i keep lots of them still inside the damaged HDD compartments) and some fancy neomydium magnets that can hold a utility compartment or something and lid intact together.
« Last Edit: July 19, 2020, 11:44:27 am by Mechatrommer »
  • Country: zm
Just for my curiosity, I tested a second old hard drive
Checking for bad blocks, From block 0 to 156290903
Writing pattern 0xaa, Reading and comparing: done, all OK
Writing pattern 0x55, Reading and comparing: done, all OK
Writing pattern 0xff, Reading and comparing: done, all OK
Writing pattern 0x00, Reading and comparing: ...
           block 137614712: not equal to pattern 0x00
           block 137614713: not equal to pattern 0x00
           block 137614714: not equal to pattern 0x00
           block 137614715: not equal to pattern 0x00
           block 137616756: not equal to pattern 0x00
           block 137616757: not equal to pattern 0x00
           block 137616758: not equal to pattern 0x00
           block 137616759: not equal to pattern 0x00
8 bad blocks found!
Results are weird. The tests wrote different patterns 0xaa, 0x55, 0xff, 0x00 and compared reads.
How can it be possible that patterns 0xaa, 0x55, 0xff do pass the test, but pattern 0x00 does not?
0xaa = bx10101010
0x55 = bx01010101
0xff = bx11111111
0x00 = bx00000000
Weird also that dd if=/dev/sdb of=/dev/null doesn't produce any warning in the dmesg of Linux.
it seems we have a definition of "bad cluster" like a block that doesn't exactly keep the exact information you write, but something approximated.
Basically hidden and silent corruption  :-//
  • Country: zm
No, this time the problem was the Linux kernel. Or the hardware of the old laptop. I am not sure.
Tried on a different computer, and this time there are the expected warnings in the dmesg!
[625492.686956] Buffer I/O error on dev sdb, logical block 33649053, async page read
[625495.217169] Buffer I/O error on dev sdb, logical block 33649054, async page read
[625497.661246] Buffer I/O error on dev sdb, logical block 33649054, async page read
[625500.049439] Buffer I/O error on dev sdb, logical block 33649054, async page read
[625502.481514] Buffer I/O error on dev sdb, logical block 33649054, async page read
[625505.022728] Buffer I/O error on dev sdb, logical block 33649111, async page read
[625507.374043] Buffer I/O error on dev sdb, logical block 33649111, async page read
[625509.685476] Buffer I/O error on dev sdb, logical block 33649111, async page read
[625512.029539] Buffer I/O error on dev sdb, logical block 33649111, async page read
[625514.520121] Buffer I/O error on dev sdb, logical block 33649156, async page read
[625517.646413] Buffer I/O error on dev sdb, logical block 33649156, async page read
[625519.989976] Buffer I/O error on dev sdb, logical block 33649156, async page read
[625522.400423] Buffer I/O error on dev sdb, logical block 33649156, async page read
[625526.262438] Buffer I/O error on dev sdb, logical block 33649158, async page read
[625528.607126] Buffer I/O error on dev sdb, logical block 33649158, async page read
[625530.951189] Buffer I/O error on dev sdb, logical block 33649158, async page read
[625533.174611] Buffer I/O error on dev sdb, logical block 33649158, async page read
[625535.473668] Buffer I/O error on dev sdb, logical block 33649159, async page read
[625537.719718] Buffer I/O error on dev sdb, logical block 33649159, async page read
[625539.953766] Buffer I/O error on dev sdb, logical block 33649159, async page read
[625542.176813] Buffer I/O error on dev sdb, logical block 33649159, async page read
[625544.563882] Buffer I/O error on dev sdb, logical block 33649215, async page read
[625546.783427] Buffer I/O error on dev sdb, logical block 33649215, async page read
[625549.028477] Buffer I/O error on dev sdb, logical block 33649215, async page read
[625551.438549] Buffer I/O error on dev sdb, logical block 33649215, async page read
[625553.742231] Buffer I/O error on dev sdb, logical block 33649259, async page read
[625558.022928] Buffer I/O error on dev sdb, logical block 33649259, async page read
[625560.422498] Buffer I/O error on dev sdb, logical block 33649259, async page read
[625562.876951] Buffer I/O error on dev sdb, logical block 33649259, async page read
[625565.319277] Buffer I/O error on dev sdb, logical block 33649260, async page read
[625569.535340] Buffer I/O error on dev sdb, logical block 33649260, async page read
[625573.264964] Buffer I/O error on dev sdb, logical block 33649261, async page read
[625575.555021] Buffer I/O error on dev sdb, logical block 33649261, async page read
[625577.822073] Buffer I/O error on dev sdb, logical block 33649261, async page read
[625580.122129] Buffer I/O error on dev sdb, logical block 33649261, async page read
[625582.377305] Buffer I/O error on dev sdb, logical block 33649262, async page read
[625584.601352] Buffer I/O error on dev sdb, logical block 33649262, async page read
[625586.824399] Buffer I/O error on dev sdb, logical block 33649262, async page read
[625589.047320] Buffer I/O error on dev sdb, logical block 33649262, async page read
[625591.434264] Buffer I/O error on dev sdb, logical block 33649362, async page read
[625593.779078] Buffer I/O error on dev sdb, logical block 33649362, async page read
[625596.122765] Buffer I/O error on dev sdb, logical block 33649362, async page read
[625598.466828] Buffer I/O error on dev sdb, logical block 33649362, async page read
[625600.843770] Buffer I/O error on dev sdb, logical block 33649363, async page read
[625603.177207] Buffer I/O error on dev sdb, logical block 33649363, async page read
[625605.510268] Buffer I/O error on dev sdb, logical block 33649363, async page read
[625607.843330] Buffer I/O error on dev sdb, logical block 33649363, async page read
[625610.307909] Buffer I/O error on dev sdb, logical block 33649364, async page read
[625613.301934] Buffer I/O error on dev sdb, logical block 33649364, async page read
[625615.667874] Buffer I/O error on dev sdb, logical block 33649364, async page read
[625618.011937] Buffer I/O error on dev sdb, logical block 33649364, async page read
[625620.278490] Buffer I/O error on dev sdb, logical block 33649365, async page read
[625622.513413] Buffer I/O error on dev sdb, logical block 33649365, async page read
[625624.736461] Buffer I/O error on dev sdb, logical block 33649365, async page read
[625626.970508] Buffer I/O error on dev sdb, logical block 33649365, async page read
[625632.317971] Buffer I/O error on dev sdb, logical block 33649468, async page read
[625634.542020] Buffer I/O error on dev sdb, logical block 33649468, async page read
[625636.786943] Buffer I/O error on dev sdb, logical block 33649468, async page read
[625639.317156] Buffer I/O error on dev sdb, logical block 33649468, async page read
[625641.529452] Buffer I/O error on dev sdb, logical block 33649469, async page read
[625643.764375] Buffer I/O error on dev sdb, logical block 33649469, async page read
[625645.987422] Buffer I/O error on dev sdb, logical block 33649469, async page read
[625648.210469] Buffer I/O error on dev sdb, logical block 33649469, async page read
[625650.487523] Buffer I/O error on dev sdb, logical block 33649569, async page read
[625654.878484] Buffer I/O error on dev sdb, logical block 33649570, async page read
[625657.102406] Buffer I/O error on dev sdb, logical block 33649570, async page read
[625659.336329] Buffer I/O error on dev sdb, logical block 33649570, async page read
[625661.559377] Buffer I/O error on dev sdb, logical block 33649570, async page read
[625664.980959] Buffer I/O error on dev sdb, logical block 33649571, async page read
[625667.215881] Buffer I/O error on dev sdb, logical block 33649571, async page read
[625669.449930] Buffer I/O error on dev sdb, logical block 33649571, async page read
[625671.694884] Buffer I/O error on dev sdb, logical block 33649571, async page read
[625674.676377] Buffer I/O error on dev sdb, logical block 33649673, async page read
[625676.900174] Buffer I/O error on dev sdb, logical block 33649673, async page read
[625679.134223] Buffer I/O error on dev sdb, logical block 33649673, async page read
[625681.379272] Buffer I/O error on dev sdb, logical block 33649673, async page read
[625683.645450] Buffer I/O error on dev sdb, logical block 33649674, async page read
[625685.880373] Buffer I/O error on dev sdb, logical block 33649674, async page read
[625688.136425] Buffer I/O error on dev sdb, logical block 33649674, async page read
[625690.359471] Buffer I/O error on dev sdb, logical block 33649674, async page read
[625693.318990] Buffer I/O error on dev sdb, logical block 33649776, async page read
[625695.674806] Buffer I/O error on dev sdb, logical block 33649776, async page read
[625697.941732] Buffer I/O error on dev sdb, logical block 33649776, async page read
[625700.307924] Buffer I/O error on dev sdb, logical block 33649776, async page read
[625702.794256] Buffer I/O error on dev sdb, logical block 33649777, async page read
[625705.183200] Buffer I/O error on dev sdb, logical block 33649777, async page read
[625708.528896] Buffer I/O error on dev sdb, logical block 33649777, async page read
[625710.938843] Buffer I/O error on dev sdb, logical block 33649777, async page read
[625714.569703] Buffer I/O error on dev sdb, logical block 33649778, async page read
[625716.815627] Buffer I/O error on dev sdb, logical block 33649778, async page read
[625719.038550] Buffer I/O error on dev sdb, logical block 33649778, async page read
[625721.272597] Buffer I/O error on dev sdb, logical block 33649778, async page read
[625723.527773] Buffer I/O error on dev sdb, logical block 33649779, async page read
[625726.257014] Buffer I/O error on dev sdb, logical block 33649779, async page read
[625728.909242] Buffer I/O error on dev sdb, logical block 33650201, async page read
[625731.231302] Buffer I/O error on dev sdb, logical block 33650201, async page read
[625733.531859] Buffer I/O error on dev sdb, logical block 33650201, async page read
[625735.920178] Buffer I/O error on dev sdb, logical block 33650201, async page read
[625738.208485] Buffer I/O error on dev sdb, logical block 33650304, async page read
[625741.191507] Buffer I/O error on dev sdb, logical block 33650304, async page read
[625743.601453] Buffer I/O error on dev sdb, logical block 33650304, async page read
[625746.022526] Buffer I/O error on dev sdb, logical block 33650304, async page read
[625748.289081] Buffer I/O error on dev sdb, logical block 33650406, async page read
[625750.556507] Buffer I/O error on dev sdb, logical block 33650406, async page read
[625752.735548] Buffer I/O error on dev sdb, logical block 33650406, async page read
[625754.980598] Buffer I/O error on dev sdb, logical block 33650406, async page read
[625757.236149] Buffer I/O error on dev sdb, logical block 33650407, async page read
[625759.459696] Buffer I/O error on dev sdb, logical block 33650407, async page read
[625761.704745] Buffer I/O error on dev sdb, logical block 33650407, async page read
[625763.938795] Buffer I/O error on dev sdb, logical block 33650407, async page read
[625767.184727] Buffer I/O error on dev sdb, logical block 33650510, async page read
[625769.727442] Buffer I/O error on dev sdb, logical block 33650510, async page read
[625771.983368] Buffer I/O error on dev sdb, logical block 33650510, async page read
[625774.228863] Buffer I/O error on dev sdb, logical block 33650510, async page read
[625776.682121] Buffer I/O error on dev sdb, logical block 33650511, async page read
[625781.150092] Buffer I/O error on dev sdb, logical block 33650614, async page read
[625783.395766] Buffer I/O error on dev sdb, logical block 33650614, async page read
[625785.629689] Buffer I/O error on dev sdb, logical block 33650614, async page read
[625787.863739] Buffer I/O error on dev sdb, logical block 33650614, async page read
[625792.617498] Buffer I/O error on dev sdb, logical block 33650940, async page read
[625794.918180] Buffer I/O error on dev sdb, logical block 33650940, async page read
[625797.745682] Buffer I/O error on dev sdb, logical block 33651043, async page read
[625799.980481] Buffer I/O error on dev sdb, logical block 33651043, async page read
[625807.628252] Buffer I/O error on dev sdb, logical block 33651242, async page read
[625809.972439] Buffer I/O error on dev sdb, logical block 33651242, async page read
[625812.316878] Buffer I/O error on dev sdb, logical block 33651242, async page read
[625814.616560] Buffer I/O error on dev sdb, logical block 33651242, async page read
[625817.136646] Buffer I/O error on dev sdb, logical block 33651345, async page read
[625819.381696] Buffer I/O error on dev sdb, logical block 33651345, async page read
[625821.627245] Buffer I/O error on dev sdb, logical block 33651345, async page read
[625823.839167] Buffer I/O error on dev sdb, logical block 33651345, async page read
[625826.193730] Buffer I/O error on dev sdb, logical block 33651369, async page read
[625828.419527] Buffer I/O error on dev sdb, logical block 33651369, async page read
[625832.774734] Buffer I/O error on dev sdb, logical block 33651443, async page read
[625834.997906] Buffer I/O error on dev sdb, logical block 33651443, async page read
[625837.220827] Buffer I/O error on dev sdb, logical block 33651443, async page read
[625839.443874] Buffer I/O error on dev sdb, logical block 33651443, async page read
[625841.721802] Buffer I/O error on dev sdb, logical block 33651448, async page read
[625843.956476] Buffer I/O error on dev sdb, logical block 33651448, async page read
[625846.190399] Buffer I/O error on dev sdb, logical block 33651448, async page read
[625848.424447] Buffer I/O error on dev sdb, logical block 33651448, async page read
[625850.900030] Buffer I/O error on dev sdb, logical block 33651548, async page read
[625853.233341] Buffer I/O error on dev sdb, logical block 33651548, async page read
[625855.577404] Buffer I/O error on dev sdb, logical block 33651548, async page read
[625857.899464] Buffer I/O error on dev sdb, logical block 33651548, async page read
[625862.620594] Buffer I/O error on dev sdb, logical block 33651733, async page read
[625864.851266] Buffer I/O error on dev sdb, logical block 33651733, async page read
[625867.085315] Buffer I/O error on dev sdb, logical block 33651733, async page read
[625869.308361] Buffer I/O error on dev sdb, logical block 33651733, async page read
[625872.558046] Buffer I/O error on dev sdb, logical block 33651768, async page read
[625874.748089] Buffer I/O error on dev sdb, logical block 33651768, async page read
[625876.993013] Buffer I/O error on dev sdb, logical block 33651768, async page read
[625879.227185] Buffer I/O error on dev sdb, logical block 33651768, async page read
[625881.604127] Buffer I/O error on dev sdb, logical block 33651973, async page read
[625883.838176] Buffer I/O error on dev sdb, logical block 33651973, async page read
[625886.105228] Buffer I/O error on dev sdb, logical block 33651973, async page read
[625888.350279] Buffer I/O error on dev sdb, logical block 33651973, async page read
[625890.606330] Buffer I/O error on dev sdb, logical block 33651974, async page read
[625892.829377] Buffer I/O error on dev sdb, logical block 33651974, async page read
[625895.052424] Buffer I/O error on dev sdb, logical block 33651974, async page read
[625897.286471] Buffer I/O error on dev sdb, logical block 33651974, async page read
[625901.732315] Buffer I/O error on dev sdb, logical block 33651982, async page read
[625903.989117] Buffer I/O error on dev sdb, logical block 33651982, async page read
[625906.212163] Buffer I/O error on dev sdb, logical block 33651982, async page read
[625908.435210] Buffer I/O error on dev sdb, logical block 33651982, async page read
[625911.152698] Buffer I/O error on dev sdb, logical block 33652078, async page read
[625913.386746] Buffer I/O error on dev sdb, logical block 33652078, async page read
[625915.653799] Buffer I/O error on dev sdb, logical block 33652078, async page read
[625917.898848] Buffer I/O error on dev sdb, logical block 33652078, async page read
[625920.242912] Buffer I/O error on dev sdb, logical block 33652080, async page read
[625922.532217] Buffer I/O error on dev sdb, logical block 33652080, async page read
[625924.843151] Buffer I/O error on dev sdb, logical block 33652080, async page read
[625927.176338] Buffer I/O error on dev sdb, logical block 33652080, async page read
[625931.358021] Buffer I/O error on dev sdb, logical block 33652180, async page read
[625933.591943] Buffer I/O error on dev sdb, logical block 33652180, async page read
[625935.814990] Buffer I/O error on dev sdb, logical block 33652180, async page read
[625938.324201] Buffer I/O error on dev sdb, logical block 33652180, async page read
[625941.053315] Buffer I/O error on dev sdb, logical block 33652284, async page read
[625943.408129] Buffer I/O error on dev sdb, logical block 33652284, async page read
[625945.642552] Buffer I/O error on dev sdb, logical block 33652284, async page read
[625948.316660] Buffer I/O error on dev sdb, logical block 33652284, async page read
[625952.355699] Buffer I/O error on dev sdb, logical block 33652389, async page read
[625954.600874] Buffer I/O error on dev sdb, logical block 33652389, async page read
[625956.856924] Buffer I/O error on dev sdb, logical block 33652389, async page read
[625959.101849] Buffer I/O error on dev sdb, logical block 33652389, async page read
[625961.368651] Buffer I/O error on dev sdb, logical block 33652390, async page read
[625963.592075] Buffer I/O error on dev sdb, logical block 33652390, async page read
[625965.825997] Buffer I/O error on dev sdb, logical block 33652390, async page read
[625968.071048] Buffer I/O error on dev sdb, logical block 33652390, async page read
[625970.337975] Buffer I/O error on dev sdb, logical block 33652391, async page read
[625972.561396] Buffer I/O error on dev sdb, logical block 33652391, async page read
[625974.773316] Buffer I/O error on dev sdb, logical block 33652391, async page read
[625976.996363] Buffer I/O error on dev sdb, logical block 33652391, async page read
[625979.284919] Buffer I/O error on dev sdb, logical block 33652410, async page read
[625981.730121] Buffer I/O error on dev sdb, logical block 33652410, async page read
[625984.228328] Buffer I/O error on dev sdb, logical block 33652410, async page read
[625987.122839] Buffer I/O error on dev sdb, logical block 33652410, async page read
[625989.376640] Buffer I/O error on dev sdb, logical block 33652411, async page read
[625991.601937] Buffer I/O error on dev sdb, logical block 33652411, async page read
[625993.835861] Buffer I/O error on dev sdb, logical block 33652411, async page read
[625996.014902] Buffer I/O error on dev sdb, logical block 33652411, async page read
[625998.389844] Buffer I/O error on dev sdb, logical block 33652412, async page read
[626000.724780] Buffer I/O error on dev sdb, logical block 33652412, async page read
[626003.068843] Buffer I/O error on dev sdb, logical block 33652412, async page read
[626005.357899] Buffer I/O error on dev sdb, logical block 33652412, async page read
[626007.634078] Buffer I/O error on dev sdb, logical block 33652413, async page read
[626009.870376] Buffer I/O error on dev sdb, logical block 33652413, async page read
[626012.126428] Buffer I/O error on dev sdb, logical block 33652413, async page read
[626014.349475] Buffer I/O error on dev sdb, logical block 33652413, async page read
[626016.603027] Buffer I/O error on dev sdb, logical block 33652414, async page read
[626018.817447] Buffer I/O error on dev sdb, logical block 33652414, async page read
[626021.040493] Buffer I/O error on dev sdb, logical block 33652414, async page read
[626023.263539] Buffer I/O error on dev sdb, logical block 33652414, async page read
[626025.572099] Buffer I/O error on dev sdb, logical block 33652492, async page read
[626027.806271] Buffer I/O error on dev sdb, logical block 33652492, async page read
[626030.029318] Buffer I/O error on dev sdb, logical block 33652492, async page read
[626032.252240] Buffer I/O error on dev sdb, logical block 33652492, async page read
[626034.508416] Buffer I/O error on dev sdb, logical block 33652493, async page read
[626036.731588] Buffer I/O error on dev sdb, logical block 33652493, async page read
[626038.943633] Buffer I/O error on dev sdb, logical block 33652493, async page read
[626041.155553] Buffer I/O error on dev sdb, logical block 33652493, async page read
[626043.455235] Buffer I/O error on dev sdb, logical block 33652599, async page read
[626045.678781] Buffer I/O error on dev sdb, logical block 33652599, async page read
[626047.901828] Buffer I/O error on dev sdb, logical block 33652599, async page read
[626050.124875] Buffer I/O error on dev sdb, logical block 33652599, async page read
[626054.394321] Buffer I/O error on dev sdb, logical block 33653540, async page read
[626056.584614] Buffer I/O error on dev sdb, logical block 33653540, async page read
[626058.807661] Buffer I/O error on dev sdb, logical block 33653540, async page read
[626061.008703] Buffer I/O error on dev sdb, logical block 33653540, async page read
[626063.506412] Buffer I/O error on dev sdb, logical block 33653617, async page read
[626069.218050] Buffer I/O error on dev sdb, logical block 33653647, async page read
[626073.278467] Buffer I/O error on dev sdb, logical block 33653647, async page read
[626075.523266] Buffer I/O error on dev sdb, logical block 33653647, async page read
[626077.768316] Buffer I/O error on dev sdb, logical block 33653647, async page read
[626080.476428] Buffer I/O error on dev sdb, logical block 33654062, async page read
[626082.687974] Buffer I/O error on dev sdb, logical block 33654062, async page read
[626084.900020] Buffer I/O error on dev sdb, logical block 33654062, async page read
[626087.111939] Buffer I/O error on dev sdb, logical block 33654062, async page read
[626092.922965] Buffer I/O error on dev sdb, logical block 33654266, async page read
[626095.277404] Buffer I/O error on dev sdb, logical block 33654266, async page read
[626097.544457] Buffer I/O error on dev sdb, logical block 33654266, async page read
[626099.833387] Buffer I/O error on dev sdb, logical block 33654266, async page read
[626102.167199] Buffer I/O error on dev sdb, logical block 33654272, async page read
[626104.544141] Buffer I/O error on dev sdb, logical block 33654272, async page read
[626106.932209] Buffer I/O error on dev sdb, logical block 33654272, async page read
[626109.276273] Buffer I/O error on dev sdb, logical block 33654272, async page read
[626111.895622] Buffer I/O error on dev sdb, logical block 33654803, async page read
[626115.934662] Buffer I/O error on dev sdb, logical block 33654803, async page read
[626118.300602] Buffer I/O error on dev sdb, logical block 33654803, async page read
[626120.534651] Buffer I/O error on dev sdb, logical block 33654803, async page read
[626122.878588] Buffer I/O error on dev sdb, logical block 33654905, async page read
[626125.123638] Buffer I/O error on dev sdb, logical block 33654905, async page read
[626127.368688] Buffer I/O error on dev sdb, logical block 33654905, async page read
[626129.602611] Buffer I/O error on dev sdb, logical block 33654905, async page read
[626131.980054] Buffer I/O error on dev sdb, logical block 33654906, async page read
[626134.312615] Buffer I/O error on dev sdb, logical block 33654906, async page read
[626136.646053] Buffer I/O error on dev sdb, logical block 33654906, async page read
[626138.978738] Buffer I/O error on dev sdb, logical block 33654906, async page read
[626141.257292] Buffer I/O error on dev sdb, logical block 33654973, async page read
[626143.476965] Buffer I/O error on dev sdb, logical block 33654973, async page read
[626145.699886] Buffer I/O error on dev sdb, logical block 33654973, async page read
[626147.933935] Buffer I/O error on dev sdb, logical block 33654973, async page read
[626151.293633] Buffer I/O error on dev sdb, logical block 33655076, async page read
[626153.524305] Buffer I/O error on dev sdb, logical block 33655076, async page read
[626155.769355] Buffer I/O error on dev sdb, logical block 33655076, async page read
[626158.003404] Buffer I/O error on dev sdb, logical block 33655076, async page read
[626160.262830] Buffer I/O error on dev sdb, logical block 33655114, async page read
[626162.486001] Buffer I/O error on dev sdb, logical block 33655114, async page read
[626164.720050] Buffer I/O error on dev sdb, logical block 33655114, async page read
[626166.942971] Buffer I/O error on dev sdb, logical block 33655114, async page read
[626171.454948] Buffer I/O error on dev sdb, logical block 33655216, async page read
[626173.688997] Buffer I/O error on dev sdb, logical block 33655216, async page read
[626175.912044] Buffer I/O error on dev sdb, logical block 33655216, async page read
[626178.322117] Buffer I/O error on dev sdb, logical block 33655216, async page read
[626180.666055] Buffer I/O error on dev sdb, logical block 33655217, async page read
[626183.009866] Buffer I/O error on dev sdb, logical block 33655217, async page read
[626185.387310] Buffer I/O error on dev sdb, logical block 33655217, async page read
[626187.797506] Buffer I/O error on dev sdb, logical block 33655217, async page read
[626190.009426] Buffer I/O error on dev sdb, logical block 33655218, async page read
[626192.243600] Buffer I/O error on dev sdb, logical block 33655218, async page read
[626194.477647] Buffer I/O error on dev sdb, logical block 33655218, async page read
[626196.711571] Buffer I/O error on dev sdb, logical block 33655218, async page read
[626200.299051] Buffer I/O error on dev sdb, logical block 33655294, async page read
[626202.518346] Buffer I/O error on dev sdb, logical block 33655294, async page read
[626204.752395] Buffer I/O error on dev sdb, logical block 33655294, async page read
[626206.975441] Buffer I/O error on dev sdb, logical block 33655294, async page read
[626209.389263] Buffer I/O error on dev sdb, logical block 33655320, async page read
[626211.623437] Buffer I/O error on dev sdb, logical block 33655320, async page read
[626213.846358] Buffer I/O error on dev sdb, logical block 33655320, async page read
[626216.069405] Buffer I/O error on dev sdb, logical block 33655320, async page read
[626218.336333] Buffer I/O error on dev sdb, logical block 33655321, async page read
[626220.570507] Buffer I/O error on dev sdb, logical block 33655321, async page read
[626222.804554] Buffer I/O error on dev sdb, logical block 33655321, async page read
[626225.027477] Buffer I/O error on dev sdb, logical block 33655321, async page read
[626227.393667] Buffer I/O error on dev sdb, logical block 33655322, async page read
[626229.725105] Buffer I/O error on dev sdb, logical block 33655322, async page read
[626232.059666] Buffer I/O error on dev sdb, logical block 33655322, async page read
[626234.392727] Buffer I/O error on dev sdb, logical block 33655322, async page read
[626236.659780] Buffer I/O error on dev sdb, logical block 33655402, async page read
[626238.879451] Buffer I/O error on dev sdb, logical block 33655402, async page read
[626241.080494] Buffer I/O error on dev sdb, logical block 33655402, async page read
[626243.336545] Buffer I/O error on dev sdb, logical block 33655402, async page read
[626246.883519] Buffer I/O error on dev sdb, logical block 33655424, async page read
[626249.106565] Buffer I/O error on dev sdb, logical block 33655424, async page read
[626251.329613] Buffer I/O error on dev sdb, logical block 33655424, async page read
[626253.552660] Buffer I/O error on dev sdb, logical block 33655424, async page read
[626255.885597] Buffer I/O error on dev sdb, logical block 33655425, async page read
[626259.099400] Buffer I/O error on dev sdb, logical block 33655425, async page read
[626261.322197] Buffer I/O error on dev sdb, logical block 33655425, async page read
[626263.567246] Buffer I/O error on dev sdb, logical block 33655425, async page read
[626272.018999] Buffer I/O error on dev sdb, logical block 33668443, async page read
[626274.259549] Buffer I/O error on dev sdb, logical block 33668443, async page read
[626276.504473] Buffer I/O error on dev sdb, logical block 33668443, async page read
[626278.738646] Buffer I/O error on dev sdb, logical block 33668443, async page read
[626281.175347] Buffer I/O error on dev sdb, logical block 33668444, async page read
[626283.382891] Buffer I/O error on dev sdb, logical block 33668444, async page read
[626285.605938] Buffer I/O error on dev sdb, logical block 33668444, async page read
[626288.005010] Buffer I/O error on dev sdb, logical block 33668444, async page read
[626292.455354] Buffer I/O error on dev sdb, logical block 33668485, async page read
[626294.688776] Buffer I/O error on dev sdb, logical block 33668485, async page read
[626296.922699] Buffer I/O error on dev sdb, logical block 33668485, async page read
[626299.145746] Buffer I/O error on dev sdb, logical block 33668485, async page read
[626301.369418] Buffer I/O error on dev sdb, logical block 33668558, async page read
[626303.589090] Buffer I/O error on dev sdb, logical block 33668558, async page read
[626305.790009] Buffer I/O error on dev sdb, logical block 33668558, async page read
[626308.024058] Buffer I/O error on dev sdb, logical block 33668558, async page read
[626310.371619] Buffer I/O error on dev sdb, logical block 33668589, async page read
[626312.594042] Buffer I/O error on dev sdb, logical block 33668589, async page read
[626314.827964] Buffer I/O error on dev sdb, logical block 33668589, async page read
[626318.779617] Buffer I/O error on dev sdb, logical block 33668606, async page read
[626320.992537] Buffer I/O error on dev sdb, logical block 33668606, async page read
[626323.215584] Buffer I/O error on dev sdb, logical block 33668606, async page read
[626325.449632] Buffer I/O error on dev sdb, logical block 33668606, async page read
[626327.759440] Buffer I/O error on dev sdb, logical block 33668692, async page read
[626330.146635] Buffer I/O error on dev sdb, logical block 33668692, async page read
[626332.381058] Buffer I/O error on dev sdb, logical block 33668692, async page read
[626334.714120] Buffer I/O error on dev sdb, logical block 33668692, async page read
[626336.981922] Buffer I/O error on dev sdb, logical block 33668693, async page read
[626339.237474] Buffer I/O error on dev sdb, logical block 33668693, async page read
[626341.460396] Buffer I/O error on dev sdb, logical block 33668693, async page read
[626343.694443] Buffer I/O error on dev sdb, logical block 33668693, async page read
[626348.415950] Buffer I/O error on dev sdb, logical block 33668797, async page read
[626350.649623] Buffer I/O error on dev sdb, logical block 33668797, async page read
[626352.905674] Buffer I/O error on dev sdb, logical block 33668797, async page read
[626355.139596] Buffer I/O error on dev sdb, logical block 33668797, async page read
[626357.506162] Buffer I/O error on dev sdb, logical block 33668798, async page read
[626359.838973] Buffer I/O error on dev sdb, logical block 33668798, async page read
[626362.138531] Buffer I/O error on dev sdb, logical block 33668798, async page read
[626364.493595] Buffer I/O error on dev sdb, logical block 33668798, async page read
[626366.761398] Buffer I/O error on dev sdb, logical block 33668825, async page read
[626368.986570] Buffer I/O error on dev sdb, logical block 33668825, async page read
[626371.165611] Buffer I/O error on dev sdb, logical block 33668825, async page read
[626373.399534] Buffer I/O error on dev sdb, logical block 33668825, async page read
[626375.774727] Buffer I/O error on dev sdb, logical block 33668826, async page read
[626378.109538] Buffer I/O error on dev sdb, logical block 33668826, async page read
[626380.464604] Buffer I/O error on dev sdb, logical block 33668826, async page read
[626382.819668] Buffer I/O error on dev sdb, logical block 33668826, async page read
[626385.106972] Buffer I/O error on dev sdb, logical block 33668901, async page read
[626387.340521] Buffer I/O error on dev sdb, logical block 33668901, async page read
[626389.563568] Buffer I/O error on dev sdb, logical block 33668901, async page read
[626391.797616] Buffer I/O error on dev sdb, logical block 33668901, async page read
[626394.076046] Buffer I/O error on dev sdb, logical block 33668902, async page read
[626396.287715] Buffer I/O error on dev sdb, logical block 33668902, async page read
[626398.499761] Buffer I/O error on dev sdb, logical block 33668902, async page read
[626400.744686] Buffer I/O error on dev sdb, logical block 33668902, async page read
[626403.606317] Buffer I/O error on dev sdb, logical block 33669013, async page read
[626405.950755] Buffer I/O error on dev sdb, logical block 33669013, async page read
[626408.294443] Buffer I/O error on dev sdb, logical block 33669013, async page read
[626410.638506] Buffer I/O error on dev sdb, logical block 33669013, async page read
[626413.037575] Buffer I/O error on dev sdb, logical block 33669028, async page read
[626415.262373] Buffer I/O error on dev sdb, logical block 33669028, async page read
[626417.518425] Buffer I/O error on dev sdb, logical block 33669028, async page read
[626419.763350] Buffer I/O error on dev sdb, logical block 33669028, async page read
[626424.185689] Buffer I/O error on dev sdb, logical block 33669030, async page read
[626426.377607] Buffer I/O error on dev sdb, logical block 33669030, async page read
[626428.611655] Buffer I/O error on dev sdb, logical block 33669030, async page read
[626430.845704] Buffer I/O error on dev sdb, logical block 33669030, async page read
[626433.110756] Buffer I/O error on dev sdb, logical block 33669133, async page read
[626435.346679] Buffer I/O error on dev sdb, logical block 33669133, async page read
[626437.591729] Buffer I/O error on dev sdb, logical block 33669133, async page read
[626439.847781] Buffer I/O error on dev sdb, logical block 33669133, async page read
[626442.729164] Buffer I/O error on dev sdb, logical block 33669232, async page read
[626444.953708] Buffer I/O error on dev sdb, logical block 33669232, async page read
[626447.187761] Buffer I/O error on dev sdb, logical block 33669232, async page read
[636305.218098] Buffer I/O error on dev sdb, logical block 34404189, async page read
[636307.452022] Buffer I/O error on dev sdb, logical block 34404189, async page read
[636309.686070] Buffer I/O error on dev sdb, logical block 34404189, async page read
[636311.942121] Buffer I/O error on dev sdb, logical block 34404189, async page read
[646550.880681] Buffer I/O error on dev sdb, logical block 34403678, async page read
[646553.125732] Buffer I/O error on dev sdb, logical block 34403678, async page read
[646555.370656] Buffer I/O error on dev sdb, logical block 34403678, async page read
[646557.626708] Buffer I/O error on dev sdb, logical block 34403678, async page read
[702113.172093] Buffer I/O error on dev sdb, logical block 34403678, async page read
[702115.428019] Buffer I/O error on dev sdb, logical block 34403678, async page read
[702117.651066] Buffer I/O error on dev sdb, logical block 34403678, async page read
[702119.885239] Buffer I/O error on dev sdb, logical block 34403678, async page read
[702124.650249] Buffer I/O error on dev sdb, logical block 34404189, async page read
[702126.895299] Buffer I/O error on dev sdb, logical block 34404189, async page read
[702129.096343] Buffer I/O error on dev sdb, logical block 34404189, async page read
[702131.319390] Buffer I/O error on dev sdb, logical block 34404189, async page read
All goes as it should go, and the testing software fails as expected at the first try.
Now it makes sense, and psychologically it is reassuring.
Writing pattern 0xaa, Reading and comparing: ...
           block 33649053: not equal to pattern 0xaa
Just, there are many more badblocks. More than what reported on the previous computer.
I am going to trash both these two piece of garbage, both hard drives (already wiped) and the old laptop.
Just, it's amazing how electronic devices behave when they age.
Offline LeonR
  • Country: br
  • PC hardware enthusiast
Hard drives have moving parts. They are all going to fail, one day of another. Sometimes they go poof without warnings, SMART errors (if you look at those up regularly) or Windows CHKDSK messages. Always keep important files backed up regularly.  :-+
For HDD surface test tools I recommend the one provided by your drive manufacturer (they all provide a free utility, just go at their websites) or HD Tune.
