Author Topic: EEVblog #1144 - Padauk Programmer Reverse Engineering  (Read 401970 times)
serisman and 4 Guests are viewing this topic.
Online serisman
Re: EEVblog #1144 - Padauk Programmer Reverse Engineering
« Reply #1025 on: July 06, 2020, 05:20:37 pm »
I have created a PR [1] that introduces a new design for https://free-pdk.github.io/ and also integrates the pinout diagrams as well as an overview of the many different free-pdk repositories. There is a lot of room for further improvements, but this should get the ball rolling when it comes to tutorials and more detailed instructions. Adding pages is as easy as adding new markdown files (no more HTML :)).
I have not yet added any information on the SDCC examples and headers, since that is an ongoing discussion.
[1] https://github.com/free-pdk/free-pdk.github.io/pull/3
It's live now, thanks a lot!
Now it's much easier to contribute some much needed documentation. Everyone, feel free to contribute. You can directly submit pull-requests here: https://github.com/free-pdk/free-pdk.github.io/tree/development
I will add a section about ordering the lite-programmer once I received and validated the r1 samples - they are being made right now.
Excellent!  Nice work!
A few things I noticed while playing around with the pinout diagrams:
I also just submitted PRs for:
« Last Edit: July 06, 2020, 08:15:13 pm by serisman »
Offline tim_
« Reply #1026 on: July 06, 2020, 08:51:47 pm »
Just as a side note: How can the PMS150C be so cheap?
The image below shows a die size comparison between a PIC12C508 (sorry, wrong title) and a PMS150C. I don't know the actual dimension of the PIC die - the image is from Zeptobars.
One can, however, use the size of the bondbands to scale the images relative to each other. The PMS150C is around 10x smaller than the PIC, thanks to newer technology.
Edit: Source of the images
- PIC: https://zeptobars.com/en/read/PIC12C508-PIC-Microchip
- Padauk: https://electronupdate.blogspot.com/2019/09/3-cent-microprocessor-teardow-paduak.html
« Last Edit: July 06, 2020, 09:06:42 pm by tim_ »
Online serisman
« Reply #1027 on: July 06, 2020, 09:32:13 pm »
From the 'new' website:
SDCC Integration
Padauk themselves use a custom programming language that looks a bit like C for programming the µCs that is compiled by their proprietary IDE. While code created using this custom language can be programmed using the Easy PDK Programmer, we still recommend using SDCC, especially if you want support for proper C code. Should you be interested in code samples in that custom language, look at free-pdk/simple-pdk-code-examples.
That highlighted part is actually incorrect.
Here is a PR to fix that: https://github.com/free-pdk/free-pdk.github.io/pull/8
I also submitted a PR to add ROM and RAM sizes: https://github.com/free-pdk/free-pdk.github.io/pull/6
We might want to turn that section into a table and have columns for the major peripherals (i.e. Instruction Set, ROM Size/Type, RAM Size, ADC, PWM, etc...)
The following users thanked this post: icraftcrafts
Offline cmfcmf
    • github.com/cmfcmf
« Reply #1028 on: July 06, 2020, 10:38:49 pm »
Nice work with the PRs.
My confusion with the drive/sink currents in the PFS154 datasheet arose from the fact that it listed the drive/sink currents differently than the PFS173 datasheet:
PFS154PFS173
"negative drive current", e.g. -5mA"positive drive current, e.g. 5mA
"low" vs. "normal" current"normal" vs. "strong" current
But, looking at your PR, I gathered that both seem to mean the same thing.
Centering the diagrams is on my TODO list, however it currently breaks the image download buttons.
Online serisman
« Reply #1029 on: July 06, 2020, 10:44:52 pm »
PFS154PFS173
Yeah, I'm not sure why they state drive current as '-' in some datasheets but not others.
The low/normal vs. normal/strong has to do with the FUSE settings.  Some have an option to enable weaker IO drive, some have an option to enable stronger IO drive.
 :-+  I took a quick look, but noticed these diagrams use html tables with varying width columns, so I gave up pretty quick.  Hopefully there is a clean way to do it.
EDIT:  Maybe the table can span diagrams instead of creating a new table per diagram?  Then, the column widths would line up between diagrams, and the entire table could be centered.  Not sure what that does to the image download though.
« Last Edit: July 06, 2020, 11:01:06 pm by serisman »
Online serisman
« Reply #1030 on: July 07, 2020, 08:28:58 am »
Sharing this here, in case anyone else would find it useful:
I threw together a quick-n-dirty node.js app that can 'rip' the Padauk IDE's .INC files into a more consumable .json form:
And, I used it to 'rip' the PDK .INC files for a bunch of the common devices that we are working with (all the .json files in the root of the repo).
https://github.com/serisman/pdk-device-json
Among other things, this should come in handy for auto-generating the pdk-include files, whenever we decide on the final format.
It also could come in handy to auto-generate documentation, or comparison tables, or just to manually compare two different devices through a compare tool, or whatever.
« Last Edit: July 07, 2020, 08:32:58 am by serisman »
Offline NickE
  • Country: hu
« Reply #1031 on: July 07, 2020, 02:37:54 pm »
In this description there is a mistake at STT16 M | LDT16 M | IDXM M,A | IDXM A,M instructions:
https://free-pdk.github.io/PADAUK_FPPA_14_bit_instruction_set.html
000011c<7-bit MEM addr>c  // 7+7+1=15 bit, but this is only 14 bit device
Offline LovelyA72
  • Kashikoma from Massachusetts!
« Reply #1032 on: July 08, 2020, 12:11:44 am »
When will the Mini-pill programmer's kicad file available? It'll be fun to build one because it's such an impressive design!
« Last Edit: July 08, 2020, 12:16:26 am by LovelyA72 »
Kashikoma!
Online serisman
« Reply #1033 on: July 08, 2020, 12:19:46 am »
When will the Mini-pill programmer available? It'll be fun to build one because it's such an impressive design!
Thanks for showing interest!  Indeed, it is a kinda fun build to do!  Probably not a good project from someone that hasn't already done some surface mount soldering before, though.  The STM32 in particular can be a bit more challenging than other parts.
The STM32 mini-pill board is already 'available':
I still have to post the design files for the Padauk programmer top-hat, but the PCBs are already available from OSHPARK (https://oshpark.com/shared_projects/z5EAm6HO).  Or you can find the gerber files from my very first post (https://www.eevblog.com/forum/blog/eevblog-1144-padauk-programmer-reverse-engineering/msg3091725/#msg3091725).
The following users thanked this post: LovelyA72
Offline LovelyA72
« Reply #1034 on: July 08, 2020, 12:38:54 am »
Since all of these padauk micros are surface mounted, I learned quite a lot of surface mounting soldering during the last two months. :-+
Kashikoma!
Online serisman
« Reply #1035 on: July 08, 2020, 01:54:31 am »
Excellent!  :-+
Although an LQFP-48 is quite a bit more difficult than a SOP-16.  But, definitely give it a try.  With a decent soldering iron, and some patience, it is fairly manageable.  Some good flux, de-soldering braid, and a magnifying lens will come in handy as well.
Just don't do what I did on the first one.  After carefully tacking down the first corner and repositioning the board so I could tack down the second corner, my OCD got the better of me and without thinking about it, I put my finger on the STM32 to 'clean' off the flux residue.  Let's just say, the pins were never straight again.  |O  I still might be able to fix it, but it was easier/quicker to just grab a spare pcb/ic and try again, this time even more carefullly.
So, maybe a good idea to make sure you have a spare STM32 as well.
Online serisman
« Reply #1036 on: July 08, 2020, 03:15:44 am »
Ok, boo-boo all fixed.  I was able to pull off the IC with hot air, VERY carefully straighten out the bent pins, and tack it back on with hot air again.  I went around and flooded all the pins with solder, and used wick to pull the excess back off.  Some of the pins are still a little out of shape, but as far as I can tell they are all making contact and no shorts (I did clean up the joints a bit further after taking the 'After' picture).  I finished assembly of the rest of the board and can at least confirm that the USB bootloader works.
Before:
1018974-0
After:
1018978-1
Offline js_12345678_55AA
  • Country: ht
« Reply #1037 on: July 08, 2020, 03:31:07 pm »
I created a new showcase repository which will receive complete and useful projects:
https://github.com/free-pdk/easy-pdk-showcase-projects
I spent some time to also create pc emulation code which uses the same (main) source code for emulation. This should make modifications / implementing new features much easier.
All projects are fully self contained and do not have any external dependencies. You only need to install the latest SDCC compiler and you are ready to go.
Projects so far:
* WS2812b RGB LED 16x16 matrix animation demo (inspired from here: https://github.com/joshgerdes/arduino-led-matrix):
https://github.com/free-pdk/easy-pdk-showcase-projects/tree/master/ws2812animation16x16
- universal WS2812B output routine (adopted from cpldcpu's implementation)
- on the fly RLE image decoder
- image packer which compresses the 16x16 RGB images to palette based RLE encoded images (compression factor 15:1)
  The original project for Arduino nano produced apx. 40kB of code. The compressed image version for PADAUK MCUs requires less than 2.5kB.
- the complete project fits into 3K ICs like the PFS173. Reduced versions for 2K and 1K ICs are created automatically (some images/animations left out).
- targets for PMS150C, PFS154, PFS172, PFS173
- emulation project for pc (Linux/MacOS/Windows) - have a look in the emulation directory
* Polyphonic sound player emulating the 4 NES sound and playing a famous tune (ported from: https://bisqwit.iki.fi/jutut/kuvat/programming_examples/pic/):
https://github.com/free-pdk/easy-pdk-showcase-projects/tree/master/polysound
- stand alone 4 channel NES style music player (requires no extra hardware other than a speaker)
- requires 3K IC like PFS173
More to come soon  8)
WS2812 16x16 matrix demo:
JS
« Last Edit: July 08, 2020, 03:52:24 pm by js_12345678_55AA »
Easy PDK programmer and more: https://free-pdk.github.io
  • Country: ht
« Reply #1038 on: July 08, 2020, 03:45:34 pm »
This is a bit tricky to explain...
The "7 bit memory address" label is correct, just the last bit is ignored and reused as "c".
This means the address is 7 bit with the last bit set to 0 (You only can address every second byte).
I tried to explain this in the comment for the instructions: "(last bit of M set to 0, M must be word aligned)"
JS
The following users thanked this post: NickE
Offline ali_asadzadeh
« Reply #1039 on: July 09, 2020, 06:48:50 am »
Thanks for sharing JS 8) :-+
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Online serisman
« Reply #1040 on: July 09, 2020, 07:33:38 am »
Yes, agreed!
That polysound example is simply amazing.
I may have to pick up one of those 16x16 WS2812B matrix displays as well, cause that other project looks like fun too.
Both of these projects make me wonder how easy it would be to combine them with an inexpensive NOR flash IC (i.e. W25Q80 or similar) to greatly increase the quantity/duration of the sounds/patterns and allow them to be changed even without having to re-compile.
« Last Edit: July 09, 2020, 07:35:47 am by serisman »
Online serisman
« Reply #1041 on: July 09, 2020, 07:40:53 am »
FYI,
I cleaned up some of the code and comments in the (in-progress) free-pdk-examples repo (https://github.com/free-pdk/free-pdk-examples) and added README files to the first three examples.
The repo is now also more self-sufficient (it has copies of all the required include files instead of using git submodules).
More to come over the next few days.
I still need to give the repo a proper license, make sure all 'original authors' are properly referenced, clean up the serial code a bit, add more README files, and write the rest of the intended examples.
  • Country: ht
« Reply #1042 on: July 09, 2020, 08:30:01 am »
I already completed a project with external SPI flash - a good quality audio player (plays 8 bit @32kHz).
I created a PCB which holds an 8 pin PADAUK (e.g. PMS150C/PFS154/PFS173) and added a 16MBit SPI flash and a small class D amplifier.
I use it inside of my hackintosh to play the startup chime immediately after a power cycle.  8)
In order to release this project I still need to write the pc emulation part (not so hard now since I got perfect audio emulation working in polysound already).
I also added a microSD card socket to the PCB mentioned above and want to try to use this as external storage (most likely without file system since we simply don't have enough memory).
JS
Offline tim_
« Reply #1043 on: July 09, 2020, 09:30:09 am »
Thanks to @cmfcmf we now have a list of community projects on https://free-pdk.github.io/ (scroll to bottom). (Thanks again!)
1019710-0
The list is automatically populated by a Github search. To be included, please do the following:
 - Add "padauk" as a topic for your repository
 - Add a project description
« Last Edit: July 09, 2020, 09:32:47 am by tim_ »
« Reply #1044 on: July 09, 2020, 11:57:14 am »
A video Demo of some sort would be very nice 8) ;)
Offline NickE
  • Country: hu
« Reply #1045 on: July 09, 2020, 01:43:38 pm »
Thanks.
Another confusing instructions are T0SN M.n | T1SN M.n | SET0 M.n | SET1 M.n. The table shows 6-bit MEM addr, but for M address you need 7 bit address to be able to address the whole memory. (128bytes PFS154) For IO space needs 6 bit because it is only 64bytes.
I wrote a pure assembler, finished now, testing is in progress. That's why I need to know how every instruction works.
  • Country: ht
« Reply #1046 on: July 09, 2020, 01:58:33 pm »
Thanks.
This is also correct and is indeed a limitation of the processor. Those instructions only can address the lower address space. It's also mentioned in the data sheets.
JS
  • Country: ht
« Reply #1047 on: July 09, 2020, 02:22:47 pm »
The audio player showcase project is available now: https://github.com/free-pdk/easy-pdk-showcase-projects/tree/master/audioplayer
What kind of video demo? A video from my hackintosh (intel NUC) starting up?
JS
Offline NickE
  • Country: hu
« Reply #1048 on: July 09, 2020, 03:36:26 pm »
I experiance so many strange things around this MCU :D
I run my PFS154 on ILRC but according to my calculation it runs approx. at 143kHz. I wrote a loop with 97nop + 1 goto + 1 xor (to invert led), that's 100 instruction, the execution of the 100 instruction takes 700us, so to execute 1 instruction takes 7us. I don't find any explanation for this. According to the datasheet it should run at 55kHz. I know ILRC is not accurate but I did not expect 143kHz.
.rom
wdreset
set0  clkmd.1
set1 pac.0
mov a,#01h
label1:
xor   pa,a
nop
nop
        97 nops total
        goto label1
Offline spth
« Reply #1049 on: July 09, 2020, 04:58:32 pm »
Did you properly setup ILRC using the factory calibration value?
Philipp
