Author Topic: Rigol 5074 vs Siglent SDS2104X Plus vs Keysight DSOX1204G  (Read 22681 times)
Offline nichristTopic starter
  • Country: gr
« on: February 09, 2021, 08:37:39 pm »
The three models are extensively reviewed in the past but I think now that are in the mature phase it would be helpful from end users, or any others with relative knowledge, to point out their positives and negatives. For a starting point I did a research and I made a comparison chart.
                       Rigol 5074                               Siglent SDS2104X Plus                Keysight DSOX1204G
                  4 channels                                4 channels                             4 channels
Bandwidth   70MHz                                        100MHz                                     70MHz
Sample rate   8GSa/s 1ch, 4GSa/s per 2ch             2GSa/s 2ch, 1GSa/s per 4ch         2 GSa/s (1 or 1/2 channel operation)
Sample rate   2GSa/s per 4ch                        1 GSa/s (3 or 4 chl operation)
Mem depth      100Mpoints 1ch, 50 per 2ch        200Mpoints per 2ch             2 Mpoints (1 or 1/2 channel operation)
                   25Mpoints per 4ch                        100Mpoints per 4ch             1 Mpoints (3 or 4 channel operation)
WF update    500,000 waveforms/sec                480,000 waveforms/sec           200,000 waveforms/sec
Segmented memory   ?                                         ?                                       Yes
Resolution            8bit                                            8bit (10bit mode)                8bit
Probes           4 Passive Probes 350 MHz      4 Passive Probes 200 MHz      4 Passive Probes 200 MHz
WaveGen   2 Channel 25MHz                          1 Channel 50MHz +-3V      1 Channel 20MHz
Bode Plot                    Yes?                                              Yes                                Yes
Serial prot   I²C, SPI, UART/RS-232, CAN, LIN   I²C, SPI, RS232/UART, CAN, LIN         I²C, SPI, UART/RS-232, CAN, LIN
FFT                             Yes                                             Yes 2Mpts                        Yes
Display            9'' capacitive multi-touch screen   10.1'' TFT LCD touch (1024x600)     7-inch TFT LCD WVGA
Connectivity   USB, LAN, and HDMI                              USB, LAN                         USB 2.0 (host anddevice), LAN
Noise floor        (Not good)?                          80μV rms at 500MHz BW         ?
Cost (included 19%VAT)
                             1.050 €                                                  1.430 €                    1.430 €
Regards
Re: Rigol 5074 vs Siglent SDS2104X Plus vs Keysight DSOX1204G
« Reply #1 on: February 09, 2021, 08:51:11 pm »
Additional comments
SDS2000X Plus models are a 500 MHz design.
SDS2104X Plus proven -3dB BW is ~185 MHz.
Current promotion includes some free options:
https://www.siglenteu.com/news-article/save-up-to-e1464-with-a-new-sds2000x-plus-oscilloscope-and-option-bundle/
The following users thanked this post: nichrist
Offline tv84
  • Country: pt
« Reply #2 on: February 09, 2021, 08:59:57 pm »
Dave should insert in the forum a "stock ticker" bar with the arguments of each scope so that we are always update...  ::)
The following users thanked this post: nctnico
« Reply #3 on: February 09, 2021, 10:09:00 pm »
That chart completely ignores the fact that everybody around here hacks them to unlock more features (eg, 350MHz bandwidth)
Offline Elasia
« Reply #4 on: February 09, 2021, 11:07:24 pm »
A hacked unit is more likely to be at full bandwidth ie 550-600MHz -3db... 350 is just a marketing stunt targeted at business
Online nctnico
« Reply #5 on: February 09, 2021, 11:37:37 pm »
I guess you mean the Siglent? The Rigol 5000 is useless for HF without 50 Ohm inputs.
The following users thanked this post: Tom45
Offline Noy
« Reply #6 on: February 10, 2021, 12:08:22 am »
The siglent has no real 50 ohm input for what i know..
Its only a 50 ohm termination resistor..
Not a lot better than an external through termination on a rigol.
Offline mawyatt
« Reply #7 on: February 10, 2021, 02:36:16 am »
The Siglent SDS2102X Plus we have (enabled with the help of folks on here  :) ) has a return loss of better than -20dB to >500MHz, it's -38dB @ 100MHz (SWR 1.02), -41dB @ 200MHz (SWR 1.01), and -29dB @ 350MHz (SWR 1.07). Measured -3dB bandwidth is >600MHz, not too bad an input IMO, and certainly easier than fiddling with external BNC terminations!!
Best,
« Last Edit: February 10, 2021, 02:43:30 am by mawyatt »
~Wyatt Labs by Mike~
The following users thanked this post: Performa01
Online DeepLink
« Reply #8 on: February 10, 2021, 07:10:52 am »
I tried several scope's before deciding on a Siglent SDS2104X+ (and did transform that into a SDS2354X+ incl. all options)
Each have their own requirements
Mine selection list is here
Screen.
The Rigol was not very bright
The Keysight was only 7" and as I'm getting older I wanted something bigger
(Even tried the R&S RTB2000, but it had so much reflection)
The Siglent has a good screen, but I would have liked a 12"
Options.
Rigol and Siglent has the possibility to unlock it all
Keysight is quite expensive to increase BW or options
Rigol and Siglent can be upgarded with 16 digital channels (not possible on the Keysight)
User Interface
Rigol was not very polished and I found it to be a little "messy"
Siglent is much more my way (but I always will prefer separate controls for each channel)
Siglent's speed is ok, but not snappy (as my old HP 54645D)
Probes
The Rigol and Keysight are missing probe detection interface
As I had some Agilent probes, I wanted my scope to detect it properly
The probes on entry level scope are not that good from any brand
I ended up with the Siglent SDS2104X+ and have no regrets so far (still learning)
(A Keysight MSOX4000 would be a dream scope for me, but totally out of reach)
Offline Karel
« Reply #9 on: February 10, 2021, 09:25:17 am »
In that price range I would go for a Rohde & Schwarz RTB2002 (or a RTB2004).
Online 2N3055
  • Country: hr
« Reply #10 on: February 10, 2021, 09:54:04 am »
And pray tell, what would that price range be? 3000€? 2000€ 1000€ ?
Offline Karel
« Reply #11 on: February 10, 2021, 10:17:31 am »
RTB-2002     1559 €   VAT included
RTB-2004      2142 €    VAT included     ok, this one is outside of the price range  8)
Online 2N3055
  • Country: hr
« Reply #12 on: February 10, 2021, 11:14:11 am »
RTB2002 is a 2 ch 70MHz scope without segmented memory, protocol decodes, only 10 MS memory per channel, no digital channels, no signal generator, no bode plot option....
So to compare it with siglent SDS2104X+ you need to buy RTB-2004 (for 4ch) , 100 MHz bandwith upgrade (380€) and option bundle (1500 €).. A 4000 € worth... In which case you are better of just buying full option package RTB2K-COM4 SA for 4050€..
Or a Siglent SDS5034X for a one class up scope, for 500€ less, which buys you decent enough standalone AWG, that you can use for bode plots up to 120 MHz with the scope.....
R&S is a legend of a company...
But despite that, RTB2000 series is fancy looking but completely unremarkable scope with too high price..
It should start at 100 MHz (keeping the price of 70MHz) and have full option bundle included in price to be competitive. Also, not having 50 Ohm inputs is just lame for a 350 MHz scope.
Just look at their marketing that is completely untrue :"10 Msample memory depth is available on each channel if all channels are active. When interleaved, 20 Msample are available. That is 10 times more than comparable oscilloscopes offer. This captures longer signal sequences for more analysis results."
That is actually exactly opposite. Several cheaper scopes have 10 times MORE memory than that....
In last few years since they released 2000/3000/4000 series, many things happened. They need to adapt and change or perish...
Being a legend means you were once great, old glory stories.
My biggest regret is that R&S, in their corporate narcissism and greed killed off HAMEG brand.
They should have kept it and use that to make and sell affordable but good equipment. That way they could have kept segmentation to normal/premium markets, but still provide decent instruments.
The way it is now, they are deliberately giving you as little as possible... So you have reason to buy higher models...
And it might be working for them on their primary market. Same as Fluke, who targets industry and really don't care about other markets.
But in general, open market R&S is not competitive at all with 2000 series, not until you  reach 3000/4000 series that  compete in different area... And that is not set in stone either, and depends on many factors..
Offline tv84
  • Country: pt
« Reply #13 on: February 10, 2021, 01:06:34 pm »
They wanted to say That is 10 times LOWER than comparable oscilloscopes offer.
The following users thanked this post: egonotto, 2N3055
Online nctnico
« Reply #14 on: February 10, 2021, 01:40:49 pm »
That depends on how you compare. There are sveral things that make the RTB2000 series way better compared to the other oscilloscopes listed. Take full memory decoding and the way decoding is displayed for example. Or 10 bit resolution, high resolution screen, good user interface. If you are going to spend serious money then it is a good idea to see what else is out there. And it is not entirely true that the RTB2000 offers less memory. With segmented recording on it offers up to 320Msamples per channel. That is 3 times more compared to to the Siglent (which has the deepest memory of the scopes mentioned by the OP). You just can't use it for a single trace which is a bit of a bummer.
Online 2N3055
  • Country: hr
« Reply #15 on: February 10, 2021, 03:27:01 pm »
I know exactly how I compared. RTB-2004 is 70 MHz 4 CH scope without anything. Anything. No segmented memory at all, no decodes of anything, no signal gen, no bode plot. Nothing.
With 10 Mpoints per chanel (20 interleaved). It literally is less capable than Micsig STO1104E.
For low price of €2380.
Siglent SDS2104X Plus has 100 MHz bandwidth, it comes fully unlocked (except MSO license and hardware), and has 100 Mpoint/CH (200 interleaved). It also has more memory in segmented mod, don't know how much  now...
For whooping €1427...
Once you unlock R&S to have same set of capability (except memory, that will always be 10 times less than SDS2000X+) RTB2004 will cost more than €4200..
It is that simple. Nothing complicated with that.
For €4200 you can buy better scope than RTB2000.. Or you can buy 3 (that's three) SDS2104X+ and equip 3 workplaces with a scope....
While I do agree with you that there are some things on RTB2000 user interface that are (at the moment) more polished than they are on SDS2000X+ now, there is nothing justifying three times the price...
RTB2000 outpriced itself from a category. I consider it to be a failed model. It is not capable enough to be fully pro, and too expensive for what it is..
Offline tv84
  • Country: pt
« Reply #16 on: February 10, 2021, 03:36:47 pm »
For RTB to be competitive, we would also have to go the LIY route.  (LIY = license it yourself)
Online nctnico
« Reply #17 on: February 10, 2021, 03:49:35 pm »
That €1427 is wasted if the oscilloscope doesn't do what you need. Better spend 4k (RTB2k + option bundle) on a good instrument that does what you need from the start rather than spending 5.5k (1.5k for a POS + 4k for a good tool). Been there, done that. In the end you need a tool that works for you; if the RTB2k series is a better fit then the money is well spend. Not saying the RTB2k is always a better scope, it is just an example here to show price isn't everything.
Every time I look at Rigol and Siglent equipment there is something missing so I end up spending 'more' for a piece of equipment that actually fits my needs. Buying equipment just for the sake of being cheap just isn't a good idea. If those three SDS2104X+ from your example aren't up to the task then they are an utter waste of money.
« Last Edit: February 10, 2021, 08:31:04 pm by nctnico »
The following users thanked this post: Fungus, bgm370
Online 2N3055
  • Country: hr
« Reply #18 on: February 10, 2021, 09:57:23 pm »
SDS2000X+ is BETTER scope than RTB2000.....
And cheaper..
RTB2000 is shining example of how today with western products more money doesn't necessarily mean better.
RTB2000 is typical of today western product: lot of style, design, big names  and blah performance.
R&S 3000 and 4000 series (and up of course) are serious, powerful products.
RTB2000 is not.. Just pretty, and fancy.
Online nctnico
« Reply #19 on: February 10, 2021, 11:24:38 pm »
Buzzzz wrong. Compared to the SDS2000X+ the RTB2000 has better memory management, full memory decoding, a higher resolution screen, on screen annotations, better display for protocol decoding, 10 bit ADC resolution, better UI and there are probably a few things I'm leaving out. In the end it just comes down to what is important to the prospective buyer.
For me personally the clumsy memory management in the Siglent scope and short memory in the Keysight scope are a hard fail so to me those scopes have zero value for money.
BTW I don't see how 'western world' comes into this discussion. You are aware R&S gear is made in eastern Europe?
« Last Edit: February 10, 2021, 11:30:23 pm by nctnico »
Offline egonotto
« Reply #20 on: February 10, 2021, 11:38:34 pm »
Hello
nctnico wrote: "And it is not entirely true that the RTB2000 offers less memory. With segmented recording on it offers up to 320Msamples per channel. That is 3 times more compared to to the Siglent"
The 320 Msamples are in interleaved mode. But a sample is as I know 16 Bit.
How is this by Siglent? There a sample is only 8 Bit, but how much memory is in segmented mode?
Best regards
egonotto
Online 2N3055
  • Country: hr
« Reply #21 on: February 10, 2021, 11:50:44 pm »
Eye candy and your bias.. Irrelevant to non Nicos of this world. Siglent are just fine if you use them after reading user manual. And Keysight scopes have short memory, which makes them bad for some uses. But they have a mile long list of capabilities that R&S RTM3000 doesn't have (like search on serial protocols, many measurements) that made me buy MSOX3104T over RTM3000.
Seriously?  Berlin wall fell long time ago... But that statement might explain your struggle to change with the changing world.... ^-^
Online 2N3055
  • Country: hr
« Reply #22 on: February 10, 2021, 11:53:01 pm »
Hello
Best regards
egonotto
R&S 2000/3000/4000 have 10 Bit converters..
I don't have SDS2000X+ here so I can't check and tell you...
Offline mawyatt
« Reply #23 on: February 11, 2021, 12:52:38 am »
The SDS2104X Plus has 8 bit core ADCs that are expanded with software for higher resolutions up to 100MHz, which works surprisingly well IMO.
I've been using scopes probably longer than most here have been alive, over 60 years, and can say without a doubt the Siglent SDS2102X Plus is the most impressive value instrument we have ever owned. Don't have the other DSOs mentioned, so won't comment, but this Siglent scope continues to impress in every way and use, just like the post above about how good the input vertical amplifiers are. Everything about this DSO impresses, and leaves one feeling that it's a much more expensive instrument, from a much higher category, than the price tag indicates.
Best,
The following users thanked this post: egonotto, 2N3055, nichrist
Offline normi
« Reply #24 on: March 29, 2021, 02:04:39 am »
I am in the hunt for a new scope to upgrade from my DS1052E. I have been going over all the various posts on the entire forum regarding the Rigol 5074 vs Siglent SDS2104X and while it is clear that there are persons with bias on both sides, my objective conclusion is the following.
1.   IMHO the main difference between the scopes is that the Siglent has a quieter front end and a more attractive GUI,  VS the Rigol has significantly more sample rate. Based on my observation persons mention the user interface of the Siglent as better but I think that is more the GUI, as one advantage of the Rigol is that it still maintains the ability to use most functions with buttons rather than the touch screen, also it has independent channel controls. These are significant parts of the UI. Observe all the reviews, including Dave’s, most people still gravitate towards the buttons not the touch screen. If you have ever worked on repairs you would realize your hands get dirty and touch screens and dirt don’t go well together. There is also the 500Mhz option for the Siglent, but at 2G sample rate it is borderline but an advantage.
2.   Most persons are likely to hack both scopes, which means comparison would have to be at the lowest price point. The price difference between both scopes would be $400 or $490 if you were to hack the 2-channel version and had 350Mhz probes already. Additionally, a hacked Siglent would need 4 x 350Mhz probes after upgrade which could add another $200 to its cost.
3.   Based on the success of the Rigol 1000 series being primarily driven by low cost, available features and a history of hacking, sales of the MSO5000 will way out pace the Siglent since this looks like the same strategy is in play. (not a reason for purchase)
4.   These scopes are a step up for the hobbyist but the cost point will be an overwhelming selling point. If paying 50% more for a scope does not matter then one should be looking at the A brand scopes.
5.   I have noticed very few contributors who have pointed out issues with both scopes have explained how the + or – affects use in the real world, and so persons may be deciding on a purchase based on something they will never need or may never matter.
Based on all the above I have decided that the Rigol gives the best value proposition by far (if scope will be hacked). The MSO5074 $90 cost over the MSO5072 is less than the cost of the 2 x 350Mhz probes included with the MSO5074, so you don’t actually pay for the upgrade to 4 Channels.
The following users thanked this post: Steve12366
