Author Topic: EEVblog #751 - How To Debunk A Product (The Batteriser)  (Read 3077928 times)
Offline EEVblogTopic starter
« Reply #650 on: August 20, 2015, 11:39:20 am »
So apparently in order to get the most use out of alkalines the device actually limits the brightness of the screen. That also explains why it crapped out at about 10 hours with Batteriser installed, Garmin figured the device wouldn't come near the advertised operating time with alkalines.  This also proves the device was also set to alkaline mode. So another fabricated piece of bullshit by Batteriser, the device never stopped working, just the screen dimmed, completely as designed.
More Batteriser testing FAIL.
Can they not get anything right? This isn't rocket science.
Online Fungus
« Reply #651 on: August 20, 2015, 11:46:08 am »
"The data shows that the gps will stop functioning after one hour and 52 minutes, and the screen dims to dark"
That isn't them saying the batteries are flat....
But "stop functioning" is a lie, n'est pas?
Offline firewalker
  • Country: gr
« Reply #652 on: August 20, 2015, 12:09:14 pm »
I dig through the Approach G5's firmware. The message is:
"The battery power is too low for full backlight. Use rechargeable NiMH or lithium batteries to prevent this limitation."
Alexander.
« Last Edit: August 20, 2015, 12:18:41 pm by firewalker »
« Reply #653 on: August 20, 2015, 12:14:17 pm »
That seems to confirm they have screwed up this test completely. It didn't actually stop working. FAIL.
Online Fungus
« Reply #654 on: August 20, 2015, 12:31:15 pm »
Next question is: Do you actually have to keep prodding the screen to keep it at "full" brightness?
If so, that explains the finger. The finger makes no sense otherwise.
(It would also show the sheer deviousness of the batteroo people to try and show something lasting "many times longer")
Offline madires
« Reply #655 on: August 20, 2015, 12:47:58 pm »
... this leads to the logical conclusion, that the whole story is a deliberate deception. It's simply too much nonsense to be considered as lack of experience and knowledge. In a few cases of badly designed devices/gadgets/toys Batteriser might help a little bit, but anything else is just hot air.
« Last Edit: August 20, 2015, 12:49:37 pm by madires »
Offline FrankBuss
    • Frank Buss
« Reply #656 on: August 20, 2015, 12:56:06 pm »
Would be really interesting to test the batteriser. In the FAQ they claim "the Batteriser sleeve is designed to deliver as much current as a battery is able to supply to the device". Good luck with that in this small form factor with the near short circuit current of an AA battery for a high power device. It will glow nice red if the boost converter isn't really high efficient >:D
The following users thanked this post: MrMobodies
Offline Galenbo
« Reply #657 on: August 20, 2015, 12:58:47 pm »
Why expect that from a bunch of guys calling themselves PhD, who express energy in volt and clearly do not know how to use %.
What's next? Expressing time in kilogram?
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline amyk
« Reply #658 on: August 20, 2015, 01:44:52 pm »
According to Google, "The battery power is too low for full backlight." message has never before appeared on the Internet, and this might be the first mention of it.
If someone who has this unit could make it display that message and show a picture of it side-by-side with the one in the video, we'll have some pretty convincing proof. The fact that it's in the firmware might not be as convincing as others.  Now anyone who has a YT account can post that message on the Batteriser video, or make their own debunking...
Agreed.
Offline firewalker
  • Country: gr
« Reply #659 on: August 20, 2015, 01:49:13 pm »
There is another string in the firmware.
"Batteries Too Low For Backlight"
So there was another voltage step that would disable the backlight. It seems to me that the unit would function for more time by just pressing ok.
Offline fcb
    • Electron Plus
« Reply #660 on: August 20, 2015, 02:22:16 pm »
So the product is debunked.  Their claims are poorly researched at best.  They look like they are using shills on all levels.
"Batteriser" (wonder why they haven't used a Z as they are from the US?) looks like it will raise a substantial amount of money.
So what? They haven't got a business as pretty soon after delivery some of the other magazines/blogs/vlogs out there will comprehensively test the product (assuming it gets delivered) - most likely they will be nursing a hefty loss and huge reputational damage.
And no VC in their right mind is going to fund them - even a small amount of due diligence on the Batteriser will find this thread.
Job done Dave, can we go back to some great teardowns, the uSupply and mailbags - even the postcards FFS.
Online Fungus
« Reply #661 on: August 20, 2015, 02:28:15 pm »
Nobody's forcing you to read this thread. It's fun finding new flaws in their arguments (doubly so when you can use screenshots from their own videos to damn them).
Offline fcb
    • Electron Plus
« Reply #662 on: August 20, 2015, 02:34:14 pm »
Damn it! I just read your reply.
Offline LabSpokane
« Reply #663 on: August 20, 2015, 02:59:00 pm »
SK Telecom already did. Up to $1MM USD. Now they're trying get money out of the Department of Defense.
This is a problem. It needs to stop. It's a discredit to the profession. The Roohparvar brothers are the collective Dr. Oz of electrical engineering.
Online Fungus
« Reply #664 on: August 20, 2015, 03:02:10 pm »
Citations...?
Edit: Don't worry, I found it - google is my friend.
Edit2: And that was back in March. This is more proof that the $30,000 IndieGoGo thing is only being done for nefarious reasons.
« Last Edit: August 20, 2015, 03:16:06 pm by Fungus »
Offline LabSpokane
« Reply #665 on: August 20, 2015, 08:12:43 pm »
Bob,
When you get back from lunch, you have some deleting to do...
Offline LabSpokane
« Reply #666 on: August 20, 2015, 08:44:17 pm »
Wow. That was quick. Yeoman's work there, Bob.
Offline AmmoJammo
« Reply #667 on: August 20, 2015, 08:53:23 pm »
Ah, but it did "stop functioning" till the "ok" button was pressed.... they didn't claim the batteries to be fully depleted, or that they'd reached the cut off voltage of the device...
Offline PeterL
« Reply #668 on: August 20, 2015, 09:00:20 pm »
About the golf GPS test,
First of all: yes I know I was wrong thinking this was a Dakota at the wrong battery setting at first,but before drawing more wrong conclusions I think we have to look a little closer:
1) GPS devices don't like to be inside
It's very hard to get a 'fix' when inside a building, and for the older generation receivers it's nearly impossible. During this search the receiver will probably be more power hungry.
A 'cold fix' takes even longer since it has to gather the almanac data first before being able to calculate it's position. So whatever time the Garmin can run on a set of batteries in this test, it's not 1:1 comparable with real live experience.
2) About the finger:
Knowing Garmin software, the device could ask "Are you indoors?" or something like that after a minute or so without reception. I think they need this force the GPS receiver to stay active
3) Look at the current graph again that they gave us:
It's clearly switching to some powersaving mode after 1.5 hours. It also looks as if it goes from constant current to constant current (or the voltage didn't drop anymore.) But they did leave it running for a while after it switched mode.
4)
Running at full power for 10 hours with the batteriser against only 1.5 or 2 hours without is still a huge plus for the batteriser IMHO. ->Which is for me is a big reason to believe something else/something more is going on.
But at the end it isjust a waste of time speculating how the got their nice results. Only independent tests can tell what the batteriser (or just the technology)  is capable off. And the fact we don't see that should say enough.
« Last Edit: August 20, 2015, 09:01:51 pm by PeterL »
Offline PeterL
« Reply #669 on: August 20, 2015, 09:21:54 pm »
Check out the blog thing on their Youtube channel!
https://www.youtube.com/channel/UCFr9QYi8Yq2ckWYPx_Vui8A
"Pls stand by we are in a process of releasing a video with the technical explanation for all engineers on how Batteriser works, while at first glance, it seems implausible, I am sure that real genuine engineers will appreciate our whiteboard technical discussions along with simulation, data matching battery companies spec sheets, in conjunction with device data. Of course, those whose revenue will be reduced by our technology will do everything to divert attention"
I wonder if it will be released before or after the end of their IndieGoGo campaign.  :popcorn:
Probably short before the campaign ends, long enough so most last doubters will see it, but short enough to not give anyone time to make a reaction video.
I guess we will see a video in which nothing will really be explained. They will admit that the critics are very smart, but the Roohparvar's will look much smarter, and that shall be enough to proof the batteriser works.
Offline Smokey
  • Not An Expert
« Reply #670 on: August 20, 2015, 10:11:54 pm »
This has probably been said before, has anyone taken an off the shelf boost converter and running side by side tests on some batteries and showing the results.  With known numbers like the off the shelf boost converter's efficiency it should correlate to the type of effects the batteriser would have on stuff.
« Reply #671 on: August 20, 2015, 10:28:37 pm »
Citations...?
Yes, they got that VC funding back March, before this thing hit the fan with the infamous PC World article on June 1st.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #672 on: August 21, 2015, 04:41:03 am »
I was thinking 'the Richard Simmons' of Elec Eng...!
Don't ask a question if you aren't willing to listen to the answer.
Online Fungus
« Reply #673 on: August 21, 2015, 10:34:00 am »
Correct, but that's not what's being measured here.
Yep, the finger is very suspicious here. Obviously part of the cheat in some way.
4) Running at full power for 10 hours with the batteriser against only 1.5 or 2 hours without is still a huge plus for the batteriser IMHO. ->Which is for me is a big reason to believe something else/something more is going on.
Well...it would be if they weren't cheating.
But they are.
No it isn't.
Nope. Anybody can prove that battery powered devices generally use up at least 80% of the power in the battery. The other 10-20% is usually left there for a reason (eg. fully discharging rechargeables is bad for them).
Your statement would be valid if Batteriser were claiming 10-20% more, but they aren't.
(And the batteriser isn't 100% efficient so it's much more more likely to be 10-20% less on most devices)
Online Fungus
« Reply #674 on: August 21, 2015, 10:45:12 am »
I can't find the $1 million figure anywhere but if it's true it's just more proof that the whole IndieGoGo thing is just part of a bigger scam.
« Last Edit: August 21, 2015, 10:51:15 am by Fungus »
