After switching back to my CTI OC5SC25 OCXO, I ran a new measurement with the modified PWM DAC setup to determine the optimum TC value.
This test setup is explained in Lars's document as option 2 on page 12. I used a TC of 4 and a damping of 3.0.
The results are astonishingly different.
Please help me to explain this vast difference.
Not very scientific, but this has changed between the two test setups:
1. The first test ran with live data, the second is an import from Excel made from the Arduino serial monitor.
2. With the first version I used a current boost circuit to reduce the temperature of the 7805 voltage regulator. With the second setup, I only use a 7805 regulator. (see the circuit diagram in the post just above)
3. For the second setup, the PWM/DAC circuit was moved from the Arduino board to the OCXO board and I added 100nF caps in parallel to the 4.7uF Tantalum caps. The PWM/DAC outputs (D3 and D11) are now connected through 20cm Dupont patch cables. In the previous version, these cables connected the output of the DAC circuit to the oscillator board. All connections between the two boards are made with these cables.
4. The second version uses the 74HC14 per
imo's suggestion to reduce DAC noise from the Arduino supply.
5. For the second version, a REF02 5V precision voltage reference was added to supply the complete PWM/DAC circuit.
6. The gain for the first setup was 455 with an f delta of 1.4Hz, the gain for the second setup is 303 with an f delta of 1.1Hz.
7. Note that both setups already had the 10MOhm removal modification implemented. See my earlier posts.
8. The dip in the OSXO temp in the beginning is the dropping of the ambient office temperature for the night.
9. The OCXO board is covered during the tests by a plastic container to reduce draft effects.
My questions:
1. The mysterious (for me) hump in the old setup is gone. Why?
1. Are the hardware changes plausible cause for these results?
2. Where do the wriggles/oscillation come from in the new setup?
3. Why are the ADEV and MDEV charts so different for the new setup? (both have the drift line filter applied)
