Author Topic: News from Tinkertubes Lab  (Read 20744 times)
Offline YsjoelfirTopic starter
« on: August 31, 2016, 07:51:15 pm »
Hey everyone,
in this thread I will keep you updated about my recent tinkerworks. Please feel free to give me any advice you want, tell me how I can improve, what you liked about a specific video and/or what you didn't like.
Any comment is very appreciated since it helps me a lot to improve the overall quality of my videos.
I hope you have some fun watching, and if you do, please consider voting and subscribing to ma channel, that would be awesome!
See you at tinkertubes lab! http://www.tinkertubes.eu
[original text]
it's quite a while since my last thread at this part of the forum. As you know, I wasn't realy satisfied with the quality outcome of this voiceover attempt I made back then. Some things have changed, I got a better mic, much more light and a bit more self confidence, but still, I have no Idea if my english is that good.
Since I could'nt get a decent voiceover done, I tried it the other way around - speaking english while recording, which gave me some shivers at first. Even though I guess the outcome is... okay, I would love to hear your oppinions about this. Should I keep on doing it that way?  :-// Where can I improve?
Besides the voice, I am still not overly satisfied with the lighting, there are simply to much reflections. Any ideas how to get past that?
Thanks!
« Last Edit: October 07, 2016, 01:16:45 pm by Ysjoelfir »
Greetings, Kai \ Ysjoelfir
The following users thanked this post: CJay
Online MK14
I've had a quick look (listen) at the video, for a few minutes. Your English is good, and I had no difficulty at all, understanding it. It is maybe x10,000,000,000,000,000,000,000 million times better than if I was to do a video in German!.
Old meters like that can be interesting. It is odd that it has a common positive connection. Could it be because I heard that (but have not experienced it), some old vehicles (cars), had positive (rather than the negative battery terminal) ground connections or common connections
I'm not sure how you are suppose to say/describe it. But anyway the + and -, are the opposite to what you would expect, compared to the chassis of the car.
Example:
http://mechanics.stackexchange.com/questions/1934/what-are-the-tradeoffs-for-positive-vs-negative-ground
« Last Edit: August 31, 2016, 08:08:40 pm by MK14 »
The following users thanked this post: Ysjoelfir, jonovid
Online MK14
As requested in the video, I think it possibly might have been a silicon diode (I could easily be wrong). Because a Copper Oxide (rectifier), would have also needed many stacks (been big), to cope with the high voltage, I think, but don't know much about Copper Oxide rectifiers.
The Silicon point contact diode, was invented in 1906, according to the following source:
http://www.jmargolin.com/history/trans.htm
But I don't know if it could have handled such high voltages for your 1930's+ meter.
Offline Delta
Whilst your accent is quite strong - nothing wrong with that - your English is clear and understandable.  Your "flow" sounds very natural too  :-+
The audio is fine for this type of video - after all, you are chatting away about electronic gear, not singing opera!  (I know some people do get bothered by the audio on all videos though)
Lighting could still do with some work though.
Offline joseph nicholas
  • Country: mx
Hi, the most classical way to eliminate reflections in glass is to use a polarizing filter on the lens.  These are not expensive and work well in high contrast scenes in landscapes, but also for what you are doing.
Your English is flawless so keep up the good work.  Don´t think twice, its alright.
Hasta luego.
nico
Offline Brumby
Polarizing lenses are good for many reflections, but not specular ones (mirror like).  Lighting position and the angle things are positioned combine to cause the problems you get.  Just experiment with these and you'll soon learn where the best place is for your lights and how you hold the subject.
Don't worry AT ALL about your English!  Yes, there is a strong accent - but I got used to it very quickly.
I notice you have audio compression on your microphone.  This is an excellent move in itself - but be aware that when you clicked the range switch with the meter close to the microphone, the compression kicked in and didn't release for a good second.  When you did multiple clicks, your voice was inaudible.
For comments, I wouldn't use the outline font.  Yes it's pretty, but it's just that little bit harder to read - and what it's saying is more important.
The only other things I noticed were only because I was watching critically .. and even those are things that will be addressed by a bit of experience and more confidence in yourself.  Seriously - they are not even worth mentioning.
As a general comment on your efforts - KEEP GOING!
Hi everyone and thanks for your kind words! That realy helps me keeping myself motivated :)
Since SWMBO is a nice girl from Texas I asked her family to comment, too, and well.. their comments were very simmilar to yours, so I guess I don't have to be that worried about being understandable :)
I guess I will keep on doing most of my videos in english, trying to make a german voiceover afterwards, at least that seems so much easier to me.
Regarding your comments not regarding the speech:
Example:
That could be possible, as the time period would fit. On the other hand, maybe it has to do with the old discussion about technical/physical direction of current?
Sadly I forgot to measure the voltage drop over this thing, maybe that could have helped.. oh well. I guess someone will know what it is and help us out here :)
I know about polarizing filters as one of my other hobbies is photography, but  sadly this isn't that kind of reflection that could be killed by using a polarizer :( but even if they could be eliminated, my camera doesn't have a screwmount for filters. Maybe someday I will be able to buy a new one...
At the moment I have LED light panels made from around 15 meter LED strips straigt above my workbench. I already thought about using studio light with the big umbrelly thingys, but if you take a look at my workspace you will see my problem with that - there is simply no room to place those. When sitting at my desk there is around 50cm to the next desk behind me. To my right side is the protruding part of the roof, I can't even stand there. And left... well, I have to be able to leave somehow :)
I noticed that, too. Try to remember it for the next time, since there is no way to controll the hold time of the audio compression.
Shame on me, I was lazy - had this font for on video annotations because the outline is good readable on every background. Yes, a solid font would have been better with the unicolored background, definitely.
[/quote]
I would suggest use a pro light system like this one,
Beside the space problem mentioned above, that one is SO expensive! :O I see those around ebay for around 35€. Are those that bad? Maybe I could fit one umbrella light somewhere...
Offline Brumby
The lighting and reflection issues are the biggest challenges for any photographic exercise - but especially video, where there is subject and/or camera movement (IMHO).
There are 4 things to keep in mind:
1. The position of the camera
2. The position of each of the lighting sources
3. The orientation of the subject
4. The location and illumination of objects around and behind the camera.
The first three cause the greatest grief when they all line up - so the idea is to try and make sure they don't ... but are still illuminated properly for the shot.  Sometimes the camera and subject positions don't allow a lot of 'playing around'.  The subject has to be in front of the camera.  You can try and avoid orienting the subject into positions that don't have bad reflections, but that can be awkward if the lighting is in the wrong place.
If you can find a less constricting space to do your videos, you will be able to address a lot of your issues much more easily.  Working to a physically restricted space does add to the complexity - but, hopefully, you will be able to find a workable compromise.
To make suggestions through a forum post like this, is a bit difficult, but I would suggest you might try putting together some lighting that you can try placing in different locations and just experiment to see where you find a balance between lighting and reflections.  Since you seem to like LED strip lighting that appears to be quite reasonable in terms of brightness and colour, I might suggest you make up two LED 'panels' - maybe just a piece of board with half a dozen 50cm strips on each (you would have a better idea if you would need more or less) and have some support system that allows you to set them in various positions and orientations.  I might try them at the left and right (or maybe upper left and upper right) of the subject and see how it goes.
Panels such as these can be brought out whenever you do videos and packed away at other times.  Once you find an orientation that works well, make sure you have a means to quickly position the lighting in that orientation every time.  You will get frustrated otherwise.
The fourth issue is much less of an issue - but it can create annoying artefacts.  I give you a personal example.
I do a lot of still photography with a setup best described as a 'document camera'.  The camera is pointing vertically down to a table top on which the subject is placed.  Some of the subjects are enclosed in plastic which is highly reflective.  At one stage I was doing post production processing and noticed a golden streak across part of the image - and once I saw it on one image, I noticed it on a great many more.  After some detective work I worked out what it was......
I had mounted my camera on a home-made bracket - which was a light brassy colour - and since the subject lighting was very good, there was enough light reflected up towards the camera that this bracket was being very well lit.  So well lit, in fact, that it was reflecting off the plastic wrapped around the subject.  The solution was really simple.  I found a couple of old black socks and made the hole in the toe a lot bigger and slipped them over the bracket.
Once aware, I started noticing more of these reflections - from the silver 'Canon' logo to the rim of the lens.  I started to think I would have to shoot through a black curtain, with a little hole for the lens!  Fortunately, these were not particularly evident in the final product, so I could easily get away with it.
Offline dexters_lab
no problems with your english Ysjoelfir and no issues with the video
i would second the comments about the audio compression / limiter and loud sudden noises knocking the audio back.
Try turning off the AGC on the camera and if you can apply the limiter when your editing (if your software has that option), you should be able to adjust the limiter recovery time to be very short so it still limits sudden noises but also doesn't knock the levels back for a long period and obscuring your speech.
subbed  :-+
« Last Edit: September 06, 2016, 08:41:10 am by dexters_lab »
Offline ez24
  • L.D.A.
Offline jonovid
    • JONOVID
Re: Second attempt of making an english video - I need your oppinion once again!
« Reply #11 on: September 06, 2016, 11:56:39 am »
no issues with the video   sharp focus  :-+
Offline b_force
    • One World Concepts
« Reply #12 on: September 06, 2016, 12:13:58 pm »
Ok, first of all, crash course for Germans, Dutch people and some other EU countries.
Your English is fine!!
I have been traveling a lot, and most English speakers don't care if you make a mistake or two. As long as you get the message across and you speak clearly.
I have met many people who think their English is horrible or they're not fluent, but they speak even better than some locals.
I guess it all comes from the fact that in some countries everything has to be so perfect, to a rediculous level.
You're not a native speaker, just accept it.
Accept that you will make minor mistakes.
For the same reason, accept the fact that you have an accent (which you'll always have).
And last, to get even a bit more convidence. Watch some big youtube channels. A lot of them is done by non-native speakers with horrible foreign accents.
« Reply #13 on: September 09, 2016, 11:02:54 pm »
Definitely! I love taking photographs, so I am well aware of light being the biggest factor of success. But as I am new to videography (why is this a word in english but not in german? we have to say "recording a video"..) I struggle with this problems every time again.
At some of my first attemts I had just four 10 Watt LEDs spread around the camera which was quite okay but much to dark. Now I updated to the LED strip thing I told before which brings a much brigter and better distributed light, but also much more reflections. Before mounting the LED Panel directly beside the camera I had it sitting on a little tripod at my side, but aside stumbling upon it and kicking it over I could'nt do anything with it because it was just much to big.
I thought about placing a white cloth over the LED panel, maybe that helps distributung the light and getting rid of reflections? I should try that.
Also, I got a interesting 300W (100 x 3W LED chips) LED Panel from a local flea market. But sadly I didn'T know that thing was a growth light for plants.... damn! Didn't want to start some sort of business with bright pink/red lighting! So i ordered 200 3W LEDs in neutral white from china. We'll see if that thing could be of any use. At least it is realy small, so maybe that thing won't obstruct my moving that much.
Oh my god - that sound like something quite annoying! Actually, I noticed stuff like this at my pictures, too, but it was more or less okay for me. I am gratefull that I don't have that much aspiration - but who knows what will come someday ;)
Right, that would be a good idea. I will try that on a future video. Thanks for pointing me at that possibility!
subbed  :-+
Wow, thanks! That helps me a lot! :) I was watching your videos before, so that is kind of a honor for me :)
A couple of these will help
https://www.amazon.com/Simple-Deluxe-HIWKLTCLAMPLIGHTM-8-5-Inch-Reflector/dp/B01E9IY6US/ref=sr_1_5?s=hi&ie=UTF8&qid=1473160337&sr=1-5&keywords=clamp+light
That is so damn cheap!I have to see if I can find something like that in germany, looks promising. Maybe combined with some high power LED Lamps?
Sadly, I have experienced the opposite sometimes, which is part of the reason why I get this thoughts. But as the resonance here is quite good... I guess thats ok. Even though the first (and nearly only) comment I ever got under one on my videos was the typical hater comment :-P But getting more hate comments seems to be normal business at youtube.
The following users thanked this post: dexters_lab
Offline b_force
« Reply #14 on: September 10, 2016, 02:54:41 am »
Some people are just ass holes.  I always tell them if their Dutch (in my case) or German (your case) is better than our English, they have a point.
Don't focus on it.
Offline CJay
« Reply #15 on: September 10, 2016, 08:52:41 am »
To my shame one of my favourite ever videos is the one where TRXBench reviews a Digital Vector Wattmeter, the technical content is excellent, his presentation is perhaps a little slow but he's thorough and has an excellent understanding of his subject.
I'm ashamed of the fact that his accent always raises a smile when he says Digital Vector Wattmeter.
Your videos and accent are absolutely excellent and your English is grammatically better than that of many native speakers, it's also far better than my German.
Please, don't let the haters discourage you, they're just idiots out to get an argument or knock down those who know more than them.
Lighting, others will know better than I do so experiment, it's very difficult to get it absolutely right in all conditions but I've found reflected light works better if you have bright source(s)
Offline b_force
« Reply #16 on: September 10, 2016, 12:33:30 pm »
I don't think people need to be ashamed if certain accents or dialects (or any other kind of difference) makes them laugh.
Sometimes it is just funny on a cute way.
Differences (in culture) are just fun and very interesting!
Anyway, keep up with posting more stuff on you youtube!
Offline CJay
« Reply #17 on: September 12, 2016, 09:51:11 am »
perhaps ashamed is a little strong but I do feel a pang of guilt about it.
Anyway, I agree wholeheartedly on posting youtube videos, the more knowledge we can put on there in easily accesible and friendly formats to teach, inform and show the fun of our careers, hobbies etc. the better.
Hey,
thanks for your kind words, and no, I won't let haters discourage me, I have to much fun doing this stuff to let that happen  :scared:
Right now I tried to update my lighting with a nice LED fixture I found at a local fleamarket. To bad that I had to do a "little" midification for it to be somehow usefull. I hope that I find a way to mount it so that you can see it in action in the next video.
Until then you might want to take a look and throw an ear at the build log, I tried to enhance the audio by disabling the compression at the camera and reapply compression while editing. It kind of worked, except at one place where I got much to close to the mic and it just overmodulates completely - at least that was just a short period - phew!
As always, I would love to hear your comments and Ideas on how I can improve anything :)
Offline ez24
  • L.D.A.
Hi
I like your voice and relaxed pace of speaking.   Some people are so fast (or slow) and harsh I want to hit them.  Your hair was a distraction, the hat was better but you may want to find a hat with a short brim, it got in the way.  Reverse it on your head.  Check your fingernails.
I suggest you take close up photos of circuit boards and add them in the videos, also datasheets,  also the ads where you buy your stuff.  Like take a screen shot on what you buy.  In this video what if someone would like to check out the LEDs that you bought?
So some close up photos (not video) edited in the videos, of the LEDs, their source, cost, datasheet, etc.  Just imagine if someone wants to build what you are doing or buy something in the video, help them.  Dave does this in his videos.  Be sure to study his videos for technique,  he makes his living off of them so he puts a lot of thought into them.
I liked the part about the helicopter.  The same thing happened to me, I was watching a portable TV in a dark canyon when the helicopter came over my head.
Double check all your links, here is one from #24  notice anything wrong (hint typo) ?
Please visit my website at http://www,tinkertubes.de for more interesting articles!
Also in the English version of the links should be a warning the site is in German (I was bummed)
Could you have drawn a simple circuit of your light?  It can be on paper or white board, no computer CAD is needed.  It would have been better than the screwdriver.
You should add your youtube channel and website to you profile on this forum so it shows on every post that you make.  You should make a post every time you upload a video.  I suggest stick with this topic so people can follow you on this forum.
In #24 you show a bolt and you did not know the English name - it is a "carriage bolt".  The thing you used to make holes is a "hole punch".
Another suggestion - set up two YouTube channels, one in German and one in English.  If someone stumbles onto one of your video in a language they do not know they will skip you.  I did not know you were doing dual languages until I checked out your playlists.  It seems a bad idea to do two languages on one channel.  In fact most of your videos are in German.  This is the first time I have come across someone making video in different languages, seems like a really bad idea.  It is hard to move about on your YT because of this.
I STRONGLY suggest you do not use two languages on one YT channel.
See if you can translate your website, I thought WP could do this.  While talking about this - I feel it is more professional to have your own website rather than host on a free WP site.  It is so cheap to do this, there is no reason not to do it if this is something you would like to make money at.
I think you have a lot of potential and I really hope you will continue.  Do you have any desire to make videos on MCUs ?  If so we should talk.  It would be good if you do not know anything but start making videos on them because you have a good YT personality and I think you could do a good job.
Add in some little interesting things.  I would have loved to see a picture where you bought the light.  Notice Dave shows his lab and sometimes outside his house, he even did a road trip one time.  So you could show where you get things (just a few seconds).  It adds a little humanity to the videos.  If you drive across town to get something put in a short time lapse of the drive.
I think if you want to make money and continue you need to show yourself.  You do not need to be in the whole video, you could start with an introduction, like standing at your table.  This is hard for me to say, I am so ugly I know I would hurt the video, so personally I would not show up in a video.  But I think the commercial successful ones have the author in the video.    You should have a picture of yourself on YT.  So if you want to make money, you need to become more personal with your audience.  If you have no plans to make money off your videos, never mind.
Put something about yourself in the About section of YT.  Like name, age, gender (I can guess), occupation, schooling, interests, goals, etc.  Maybe someone would like to know if you have the same interests as they do.
till later
Roger
Offline zapta
OP, your English is very good and easy to understand. One suggestion is to look at the greatscottlab and ThomasSanladerer channels on youtube (both are from your country). They script their videos are very good IMO.
Re: News from Tinkertubes Lab
« Reply #21 on: October 07, 2016, 10:25:12 pm »
I watched both videos.
The first thing I noticed was that I turned the volume up on this latest video after having just finishing listening to the first video in this thread. So finalise the audio setup as quickly as you can and ensure it remains under your control.
I normalised the video to -12dB since the overall loudness seemed to be around that spot with some nasty peaks going up to 0dB, the older ones weren't normalised at all. I will stick to -12dB as I don't like this overly enthusiastic loudness most audio creators have today.
The fan was audible even to me. You might need to slow them down a bit or find quieter bigger ones.
even before you wrote I already took my new baby (ryobi 18V cordeless angle grinder <3 ) and made a little hole in that thing to mount a 120mm fan.Was still to noisy, could still be heard slightly. So I got myself an 78S075, soldered that to the wire, straped it down to one of the fans mounting holes and there we go. perfectly fine. I also tried to find a way to mount that thing to a tripod and place it on my desk. still need some experimentation on where to place the floodlight to get the best light distribution, but time will sort that out.
For technical videos it is ideal to speak with a German accent. The Germans are highly regarded throughout the world as producing technology of outstanding quality. So the accent complements technical video quite well.
I think you will do well.  :-+
Thanks, that is so nice to hear that the accent somehow adds to the watching experience XD I realy like that! :)
Now I am realy offended! You don't like my beautiful hair? and what about my nails? I trim them everyday to perfect size to scratch myself and keep them well lubricated with natural handyman dirt so that they stay intact!  :box: I get what you mean. :) Actually, the "Hair and Hat"-problem is actually a result of my attempt to correct another problem. My old camera setup had the problem that the picture frame was a bit to far shifted to the rear end of the table, just hanging down from a bracket at my shelf, facing away from me. So I decided to just turn it around and flipping the video in post processing, which resulted in around 15cm less stretching of my arms over the table and giving me more controll over the picture frame. What I didn't think of was, that I have to be more carefull now regarding my head being in the picture. I guess I will have that sorted out the next times.
I will try to remember that. I haven't decided which software I will use in the future as I am not completely satisfied with my ancient Version of Adobe Premiere Elements, think about using an other software for the next videos. I guess I will try to add those things then if necessary/usefull.
I would love it if we had canyons here o.o
Yes, already noticed that. Didn't find the time to change this typo in every video, since I made it in my presets. (Will correct the mistakes tomorrow if I remember it) But I edited the preset, since I now decided that I will switch completely to english. That is, because I got confused with the multilingual thing myself as it is quite hard to keep track and not to miss anything. Sadly, the translation thing you saw on wordpress only works on self hosted sites. As you mentioned it - yes, self hosting is cheap, and since I have had some experience in the webdesign business around 11 years ago I have no problem setting up a self hosted site. BUT, and that is the reason I stayed at (better: returned to) WP free, the wordpress site somehow gets quite some clicks, I have no idea why. I switched to self hosted for half a year or so, but the few comments I got kept appearing on the old site, even when I changed the title to "this site is an archive, please go to *new site*" and placed a simmilar text as preset in the comments box. The self hosted site however didn't get more than 20 clicks per months, regardless of me trying every little thing to tweak SEO and stuff like that.
I actually think about shutting off the wp site at all since I notice that I focus more on the video thing, which is way more entertaining to me. What do you guys think?
Done. How do you like it? I also edited the threads start post to better suit this Idea (I actually didn't know that this is allowed, since it is advertisement then...)
Thanks! I sure will continue, I have much fun taking the videos and I love sharing knowledge and ideas.
I actually would like to get into MCUs a bit deeper, in my studies we have some courses which involve MCUs, but we all know how much those courses help. I have basic knowledge. What do you think about?
Interesting, I have thought about that as well. Since I go to flea markets on a quite regular basis I thought it would be quite interesting to have a format like "Ysjoelfir goes shopping", showing some short clips what I got and so on. The problem would be the privacy laws we have in germany. You are not allowed to take a video or photo of someone without their permission. I don't know if there is a way around that, maybe I should investigate that a little further, if there is more interest in this type of video.
In one of my german videos I filmed myself, ranting about DPD and the amazon priority stuff. So, I actually have no problem showing myself, but I just thought there wouldn't be any benefit from it. What do the others think about this? I was a bit scared that it could just seem that I would stretch the video to length with an introduction like that.
And: I want to redesign my logo, actually I am working at it right now/this week. Thought about something like a big gear with TTLab and crossed soldering iron and scope probe under it in the middle of the gear. I guess I could involve myself in the actual header picture, if this could be usefull.
Regarding the money: I have monetarisation switched off right now since I don't think that my content is that good in quality that I should bother my viewers with advertisements. Even though, I actually designed a patreon page after I got an e-mail with an invitation to participate after giving support to some of my favorite channels myself. But for the same reason I didn't activate that 'till now.
Done. Sadly, there isn't enough space for a little biography :( I tried to get the most usefull things on there.
Thanks for your comment! I watch both channels, but I have to admit that I don't like scripted videos that much. Feels always a little like a lecture lesson...
« Last Edit: October 07, 2016, 10:33:07 pm by Ysjoelfir »
Offline ez24
  • L.D.A.
« Reply #22 on: October 08, 2016, 03:29:27 am »
No - I am bald   :-DD
« Reply #23 on: October 10, 2016, 10:29:22 am »
I like the style you have and the way you speak. It is a bit like sitting down with a friend and you are being shown what they have been doing. I call it the "over the shoulder style".
That is actually what I intended to represent. I want to show the things I like in a friend-like way so that a kind of comfort is present. Thanks  :-+
The longer you remain fixated on technical aspects of video production the more I fear it will diminish the enthusiasm. So establish a certain technical standard that is acceptable and leave it at that.
Thats what I thought. But as I am quite enthusiastic this point of technical standard isn't reached. I am saving for a new camera since this old Panasonic HDC-SD40 isn't that great (at least I got the feeling that the video quality is always a bit blurry) and am looking for more of those weed lamps to convert to studio floodlights as I noticed in some experiments I made the last days that the one I have now is quite useable, but to reduce harsh shadows I need at least a second one.
As for logos. Logos should be like flags, so simple that a child can draw them from memory. An example of a good logo is The Signal Path Blog. W2AEW has a good logo although it is not really a logo. It is just too clever to ignore.
Just a suggestion for a logo, Not saying I think it is a great one. It just poped into my head. Is TTL for "TinkerTubes Lab"maybe in a 14pin DIP package outline. Simpler would be better and easier to represent in a blog and in email and forum posts.
I had the same thing in mind but thought at first that the TTL-reference would be a bit to flat, kind of an anti-joke. But some of my friends pointed me also in that direction so I got my 200 cds from the ancient Cinema 4D Bundle I bought many years ago and started fiddling around. (was it that hard to get a somehow acceptable result back then? Or did I just forget nearly EVERYTHING in regards of using this piece of software? :wtf: )
The attached TTLab_.jpg is what I came up with. I am thinking about transforming it to a 2D sketch in mainly three colors, orange, black and green. I am absolutely not satisfied with the quality of this model but I guess you get the Idea. (Even though the tilted view looks actually not that bad... maybe for use in a header image?)
« Reply #24 on: October 24, 2016, 06:04:55 pm »
Hey everyone, there is a new video online! I was busy with my studies, so I had a hard time filming at all, so I decided to do this with the old light setting, just to be quick.
It is about a part of my study project, showing the building of an AVR-Net-IO.
In the future I am planning on presenting the finished project on video, maybe as a little addon.
You can find the video - as usual - on youtube at tinkertubes lab. Hope you like it!
https://youtu.be/LhJMJmR7Nhc
