The only way an electric motor can operate,unless it has permanent magnets mounted on its rotor,is from induced
No.
If you read the Wikipedia article I linked to, you discover a motor can work without permanent magnets or a wound rotor.
If you find that hard to understand make a simple linear motor, wind a coil round a straw with a nail loosely fitted in the middle and you'll discover the nail is pulled into the coil when it's energised.
OK,do that,then after you have proved a solenoid will draw a nail into it,remove the nail.
Is it still magnetic?
Where did the magnetic field come from?
Would it work with a piece of ferrite material?
Note:-I never said you have to have a wound rotor,in fact,the example I gave was of an aluminium disc
rotating in a magnetic field.They do work,there is one in most meter boxes.
OK,I see where you are coming from:-
"If the induced magnetic field is from induced currents,why does a permanent magnet attract a non magnetised piece of iron?"
Right?
So if we can induce a magnetic field in that case without induced currents,why not in a motor?
Well,one thing is,that a conductor moving through a magnetic field will have a current induced in it,anyway.
The magnetic field is continually changing,so the polarity of the induced magnetic field & hence the alignment of the atoms
making up the material will change.I suggest that this constitutes a current.
OK,I'm not a Physicist,so I'm not able to determine whether magnetic realignments constitute a current,but I will leave you with
these suggestions:-
Try making a motor with a ferrite rotor,& an insulator as a shaft
Try a motor with the whole rotor assembly made from an insulator
My guess is neither of them will work.
VK6ZGO
