Author Topic: Siglent SDG1000X Waveform Generators  (Read 87177 times)
Offline nihtila
  • Country: scotland
  • A Finn in Scotland. Audio Apps Engineer and Maker.
    • nihtila.com DIY audio electronics
Re: Siglent SDG1000X Waveform Generators
« Reply #50 on: November 24, 2018, 04:12:44 pm »
Thanks. Decided to order the SDG1062X ... and SDM3055  ::) My Black Friday was relatively cheap until almost midnight when placed the order on Tester/Pass.
I have quite a bit of projects coming and have some plans, and only have two PSUs and (good) scope at the moment. 10% discount is not massive but when the starting price was already ok and those were on my shopping list anyway. I know I could have hacked the SDG1032X but I'm not too much into playing with such stuff and the price difference wasn't huge.
http://nihtila.com - Vegan DIY audio electronics, does not contain snake oil
Online tautechTopic starter
« Reply #51 on: February 04, 2019, 08:02:45 am »
New firmware for SDG1000X series AWG's.
1.01.01.30R1B2
https://www.siglentamerica.com/download/8115/
Changelog
1. Fixed a bug: Setting frequency of one channel with square wave causes another channel output disabled
The following users thanked this post: tubularnut
« Reply #52 on: February 26, 2019, 09:43:38 am »
More new firmware for SDG1000X models.
Version 1.01.01.33R1
13.3 MB
Changelog
1. Supported TrueArb: 2~16 kpts
2. Optimized the UI of selecting built-in arbs
3. Changed the clock switch strategy: When the clock source is set to External and no actual external clock signal is being received, the clock source will not switch to Internal automatically but the clock icon will indicate that external clock is lost.
Offline 4x1md
  • Country: il
    • 4X1MD on Github
« Reply #53 on: February 26, 2019, 08:28:22 pm »
Is there any way to save a screenshot of SDG1032X to a USB stick?
« Last Edit: February 26, 2019, 08:36:01 pm by 4x1md »
Offline tv84
  • Country: pt
« Reply #54 on: February 26, 2019, 08:35:22 pm »
Don't remember well if they exist on SDG but try SCPI commands SCDP or BMP. Member Rerouter may help you.
« Reply #55 on: February 26, 2019, 09:06:08 pm »
Not with the front panel UI, just tried.  :(
There might be some how with the SCPI commands, dunno but have a look through them here:
https://www.siglentamerica.com/download/3290/
Offline rf-loop
« Reply #56 on: March 15, 2019, 09:24:50 am »
13.3 MB
Changelog
1. This also need urgently new updated User Manual's so that users can understand how to get all out from this  major improvement  and data sheets.
It is really nice upgrade. "TrueArb" technology  is big advantage in some situations when need Arb  without 1 clock jitter and/or jump over details, due to adjustable sampling speed (max 30Msa/s in TrueArb mode) and adjustabe Arb memory length. ( 2 to 16k.)
2. Previously selecting Arb from memory to use was cumbersome.  Also previously selecting Arb and then select some other Arb was really cumbersome. Now with this preview on screen and together with rotary encoder push it is easy and fast to select and change Arb waveforms in use. Well "Optimized" Siglent!
Interesting surprice find.
« Last Edit: May 02, 2019, 07:06:22 am by rf-loop »
Offline 4x1md
  • Country: il
    • 4X1MD on Github
« Reply #57 on: April 11, 2019, 08:28:29 pm »
Yesterday I found an issue with SDG1032X when I connected it to an audio amplifier. Every time I change frequency, I hear a click in the loudspeaker. I didn't check this issue with an oscilloscope but I know that it doesn't happen with my BK Precision BK4075. Is there any way to fix it?
Attached a video which demonstrates the issue.
Offline CustomEngineerer
« Reply #58 on: April 12, 2019, 05:00:43 am »
Try setting Utility->Mode->Independent
The following users thanked this post: 4x1md
Offline 4x1md
  • Country: il
    • 4X1MD on Github
« Reply #59 on: April 30, 2019, 07:35:55 pm »
It helped. Thank you very much!
Offline tv84
  • Country: pt
« Reply #60 on: May 28, 2019, 09:16:16 am »
SHELLCMD telnetd -l/bin/sh -p9999
Also works in this case  :-+, so no loading of special firmware is involved
Those .ADS do exactly the same and don't depend on the SHELLCMD availability...
Offline HendriXML
    • KiCad-BOM-reporter
« Reply #61 on: June 09, 2019, 08:06:52 pm »
During the final fase of implementing a method of doing measurements with the SDG1032X and SDS11004X-E with an accuracy of < 1 mV over a range of 0..1 V.
https://www.eevblog.com/forum/testgear/using-a-awg-and-a-scope-do-a-low-voltage-level-characterization-of-a-1n4005/msg2467191/#msg2467191
I had an unoptimized glimps of it and was very pleased with the results, however the SDG1032X fails on me and starts up only showing the logo.   :scared:
I've seen Dave's recovery video, and also read this:
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/msg1399308/#msg1399308
Is there a way to get the recovery files for this device and do a quick recovery?
« Reply #62 on: June 09, 2019, 08:37:32 pm »
I think I have what you need on the PC at home.
Do you know which FW version you had installed ?
I’ll be in touch by PM and will need your email to send the recovery files. I’ll be home in ~12 hrs.
The following users thanked this post: HendriXML
Offline HendriXML
« Reply #63 on: June 09, 2019, 09:01:45 pm »
Hi tautech, that would be great! My new device came with the newest firmware, so the recovery option should be included. Any idea whether the device depended calibration of it would survive the procedure?
« Last Edit: June 09, 2019, 09:24:34 pm by HendriXML »
Offline HendriXML
« Reply #64 on: June 10, 2019, 09:18:54 am »
This error got me thinking about the file system. If this problem is fixable, I would like to create further self constructed arbitrary waves at the usb drive. Does anyone know if thats possible using scpi commands?
« Reply #65 on: June 10, 2019, 09:32:40 am »
It is ! !  :box:
Have a look here at some samples I got from the factory years back......they were for the SDG1000 series but should still work with X models:
https://www.eevblog.com/forum/testgear/siglent-sdg1025-matlab-programming-arb-waveform/
Offline HendriXML
« Reply #66 on: June 10, 2019, 10:12:22 am »
Thanks for the link. But I didn’t find any info on how to select the wave destination. Maybe creating a symbolic link on the filesystem to redirect all custom waves to the usb drive is maybe the easiest.
I don’t know how well the wear leveling of the normal save location is.
« Last Edit: June 10, 2019, 10:18:42 am by HendriXML »
Offline HendriXML
« Reply #67 on: June 10, 2019, 10:26:53 am »
It is ! !  :box:
That would be great, but there’s still the question whether the calibration will survive the recovery.
If it doesn’t, then it might become less useful, certainly regarding the level of precision it had and the use I made of it. I think we’ll have to see. Maybe there’s a procedure to create a copy of the calibration data?
Maybe it can boot from the usb, without altering anything so the procedure can be run even in the stuck boot situation?
« Last Edit: June 10, 2019, 10:30:22 am by HendriXML »
« Reply #68 on: June 10, 2019, 10:31:05 am »
It is ! !  :box:
Maybe it can boot from the usb, without altering anything?
Yes.  ;)
Expect files soon......I have them from the factory now.  :phew:
Offline HendriXML
« Reply #69 on: June 11, 2019, 12:13:46 am »
Thanks to tautech, :-+
I could go back to finalizing my experimenting with the wave generator and the scope.
https://www.eevblog.com/forum/testgear/using-a-awg-and-a-scope-do-a-low-voltage-level-characterization-of-a-1n4005/msg2476044/#msg2476044
I haven't noticed any difference in how the device was/is calibrated, so that supports the idea that the calibration data is left alone. :-+
« Reply #70 on: August 20, 2019, 03:15:03 am »
New firmware for SDG1000X AWG's
Version 1.01.01.33R1B5
13.3 MB
https://siglentna.com/download/14915/
Release notes
Fixed an upgrade bug in 1.01.01.33R1. It is recommended to upgrade to 1.01.01.33R1B5 instead of 1.01.01.33R1
Offline e0ne199
  • Country: id
« Reply #71 on: January 17, 2020, 08:06:02 pm »
hello..does anyone here still have this file : SDG1000X_V100R001B01D01P22_eevblog.zip ?
i want to try the hack too  ;D
Offline tv84
  • Country: pt
Offline e0ne199
  • Country: id
« Reply #73 on: January 18, 2020, 12:10:59 am »
https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/msg1870091/#msg1870091
i have downloaded sdg1000x ads file but i am unable to flash it to my AWG...are there any additional steps to use it?
Offline rf-loop
« Reply #74 on: January 18, 2020, 02:41:01 am »
You mean this [telnet_SDG1000X.ADS]
This you can not flash at all. You do all like FW update with this file and SDG tell that it fails... do not care...do not shut off... just telnet and do what ever inside SDG system. If you do not know what to do there inside system and how... then please study first...yes it may take time to find all or if you find right place there can perhaps find all very detailed full instructions (it is like spring festival gift package what include all you need) what can use like blind (after you have telnet working) but be careful... it do not forgive any kind of typemistakes.   Do not try..oops...try...oops iteration... because this method may lead you to real problems and nearly like "destroy" your SDG
And seriously, do NOT downgrade to semidanger factory original or "eevblog version" FW ....01P22 even if you find it somewhere because if bad happen and it goes to boot problem... it do not support USB recovery method.
« Last Edit: March 09, 2022, 03:28:10 am by rf-loop »
The following users thanked this post: Johnny B Good
