Author Topic: Alkaline Battery Leakage Testing - Part 1  (Read 13874 times)
Online EEVblogTopic starter
« on: March 07, 2019, 03:04:18 am »
Will eventually be a full video when/if I get the results.
Comparing battery leakage on 7 different brands of alkaline aa batteries. Duracell, Energiser, Varta, Panasonic, Fujitsu and others.
Online gamalot
  • Correct my English
    • Youtube
Re: Alkaline Battery Leakage Testing - Part 1
« Reply #1 on: March 07, 2019, 03:09:37 am »
I don't even know that Coles has their own brand batteries.
Offline r3bers
  • Country: ru
    • solovjov.net
« Reply #2 on: March 07, 2019, 03:26:12 am »
I think on 47 Ohm will not work. Maybe something around 10 mA and maybe lower, 300 Ohm and higher. Because process of recharging will be short (maybe hours) on this load, all power will go into resister.
Offline Andrew McNamara
« Reply #3 on: March 07, 2019, 03:29:01 am »
Why not? They have their own brand everything else? Chinese manufacturers are more than happy to put your brand name on their product, rather than soil their own...  ::)
« Reply #4 on: March 07, 2019, 03:36:39 am »
One thing I've noticed is that they seem more prone to leaking when contained - a classic example being the old Maglite torches.
We used to know how to make batteries that didn't leak - 1980's RadioShack's helishly expensive premium series of batteries were nearly bulletproof. I wish I still had a choice between cheap shit and spending a bit more for batteries that don't destroy my gear.
I once contacted Eveready about their leak guarantee... they were more than happy to replace my device... provided I complied with a long list of absurd, impossible to comply with conditions...  :palm:
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #5 on: March 07, 2019, 03:37:35 am »
There was a discussion on leaking batteries recently and there are a few more threads on this topic around the forum as well, the thread is linked below. I recently bought some AA and AAA alkalines from Supercheap Auto but have no idea who the original manufacturer was and wondered if it was possible to determine the origin of different relabeled batteries.
If the same manufacturing process was used then there should be certain aspects which could help identify the maker, things such as physical dimensions, weight, initial voltage and other indicators such as the roll direction of the outer case. For example have a look at the negative end of any AA battery and compare the seam angle with another brand as they do differ.
https://www.eevblog.com/forum/chat/leaking-aa-and-aaa-batteries/
Dick Smith owes me a Maglite.    >:( ::)
« Last Edit: March 07, 2019, 09:03:36 am by Muttley Snickers »
« Reply #6 on: March 07, 2019, 03:58:29 am »
They don't make them of course, but an in-house rebadge.
« Reply #7 on: March 07, 2019, 04:00:49 am »
He just called me twice today actually, really, if I'd seen this earlier I would have mentioned it. Oh, he hasn't owned Dick Smith since 1982, guess he can't do much  ;D
« Reply #8 on: March 07, 2019, 04:02:16 am »
That's why mercury was added to batteries, it was a leakage protection barrier, but of course now it's banned.
The following users thanked this post: darik
« Reply #9 on: March 07, 2019, 04:04:32 am »
If you are talking actual power, then no it won't. Even at the end of life the ESR of a AA alkaline is under half an ohm.
Offline r3bers
  • Country: ru
    • solovjov.net
« Reply #10 on: March 07, 2019, 04:36:43 am »
One of battery must be dead to zero to start charging through closed circuit. And there is no data about resistance on this process.
Rd - resistance of dead battery
Rg - resistance of good battery
Rl - resistance of load.
Actually IRd must be higher than IRg+IRl to reverse voltage over dead battery. And it must be on low current to have a decent time to leaking.
Offline Cnoob
« Reply #11 on: March 07, 2019, 09:39:35 am »
Is this another way of saying "bring back the 9V battery and clip"?
Offline David Hess
  • DavidH
« Reply #12 on: March 07, 2019, 05:29:25 pm »
That is what I was going to suggest but you beat me to it.  Before the tiny amount of mercury was removed from alkaline batteries, I do not remember them ever leaking.
Offline floobydust
« Reply #13 on: March 07, 2019, 06:58:59 pm »
Asphalt seal was used before the green movement took over.  Not much else can withstand the strong alkaline for years. I'm curious what the seal looks like on these newer cells.
I think the new eco seals are cheap crap and are the problem.
P.S. I've had good cells leak, it's not the discharged state that affects it.
Duracell is King of the leaks, thanks Proctor and Gamble for killing the brand and quality, thanks Berkshire Hathaway for doing nothing at all other than reap profit.
« Last Edit: March 07, 2019, 07:02:07 pm by floobydust »
Offline David Hess
  • DavidH
« Reply #14 on: March 07, 2019, 07:20:16 pm »
Carbon-zinc cells used asphalt.  I have never seen that on alkaline cells.  When I need a carbon rod for something, I pick up some cheap carbon-zinc cells, disassemble them, and boil the extracted carbon rod in water to clean it.
Many of the leaking alkaline cells I have encountered leaked at the bottom of the outer shell which has nothing to do with the seal at the positive end.
Offline floobydust
« Reply #15 on: March 07, 2019, 07:55:36 pm »
I got the information from the plethora of battery patents, where the chemicals, seals etc. are discussed, and taking apart old alkaline batteries that never leaked after 10 years.
It's common asphalt or tar pitch and now could be nylon, styrene hot glue, epoxy etc.
I find the leaks start at the -ve end and after a while include the +ve end.
"... The closure members, since they are usually exposed to the elements contained within the cell are required to be substantially inert to such elements. As a result it has been preferred to utilize plastic e.g. nylon, polyethylene, polysulfone, and other generally inert materials for such members. In many cases, however the aforementioned materials have shortcomings such as cold flow under temperature cycling and imperfections in the surface area thereof. The metallic surface areas in contact therewith generally have imperfections as well. Thus, a cell electrolyte such as the common alkaline KOH utilized in many commercial cells (an aggressive leaking material) may leak, over a period of time, through such imperfections. Such leakage is in fact exacerbated by the hydrogen gas evolution common in alkaline cells which tends to push the electrolyte through the path of least resistance, i.e. the seal."
"... The aliphatic or fatty polyamides are coated on sealing members such as grommets by means of a relatively expensive and complicated spraying procedure."
"alkaline electrolyte battery container, cover, etc. tends to crawl the wall by capillary action to wet the sealing piece has the property that oozes to the outside from the sealing part of the battery. This behavior metal surface is connected to the negative electrode, i.e. it appeared strongly to the negative terminal side of the sealing portion, prone to leakage. This is commonly known as liquid leakage due to electrical capillary action..."
US4618547A
US10008748B2
US20050271942A1
JP2870152B2
The following users thanked this post: SilverSolder, helius, Marco1971
Offline darik
« Reply #16 on: March 07, 2019, 08:18:10 pm »
For years I've been wondering what the hell changed. I remember alkalines being practically leakproof, you only had to worry about those shitty cheap carbon batteries. Then suddenly they're going off like firecrackers and you can't trust them at all.
I knew it had to be something specific, thank you.
« Reply #17 on: March 07, 2019, 10:05:32 pm »
9V batteries just contain 6 x AAAA alkaline batteries
The following users thanked this post: Cnoob, Marco1971
Offline Cnoob
« Reply #18 on: March 07, 2019, 10:17:29 pm »
In all Seriousness Dave and others  this topic has  made me go and check the batteries in my test equipment 10 items in total.
I have a digital pen which uses one AAAA .
edit: I forgot one too check my frequency counter so 11 items. 13 items now
PS it does explain why I had 4AAA batteries leak in an LED torch which I was surprised because they were not that old.
« Last Edit: March 08, 2019, 10:31:20 am by Cnoob »
Offline Towger
  • Country: ie
« Reply #19 on: March 07, 2019, 10:24:25 pm »
Some are (were) a pile of flat rectangular cells.
« Reply #20 on: March 07, 2019, 10:46:23 pm »
Yes, Coles and Varta at least.
But if they are the same Alkaline chemistry then I'm assuming there is no reason why they can't leak the same.
Offline r3bers
  • Country: ru
    • solovjov.net
« Reply #21 on: March 08, 2019, 01:50:08 pm »
There is more conditions to leak in 9V battery in long time. Because unbalanced current through 6 elements will be much possible.
Offline rrinker
« Reply #22 on: March 08, 2019, 02:38:13 pm »
 Sidenote, I just watched a video where they unboxed a never-before opened pinball machine still sealed int he original shipping box, from 1993. For backup in the electronics there were 4x AA Panasonic cells. Not alkalines. Not only had they not leaked, they actually were STILL GOOD!
 In more than a few ways, it seems we've taken a step backwards when it comes to common removable batteries. There's even a fair percentage of DOA fresh out of the package and still not past the expiration date, not to mention the now almost guaranteed TO leak design.
Offline HKJ
    • Tests
« Reply #23 on: March 08, 2019, 07:28:39 pm »
That is not correct, 9V batteries are made either with 6 AAAA cells or with  stacked blocks.
I disassembled a lot of 9V batteries here: https://lygte-info.dk/info/BatteryDisassembly9VAlkaline%20UK.html
The following users thanked this post: r3bers
Offline floobydust
« Reply #24 on: March 08, 2019, 08:01:45 pm »
Took apart a leaking Duracell AAA battery. The -ve end seal is a plastic disc with a copper pole going through the middle. Then a felt washer and cap over that to make the -ve terminal.
A hard crimp on a plastic washer is clearly a fail for a seal here. They can't use an o-ring? OMG shareholder profits would suffer  :palm:
Date marking (best before) MAR 2018, Made in USA.
edit: took it apart further. The seal is a plastic piston with a layer of tar applied to the outside ring.
« Last Edit: March 08, 2019, 08:27:35 pm by floobydust »
The following users thanked this post: thm_w, edavid, Andrew McNamara, Marco1971
