Author Topic: A good very low voltage electrolytic capacitor for the purpose of blowing up?  (Read 8541 times)
Offline XOIIOTopic starter
Hey all, I am wondering if there are any nice very low voltage electrolytic capacitors, that are decently sized physically, that would blow if given around 5 volts or so.
I also because I have always wanted to rig up devices, maybe dummy computer mice, or just little gadgets that I could use a micro to trigger the capacitor to blow up, they provide a nice little pop and puff of smoke, however the lowest value caps I usually see are 6.3v, and I am unsure if something rated for 3 volts would actually blow if given 5 volts or not.
Offline T3sl4co1l
    • Seven Transistor Labs
Resistance wire (very fine) and a firecracker (if they're available in your area, anyway..).
Electrolytics aren't rated for operation at less than -3V, or much more positive than their rating.  But that's hardly a guarantee for failure; 6.3V caps can operate at -5V (5V supply, installed backwards) for months before failure.
Tantalums are likely to fail at -3V, but I wouldn't really recommend one for a prank, they're a bit lively for that.  Well, so is the firecracker, but that's a limited pop and little or no fire, which a mouse should contain quite well.
Don't suppose you can find a very small smoke / fog generator that's USB powered... actually... I'm sure such a useless novelty already exists...  You wouldn't get the suspicious crackle-pop sound and burnt electronics smell though, at least not without doping the fog juice with phenol and depolymerized bisphenol derivatives.
Tim
Seven Transistor Labs, LLC
Not much in the way of firecrackers here, and I'm looking for for the smoke than a bang.
I wonder if something like a 10 ohm quarter watt resistor would work well, not really sure what resistance would be good for this sort of thing.
Offline kizzap
I preface this with a "I have never seen a Tant blow"
however I hear that reversing the polarity on a Tant makes them extremely unhappy.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline G7PSK
  • It is hot until proved not.
A few milli amp fuse and red match heads make for a good bang, put a bit of talc in with and you get what loos like smoke. I have used this for pyrotechnics in the past.
Offline dexters_lab
just reverse polarity it and it should pop, though i wonder if you might need a few more volts
They go with a fair crack so if your  putting inside a mouse you would probably only need like a low voltage 10 or 47uf.
i was popping a few the other week, i have some nice tantalums ready to be popped, if the weather is good this weekend i might make another video.
Reverse polarity, 30v usually pulling about 3 amps before they pop
Online Psi
50/50 Potassium nitrate and sugar makes a nice amount of smoke.
Could ignite it with a model rocket motor igniter.
Just be sure you dont burn someones house down
What's a bit of arson between friends?
Yeah, I used to cook up KN03 using cold packs and kosher salt, works pretty nicely, just a bit expensive for those cold packs but eh, I should still have a decent sized jar of it somewhere.
Won't have the right smell to it unfortunately.
Offline Fred27
    • Fred's blog
You've just reminded me of when I did electronics at school. Our teacher promised that if we managed a whole lesson without blowing up an electrolytic capacitor then he'd get the biggest one he could find and blow it up for us (with safety goggles on of course). We managed it. It wasn't all that impressive anyway.
Probably wasn't big enough lol.
I made a variable power supply in grade 8, not for school though, but a college class I audited, sadly I drove it too hard blowing up capacitors and burnt it out. Never got around to fixing it, I think I scrapped it for parts a long time ago, but man, some nice big ones can really fill a room with smoke  :D
Offline dexters_lab
yea i think with the larger ones the rubber seal can pop out easier or they blow the the vent.... or maybe you just need more wattage to pop em properly
Probably, I think less current gives more chance to smoke out (where they just spray a bunch of smoke) rather than just blowing up. I think ramping up the voltage a bit more gradually helps to make them smoke out too.
Offline AlanR
Tantalum make good fire balls.  >:D >:D >:D >:D
Offline Macbeth
When I were a lad, I would get the steel wool from pan scourers and wrap a few strands around some nails tightly, and use that as a detonator with a 9v battery. My gunpowder ingredients were sourced from my local chemists potassium nitrate, sulfur. I powdered down charcoal BBQ bricks too. Often I would have to use different chemists for the saltpeter and sulfur as it was plainly obvious to them when a 14 year old was getting up to when buying such  :-DD
I had to say I was buying saltpeter for curing meat for example. Haha.
Of course in these insane times I would expect to be locked up in Gitmo for daring to play with chemistry and electronics in such a way.
Offline Someone
    • send complaints here
Resistors tend to just burn cleanly.
Electrolytic capacitors go bang.
Tantalum capacitors smoke.
Conveniently tantalum capacitors are also available in very low voltages, but you'll probably still need a fet to switch the large current and possibly a large electrolytic next to it to provide the initial current.
Offline tom66
A reversed biased or overvolted lytic only pops violently because of extreme heating and pressure build up. Even the best USB ports are current limited and a mouse will use the thinnest wire practical, I doubt you'd see more than an amp which might make a sizzle but I doubt much more.
Offline wraper
  • Country: lv
Hitano EXR is worth a try. At least it took ~10 seconds for 47uF 25V cap to blow up violently on 15V reverse polarity. I've only found 2 leads sticking out of the board and very small paper particles all around. Small cap without a safety vent is recommended  ;D. Unfortunately don't have any of them left to try :-DD
« Last Edit: June 28, 2014, 02:43:01 pm by wraper »
Offline rob77
  • Country: sk
back in time we got big-ass electrolytics with no vents ;) 4700uF or 10000uF - those were quite a bangs , but hell of a smoke as well :D and the lovely pieces of paper and foil all over the place :D
(i would rather not describe the freaking dangerous firing method of those big caps :D )
that was back in time when i was young and stupid... but i'm not young anymore :D
Offline VK3DRB
Electrolytic capacitor smoke is quite toxic. Don't blow them up.
35 years ago I made a burglar alarm which would shock the burglar by exploding some electrolytic capacitors. The resultant fumes were very nauseating... an added bonus. Not really a good idea.
Offline c4757p
  • adieu
shock the burglar
Now there's an idea. ;)
Electric fence energiser does that, legally. I have been tempted to install the wiring all the way down the gate, so as to include the bottom, but that is not allowed.
Would stop the drunk guys from using it as a urinal though.
Eskom has a lot of substations with an inner fence ( 3 layer fence)  between the 2 outer layers supported on glass insulators 30cm over a concrete base with a steel ground strap under it. Fence and gate in it are connected to a separate 33kV single phase transformer  via a line reactor, remote disconnect and a recloser, along with a monitor for voltage and current. It is classed as a live work area, done so that they do not get sabotage of the inner yard.
Offline kingofkya
Nichrome
Cloth (used as a wick)
Glycerine (used in most diy fog/smoke machines)
Coat the cloth in Glycerine (you can dulute with watter if you want)
Then just set the Nichrome on cloth. Done:)
Like other have said you can't draw too mutch power from the mouse wireing maybe a big cap for some power storage?
I have also coated nicrome with flux, not as much smoke though:)
« Last Edit: July 01, 2014, 05:31:20 pm by kingofkya »
Offline dexters_lab
perfect use of the resources available!
They had a few try to steal the fence, but were unable to identify who it was..............
Enough voltage and they will be there the next morning to find during your inspection.
