Hey guys, thanks for the responses! I actually just wrapped up a 3 hour meeting with a Trans-Tec (Yamaha) service tech, more on that later.
I'm aware that brick walls shed, and I can cover them if needed, but I think a giant HEPA filter unit that can be had for relatively cheap will take good care of it. As the service tech told me "you think all the guys running these machines in Mexico have air conditioned dust-free rooms?"
If I can put the compressor outside it'll be nice, or at least in the hallway where it won't take up space. Then I could just build a box around it to keep the noise down. The tech told me for these machines I'll need about 12 CFM @ 5 bar per machine. Plus whatever the stencil printer takes. So call it 30CFM. Both PnPs use pnuematic feeders. So a decent sized compressor. Granted these are on the conservative side with the machines running full tilt. He recommended a dedicated 20A breaker for each PnP, probably same for the stencil printer, 100A for the oven, whatever the A/C and dehumidifier draw, and the compressor. So I think 200A will do it. Each one should be on its own breaker which makes perfect sense to me.
As for the tech, I talked to him a lot about the capabilities, spare parts, maintenance, etc... He even called 2 customers and had me talk to them. Granted they could be cherry picked but they both seemed very happy with the machines and said that aside from operator-induced damage (leaving a feeder on top of the machine where the head runs into it) they've never had to do any service aside from routine maintenance like seals/grease. One client had the same types of machines running since 1998 and still in production. He's setting up a visit to a company (major defense contractor specializing in electronics) where they are running these machines. Certainly gives me comfort.
I got a good impression from the TransTec guy. He didn't hesitate to point me to third parties for feeders/nozzles if it made sense. He said they don't try to force people into service contracts for things like calibrations, and in my case a service contract isn't necessary. They offered to come out when the machines are delivered to check everything as it comes off the truck. Phone support is free, latest software is free, service calls if you need them might be $140-$180 per hour. Spares are still being manufactured today for both the machines I'm looking at.
As for shipping I explained my plans and concerns. I was told that the moisture barrier is an unnecessary expense nif it's in a dedicated air-ride truck. Shrink wrap and desiccant should cover it along with shock and tilt sensors. As for vibration damping I was told it's also unnecessary, just put the machine on a sturdy pallet and shrink wrap it then secure it in the truck. He's been there for over 20 years and says all of their machines are shipped this way from Yamaha and that they've never had an issue doing it this way. They DO seem quite sturdy. He also explained exactly how to secure the axes - if the seller doesn't have the brackets that do this it's OK to use some of those big-ass zipties. The heads on the Opal are spring-retract and don't *need* to be secured, the heads on the MG-8 are servo driven and can also just be loosely ziptied to keep them up.
The gist of it was he told me to relax and breathe, as long as the machines aren't moved between being loaded on the truck and unloaded at the destination they'll be fine, and it will be obvious if someone put a forklift through the machine or if it was removed from the truck during transit.
As for the stencil printer and reflow oven, these now seem like the biggest unknowns that I know the least about.
Agree on the feeders, I'll figure it out. I have 15' ceilings so it'll be easy enough to put the ones I don't need up there for storage.
