Author Topic: EEVBlog 121GW Discussion thread  (Read 792963 times)
Online IanB
Re: EEVBlog 121GW Discussion thread
« Reply #1075 on: August 31, 2018, 02:59:26 am »
I have not ran a test like this with any of the other handheld meters I have.  None of them can capture data this fast.
Last night I ran a crude test on my BM869s by driving the data interface cable as fast as possible with a test program. I was able to obtain readings over the cable at a rate of about 200 ms per sample. This was done by starting the next read as soon as the previous read was completed and measuring the interval. I may post more on this in another thread after I do a few more experiments.
Offline MiroS
« Reply #1076 on: September 06, 2018, 10:03:38 am »
Dr Frank was suggesting a higher test current for the low ranges.
I do  not have this metter, but majority of multimeters I touched have always problem with low and high margin of ranges, especialy for lowest  range is a good test for mesuremant capabilities, e.g. current like 100nA, or 1nA.  Even if spec is claiming 0.5 % or so at marginal values for ranges  this might be quite high like 10% for lowest range and test current like 10nA, or 1nA , or 1uA at 1000V etc.
I wonder if GW121 is much different from other mutimeters?  I would think that it might be  actually worst than others due to low burden volatege (?)
Offline HKJ
    • Tests
« Reply #1077 on: September 06, 2018, 10:22:47 am »
You have to look at the full specifications. A tolerance may be 0.5% + 4, the 4 is a very important part of the tolerance specification when measuring low values.
There is also a detail about AC, there the tolerances is usual not valid below 5% to 10% of the range.
I wrote a bit about it here: https://lygte-info.dk/info/DMMTolerances%20UK.html
Offline MiroS
« Reply #1078 on: September 06, 2018, 10:27:56 am »
Nice article, thanks for sharing. Btw, I know rules , but  I wonder how is doing 121GW comparing to others by tests.
Offline HKJ
    • Tests
« Reply #1079 on: September 06, 2018, 10:38:58 am »
When I tested it, it was inside the specified tolerances (with one exception).
https://lygte-info.dk/review/DMMEEVBlog%20121GW%20UK.html
Offline MiroS
« Reply #1080 on: September 06, 2018, 10:54:04 am »
I can  not find  test with nA test current. Did I missed this?
Offline HKJ
    • Tests
« Reply #1081 on: September 06, 2018, 10:59:39 am »
My lowest test current is usual 1uA, I did mention that you need to use REL mode.
Offline MiroS
« Reply #1082 on: September 06, 2018, 11:31:40 am »
.....range and test current like 10nA, or 1nA , or 1uA at 1000V etc.
Are you trying to apply 1000V with a supply that is limited to a uA and measure the voltage?  If you are trying to measure current, where does the 1KV fit in?   I am not sure what you are asking.
Not uA and not like this, as simple as that:
- 100nA at any voltage (better 10 or 1nA, no idea how 121GW sensitive is)
- 100nA (better 10 or 1nA, no idea how 121GW sensitive is) at 1kV (1kV relative to ground , not accross multiemer)
Offline HKJ
    • Tests
« Reply #1083 on: September 06, 2018, 11:57:46 am »
That would be outside the specifications for the meter, it is only rated for 600V to earth.
Offline MiroS
« Reply #1084 on: September 06, 2018, 02:14:17 pm »
I would  not care for specifiation for such tests, but other hand I cannot ask anyone for potentialy destructive tests.
I would also not buy 121GW at this moment for own  tests, it looks not mature to me.
Offline Seppy
  • Curious
« Reply #1085 on: September 10, 2018, 12:11:09 am »
Are you looking to find leakage current of the voltage range? If so, the leakage at 1kV isn't likely to fit on a straight line curve down to zero, so we would need a few different points.
Offline Visitor
  • Country: at
« Reply #1086 on: September 16, 2018, 04:03:24 pm »
Hi!
Got my 1.21GW a few days ago.
My first impression was like  :palm: when i saw the glonky springs trying to hold the batteries in place.
Oh my god, what a bad quality battery holder for a 240 EUR Multimeter.
Without aranging the Springs after puting the batries in  the holder they would almost jump out of it.
But the Multimeter itself looks pretty god  :-+
Some measurements in relatve mode makes no sense for me, but i need some more practice.
Offline chronos42
« Reply #1087 on: September 16, 2018, 06:34:21 pm »
that is true, the battery holders are terrible. That was also my first impression.
The worst springs of all my battery powerd instruments. I have aligned the springs with a small tweezer, so now it lookes a bit better.
Beside of this a great meter with some room of improvement in the firmware.
Offline 1anX
« Reply #1088 on: September 16, 2018, 09:51:39 pm »
I think all of us who bought this meter were shocked at the springs fitted in the battery holder. A well made battery holder fitted with springs which are simply too long.
To use a "Dave" expression when reviewing products the springs are a "FAIL"!
Good meter fitted with the wrong length battery springs, how did this get into the production run?
Offline stig
  • Country: no
EEVBlog 121GW Discussion thread ESR of capacitors measurment
« Reply #1089 on: September 17, 2018, 07:32:39 am »
Was just wondering if it would get ESR in the capacitance measurment aswell :)
Offline CDaniel
« Reply #1090 on: September 17, 2018, 10:36:48 am »
This multimeter has in theory an 50000 counts display , than range switching upward  at 55000 counts but downward at 40000 counts  is supposed to be a feature ?
I find this rather annoying ... lets say  I want to adjust a 5.0000V voltage refference , if I go up beyond 5.5000V I lose the last digit of resolution because is switching the 50V range , but then if I adjust downward I can't get it back since it remains in 50V range until it reaches 4V
« Last Edit: September 17, 2018, 11:21:48 am by CDaniel »
Offline Cliff Matthews
    • General Repair and Support
« Reply #1091 on: September 17, 2018, 12:20:07 pm »
@CDaniel - Why not use the provided range switch?
Offline CDaniel
« Reply #1092 on: September 17, 2018, 12:32:54 pm »
Because it has autorange ...  |O
« Reply #1093 on: September 17, 2018, 02:54:51 pm »
@CDaniel - You said you can't get it back after you turned down V-ref.. go manual to desired range, then flip it back to auto.
Offline CDaniel
« Reply #1094 on: September 17, 2018, 04:27:11 pm »
Sure I could , but I don't think is normal to be 2 thresholds , that is my point .
And that was just an example .
« Last Edit: September 17, 2018, 04:28:55 pm by CDaniel »
Offline newbrain
« Reply #1095 on: September 17, 2018, 04:28:50 pm »
I would consider this quite normal, though the hysteresis is a bit on the wide side.
This is what happens with my Fluke 87V:
Counts
Up at
Down at
6000
6.600
+10
5.40
-10
20000
19.999
+0
16.80
-16(Of course, it can't display > 19999)
The 121GW does it at +10% and -20%.
Sure I can , but I don't think is normal to be 2 thresholds , that is my point .
It's definitely normal! Without hysteresis you would have continuous range change at the threshold, a much worse experience.
Nandemo wa shiranai wa yo, shitteru koto dake.
Offline darik
« Reply #1096 on: September 17, 2018, 04:40:49 pm »
I have 4 meters. They all have two thresholds like that. I would imagine to prevent excessive autoranging when taking measurements near the threshold value. I believe it's called hysteresis.
Offline CDaniel
« Reply #1097 on: September 17, 2018, 04:45:54 pm »
Ok , you are wright , I cheked my other multimeter who has 6,6V up and 6,2V down , which is much smaller and I never noticed since is not around 5V ( I don't think that's random design )
« Last Edit: September 17, 2018, 04:51:31 pm by CDaniel »
Online IanB
« Reply #1098 on: September 17, 2018, 06:19:56 pm »
Sure I could , but I don't think is normal to be 2 thresholds , that is my point.
And that was just an example.
There will always be two thresholds to prevent "hunting" of the auto-range circuit when close to the switch point.
Offline Seppy
  • Curious
« Reply #1099 on: September 24, 2018, 01:40:38 am »
V1.51 Firmware released, change log will be in the manual soon.
www.eevblog.com/product/121gw/
The following users thanked this post: jancumps, hammy, Dr. Frank, 1anX
