Author Topic: Electrokinetic sonic amplitude measurements  (Read 931 times)
Offline stcosoTopic starter
« on: March 06, 2018, 09:17:01 pm »
Hi, I'm a chemist and I'm interested in electronics... So, in nanomaterials science a technique called "Electrokinetic sonic amplitude" is sometimes used to measure the mobility of suspended nanoparticles in solution.
I've attached a scheme of the basic measurement cell for this technique.
I'm wondering how the generation of the sine wave works...
The solution between the electrodes can basically be described as a resistor (ranging from 1MOhm to 100Ohm)
In series with a capacitor (in the order of magnitude of 100pF)
Offline rhb
Re: Electrokinetic sonic amplitude measurements
« Reply #1 on: March 07, 2018, 01:19:02 am »
Buy a JDS-6600 AWG good to 25 MHz, place the electrodes 2 mm apart.  Set the AWG to 20 Vpp.  Actual mileage may vary, but it will get you started.  Very likely you will want to add an external amplifier to boost the output voltage a bit so you can use a wider cell.
That's a large frequency span, so the impedance is  varying quite a lot.  As a consequence you will need to build an automatic tuner to adjust the impedance matching.  I suggest reading my posts to the "Roller inductor... and other craziness"  thread.  The OP is trying to build a mass spectrometer.
At about age 13 I was morally corrupted by Clair Stong's volume of   Amateur Scientist columns from Scientific American.  "For less than the price of an average set of golf clubs, you too can smash atoms in your backyard."  The column goes on to describe a linear particle accelerator built by a faculty member at Brooklyn Polytechnic IIRC.
Above 1-2 MHz life starts getting complicated.  At 20 MHz you're just at the edge of a real adventure.
Take a look at the amateur radio literature describing power amplifiers and antenna tuners  for HF from 160 m to 15 m.  It appears to me you've got a doozy of an impedance matching  problem.  So you're looking at a more complex version of what I described in the mass spec project thread.  You'll have to tune the system by sampling the voltage potential across the electrodes.  Not hard, just more moving parts.  The paper by the Stanford folks referenced in that thread is rather poorly done, but the concept is very similar to what you need.
Have Fun!
Reg
The following users thanked this post: stcoso
